I posted the other day but maybe it wasn't informative enough, I just really need some advice or a fix.
I bought an Intel D865PERL motherboard with an intel P4 2.8 533FSB processor and two sticks of Centon 256mb DDR434 PC3500 ram
heres the specs:
____________________________________________________
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.80GHz
Speed : 2.79GHz
Performance Rating : PR3072 (estimated)
Type : Standard
Package : FC µPGA478
Rated Speed/FSB : 2800MHz / 4x 133MHz
Multiplier : 21/1x
Minimum/Maximum Multiplier : 0/1x / 21/1x
Generation : G7
Name : P4N (Northwood) Pentium 4 1.6-3.4GHz 1.5-1.6V
Revision/Stepping : 2 / 7 (9)
Stepping Mask : C1
Microcode : MU0F2737
Core Voltage Rating : 1.550V
Maximum Physical / Virtual Addressing : 36-bit / 32-bit
Part Number : To Be Filled By O.E.M.
Asset Tag : To Be Filled By O.E.M.
Serial Number : To Be Filled By O.E.M.
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 8kB Synchronous Write-Thru (4-way sectored, 64 byte line size)
Internal Trace Cache : 12kB Synchronous Write-Thru (8-way, 64 byte line size)
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
L2 Cache Multiplier : 1/1x (2793MHz)
Upgradeability
Socket/Slot : J2E1
Upgrade Interface : Socket 478
Supported Speed(s) : 3.06GHz+
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : Yes
DS - Debug Trace & EMON Store : Yes
ACPI - Software Clock Control : Yes
MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SS - Self Snoop : Yes
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : Yes
SBF - Signal Break on FERR : Yes
SSE3 Technology : No
MON - Monitor/MWait : No
DSCPL - CPL qualified Debug Store : No
TM2 - Thermal Monitor 2 : No
EST - Enhanced SpeedStep Technology : No
CID - Context ID : Yes
DAZ - Denormals Are Zero : Yes
Advanced Settings
Data Error Checking : No
Fast Strings : Yes
x86 FPU Compatibility Mode : No
Prefetch Queue : Yes
Branch Trace Storage : Yes
Data Cache Active Mode : Yes
IO Queue Depth : 12 request(s)
Thermal Monitor Enabled : Yes
_____________________________________________________
Mainboard
Manufacturer : Intel Corporation
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : D865PERL
Version : AAC27646-210
Serial Number : BTRL35003873
On-board Devices
Intel GMCH AGP Graphics Controller : Video Adapter
Intel 82562 Ethernet Device : Ethernet Adapter
Intel ICH4 Audio Device : Sound Adapter
FireWire IEEE P1394 Controller : Other
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 4GB
CHANNEL A DIMM0 - J5G1 : Manufacturer1 PartNum1 SerNum1 AssetTagNum1 DIMM Synchronous DDR-SDRAM 256MB/64 @ 333Mt/s
CHANNEL A DIMM1 - J5G2 : Empty
CHANNEL B DIMM2 - J5H1 : Manufacturer3 PartNum3 SerNum3 AssetTagNum3 DIMM Synchronous DDR-SDRAM 256MB/64 @ 333Mt/s
CHANNEL B DIMM3 - J5H2 : Empty
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 4x 133MHz (532MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 200MHz / 2x 200MHz
Width : 64-bit
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.50
Number of Ports : 3
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.5-4-4-7CL 1CMD
Channels : 2
Speed : 2x 166MHz (332MHz data rate)
Multiplier : 5/4x
Width : 64-bit
Refresh Rate : 7.80µs
Performance Acceleration Technology : Yes
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
AGP Bus(es) on Hub 1
Version : 3.00
Speed : 8x
Multiplier : 1/2x
Fast-Writes Enabled : Yes
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
Aperture Size : 128MB
PCI Bus(es) on Hub 1
Version : 2.20
Number of Bridges : 2
PCI Bus 0 : PCI (1x PCIClk)
PCI Bus 2 : PCI (1x PCIClk)
LPC Hub Controller 1
Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Random Number Generator Support : Yes
Delayed Transaction Enabled : Yes
USB Controller 1
Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : Intel Corporation 82801EB/ER (ICH4/ICH5R) USB EHCI Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
FireWire/1394 Controller 1
