- Sep 9, 2003
- Houston, Texas
Rambus will make one more play early this year (2004) when SiS releases the R659, its anxiously awaited, long-delayed quad channel RDRAM chipset. R659 will run pc800, pc1066, and pc1200. Steady now-these arent foo-foo bandwidth numbers like the ones used to describe ddr modules, kids. These are real clock speeds, Thus the R659 will run a pair of dual-channel RDRAM moduales at 1200mhz for a total of 9.6GB/s of bandwidth.
SiS has also taken some steps to reduce the latency that RDRAM was criticized for. While we've been looking forward to the R659 for months, it probably wont be enough to displace the move toward DDR2. If you think intel will suddenly rekindle it love-fest with Rambus, know this: Intel just made a $450 million investment in Micron, a company that doesnt fab RDRAM at all....
My prediction....
why would they make a $450 million dollar investment into a company that produces DDR?? i think its because they are using it as a backup plan if you will LOL those guys know it might not stand a chance against what DDR2 has to offer.
On the otherhand, DDR2 itself will operate at a lower voltage of 1.8 volts versus 2.5 volt DDR RAM, and will use ball-grid array memory similar to that used on high-performance videocards. The DIMM will have 240 pins versus DDR's 184 pins. While we will still use the clock speed designation, the industry nomenclature will identify a DDR2-400 moduale as PC2-3200, a DDR2-533 part will be called PC2-4300. DDR2 also increases potential bandwidth by prefetching twice as much data as DDR does. Thus, a DDR2 400 module could in the right situation offer twice the theoretical bandwidth as DDR400.
Even though this might sound like i'm putting RDRAM down i must say this for my own personal moral value...you know what they say afterall...dont believe everything you hear and only believe half of what you see...
Here are some DDR2 related sources:
ZDNET Article
Infineon Specs
Micron Website Direct Link
My prediction....
ZDNET Article
Infineon Specs
