- Feb 21, 2008
- Baltimore, MD
hello all. im relatively new here. ill start with my build and current specs in BIOS. ive successfully acheived a stable OC of 3.2 GHz, but i want more
Machine:
Antec 900
q6600
Asus P5K3 Deluxe
2x1GB G.Skill DDR3-1066
Cooler Master Xtreme 550W
zalman 9700NT optimal mode (1300-1800rpm)
2x 120mm tri-cool front fans (low)
1x 200mm tri-cool top fan (high)
1x 120mm side fan (1200 rpm)
1x 120mm scithe rear fan (1000rpm)
BIOS:
core voltage is consistently .02V lower than BIOS setting, and Vdroop is about .04V (ex, 1.52V BIOS= 1.50V idle/1.46V load)
values in [] are current, values in () are available choices. like i said this current setup is stable. temps in prime are 60C, in folding are about 55C. im looking to get at least 3.6 GHz stable on air, 3.8 if possible. ive tried upping the FSB to 400, seting the ram to DDR3-800, and upping the CPU voltage to 1.50V. booted up fine, but running prime caused the machine to reboot within a few seconds. i upped the voltage to 1.5125 and prime ran for about 30 seconds and got an error on one instance (running 4 instances to stress all 4 cores). upped the voltage to 1.525. prime ran ok for a few mins and the machine just shut down again. temps were approaching 70C which is getting a little warm. and i really dont think id be comfortable letting it run hotter than that for any extended period of time (unless its ok). im looking for some guidance on where to go from here and what settings you think i should change to achieve 3.6+. i really dont know what most of those settings do thats why i left most on auto. maybe if someone could explain all of them?
hope i gave all the info you guys need to point me in the right direction. is it possible that the PSU just cant do it? or is the CPU getting to hot and shutting it down? i dont get any error messages when it restarts. or anything else.
thanks
Machine:
Antec 900
q6600
Asus P5K3 Deluxe
BIOS:
Code:
CPU Ratio [9] (6-9)
FSB Frequency [355]
DRAM Frequency [DDR3-1065MHz]
DRAM Timing Control [Auto]
DRAM Command Rate [Auto] (1T,2T)
DRAM Static Read Control [Auto] (Enable, Disable)
DRAM Dynamic Write Control [Auto] (Enable, Disable)
Transaction Booster [Auto] (Enable, Disable)
Clock-Overcharging Mode [Auto] (700,800,900,1000mV)
CPU Spread Spectrum [Auto] (Disable)
CPU Voltage [1.400] (0.0125V increments)
CPU Reference Voltage [Auto] (.63x, .61x, .59x, .57x)
CPU Voltage Damper [Auto] (Enable, Disable)
CPU PLL Voltage [Auto] (1.50, 1.60, 1.70, 1.80)
DRAM Valtage [Auto] (1.50+ 0.05V increments)
FSB Termination Voltage [Auto] (1.2-1.5V)
North Bridge Voltage [Auto] (1.25, 1.40, 1.55, 1.70)
North Bridge Ref. Voltage [Auto] (.67x, .61x)
South Bridge Voltage [Auto] (1.05, 1.20)
thanks
