Hi guys, I have a question about vid, since its not listed in the ark like my old x5690.
Looking at core temp, there is a box marked VID, and when running with the green stuff on it fluctuates from under a volt, to roughly 1.21v and some change. Would that be considered stock voltage range? Because to me it does. And since I have gotten this far with my question, maybe I will ask another. I can do 4500mhz with 1.215v, no problem, running intel burn test temps peak at roughly 80c. Awesome I thought. But no matter what, I cannot get this cpu to pass ibt using the x46 multi and up. Ive tried mooar volts. A lot more, I think I gave up at 1.35 or so. But when running with all the green stuff on, I can hit the x47 no problem, but the board just piles on the voltage, causing insane temps.
Is 4500 the best I can get from this thing? I was hoping for the magical x50, but I'm not so sure.. Also, slight observation from looking at various reviews. This board lets you add +140w, but the maximus or something I saw on overclockers.com gave you +150w. Does that extra 10w make that much difference? Do you think I'm at the limit of the cpu so soon, or maybe the board? I'm leaning towards operator error.
Thanks in advance
Thanks in advance
