What got me to thinking about this was when I read this statement over at extreme overclocking.
"First , you must make sure that the CPU is set at the same bus as the RAM , otherwise one of the 2 will not use the other's extra bandwidth , and you don't want that . For example , if you have PC2700 memory and a 166mhz RAM capable motherboard (like the ones with the KT333 chipset) , you should set the CPU also to 166 mhz FSB , and lowering the multiplier below the default value"
-Micutzu
