- Aug 15, 2002
- Stanwood, WA
Subject pretty self explan....
lyle said:I think they spelled Shin-Etsu wrong, they put a "N" in where they should have put a "T".
Mastametz said:looks like i gonna go as3....n e know any good sites that sell it or anything?
InThrees said:Ok, the real answer is that there isn't any one thermal grease that costs so much that you would just never buy it.
There also really isn't any one thermal grease that performs so poorly that you just shouldn't buy it.
In thermal grease, the application is much more important than the brand. A poor application of AS3 will perform much more poorly than a great application of stock white gunk. A great application of AS3 will perform a tiny bit better than white gunk.
That said, for peace of mind, get the AS3 if it's convenient. However, if you're sitting next to a tube / packet of white gunk or whatever came with your HSF, use it, and have peace of mind. In the end, the temp differences are likely to be less than 1 degree C.