Model : Intel Corporation FW322/323 IEEE1394 OHCI FireWire Controller
Version : 1.00
Interface : OHCI
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : SMBus Dev Drv 1
Slave Device Enabled : No
Expansion Slot(s)
J5C1 (1h) : AGP-4x 32-bit +3.3V Full-Length Used
J6B2 (2h) : PCI 32-bit +3.3V PME i2c/SMBus Full-Length Available
J6B1 (3h) : PCI 32-bit +3.3V PME i2c/SMBus Full-Length Used
J7B1 (4h) : PCI 32-bit +3.3V PME i2c/SMBus Full-Length Used
J8B2 (5h) : PCI 32-bit +3.3V PME i2c/SMBus Full-Length Available
J8B1 (6h) : PCI 32-bit +3.3V PME i2c/SMBus Full-Length Available
Port Connector
J1A1 - PS2Mouse : Mouse - None / PS/2
J1A1 - Keyboard : Keyboard - None / PS/2
J2A1 - COM 1 : Serial Port 16550A - None / DB-9 pin female
J4A2 - LPT1 : Parallel Port ECP/EPP - None / DB-25 pin male
JA5A1 - USB : USB - None / USB
J9E1 - FireWire : FireWire/1394 - None / None
J2A2 - USB : USB - None / USB
JA5A1 - RJ-45 Type : Network - None / RJ-45
J4A1 - Audio Mic In : Audio - None / Mini-jack
J4A1 - Audio Line In : Audio - None / Mini-jack
J4A1 - Audio Line Out : Audio - None / Mini-jack
J4B1 - +12V : None - None / None
J3J1 - FDD : None - Floppy Disk / None
J5J2 - PRI IDE : None - ATA / None
J5J1 - SEC IDE : None - ATA / None
J9B2 - CDIN : Audio - CD-ROM Sound Input / None
J9B1 - AUX IN : Audio - None / None
J8J1 - FRONT PANEL HDR : None - None / None
J1F2 - CPU FAN : None - None / None
J9H3 - FNT PNL : None - None / None
J6J2 - FRONT CHASSIS FAN : None - None / None
J5B1 - REAR CHASSIS FAN : None - None / None
J7H2 - BIOS CONFIG : None - None / None
J8A1 - FP AUDIO : None - Proprietary / None
J7F1 - FRONT PANEL USB : None - None / None
J2J1 - PS : None - None / None
J6J3 - CH INTR : None - None / None
J9D1 - FireWire : None - None / None
J9E1 - FireWire : None - None / None
J7H1 - SATA-0 : None - None / None
J6H1 - SATA-1 : None - None / None
Here arre the tips Sandra gave me for this board:
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
______________________________________________________
Memory
Int Buffered iSSE2 (Integer STREAM) Results Breakdown
Assignment : 3089MB/s
Scaling : 3098MB/s
Addition : 3243MB/s
Triad : 3261MB/s
Data Item Size : 16-bytes
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 75% (estimated)
Float Buffered iSSE2 (Float STREAM) Results Breakdown
Assignment : 3121MB/s
Scaling : 3109MB/s
Addition : 3298MB/s
Triad : 3301MB/s
Test Status
Memory Used by Test : 255MB
NUMA Support : No
SMP Test : No
Total Test Threads : 1
SMT Test : No
Dynamic MP/MT Load Balance : No
Processor Affinity : No
Chipset 1
Width : 64-bit
Maximum Bus Bandwidth : 4256MB/s (estimated)
Channels : 2
Width : 64-bit
Maximum Memory Bus Bandwidth : 5312MB/s (estimated)
Features
As you can see from this picture Sandra is really giving me a low score compared to systems that I should be matching or surpasing.
I just don't think that my ram should be running at 333MHz.
heres the specs:
Processor
Speed : 2.79GHz
Type : Standard
Multiplier : 21/1x
Generation : G7
Stepping Mask : C1
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Upgradeability
Socket/Slot : J2E1
Features
Advanced Settings
Fast Strings : Yes
Mainboard
MPS Version : 1.40
Model : D865PERL
On-board Devices
Chipset 1
Width : 64-bit
Version : 1.50
Number of Ports : 3
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Channels : 2
Multiplier : 5/4x
Width : 64-bit
APIC 1
Version : 2.00
Multiplier : 1/2x
Version : 3.00
Speed : 8x
Multiplier : 1/2x
Version : 2.20
USB Controller 1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Version : 2.00
Interface : EHCI
Channels : 8
Version : 1.00
Interface : OHCI
Channels : 64
Speed : 400MHz
Expansion Slot(s)
Port Connector
Performance Tips
Memory
Scaling : 3098MB/s
Addition : 3243MB/s
Triad : 3261MB/s
Scaling : 3109MB/s
Addition : 3298MB/s
Triad : 3301MB/s
Test Status
NUMA Support : No
SMP Test : No
SMT Test : No
Chipset 1
Width : 64-bit
Channels : 2
Width : 64-bit
Features
