Ok guys, as some of you know, I am still working on the USSR Computer. If not you should check it out. It was headed by our friend cpt Slug. http://www.ocforums.com/showthread.php?t=403779
Basically I am trying to figure out a way to do a modular design with the PSU. Space is very limited. I know some people use speaker connectors, but are there connectors that have 4 prongs so that you can carry all 4 wires through it? I just need to be able to unplug things when I open the case. Anyone know where I could pick something like this up or able to give pics or examples?
I do not want to use the actual PSU plugs as the modular plugs. I am looking for a cleaner/custom look.
Thanks,
JS
Thanks,
JS
