Hello Everyone, I have recently purchased a 3GB EVGA GTX 780 SC w/ACX Cooler to replace my 3 GB EVGA GTX 580. After installing the GTX 780 I have noticed that most of my games have been restarting randomly during gameplay and the occurence varies greatly between games. For example, Max Payne won't get past the loading screen while Crysis 3 could range from 2 minutes to 2 hours before a reset. I haven't been gettting the BSOD or any error messages other than the Event ID 41 for Kernel-Power Error in the Event Logs.
My Rig:
Windows 7 Home Edition 64-bit
Ivy Bridge i7 3770K 3.5GHz
16GB Patriot 1600Mhz RAM
3GB EVGA GTX 780 SC w/ ACX Cooler
OCZ FATAL1TY 1000W PSU
P8Z77-V Deluxe MOBO w/ Latest BIOS updates
I have contacted tech support at EVGA and they were very helpful suggesting a few fixes. First they had me rollback from the newest drivers to the drivers that were installed on the disk so that I would have a clean install and thay didn't fix the problem. They also had me remove the 780 and re-install the GTX 580 to see if the problems persisted and the random resets stopped with the GTX 580. I then tested the 780 in another system and everything worked fine without the random resets.
Since the GTX 580 and GTX 780 both have the same power consumption (according to EVGA) and the 580 is running perfectly on the machine I wouldn't think it is an issue with the power supply. I just don't have anymore ideas what could be causing the issues and since EVGA knows it isn't their card then they have left it up to me to figure it out. Since the card works in another system then I guess I can't blame them.
Any assistance would be greatly appreciated and any ideas are welcome. Thanks!!!
My Rig:
