- Jun 1, 2003
- Ashland, KY
My fiance is allowing me to use her vintage Fisher speakers. But they are so old that the papers and rubber around the subs are dry-rotted. So I am looking to buy just some replacements. I DO NOT need 300w RMS or anything like that, but something identical to the speakers that are already installed.
The subs I am looking at right now are these Golds from partexpress.com
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-346
My receiver is driving all my large speakers and it cannot handle any more.
Now here is a scan of the exact stats of these speakers:
This low frequency general-purpose woofer is ideal for the customer who is looking for an inexpensive replacement driver. Each woofer features a treated ribbed paper cone, vented pole piece, moisture resistant poly foam surround, and stamped steel frame. This woofer features a larger 40 oz. magnet for more cone control and tighter bass.
Specifications: *Power handling: 150 watts RMS/300 watts max *VCdia: 1-1/2" *Le: .93 mH *Impedance: 8 ohms *Re: 7.2 ohms *Frequency range: 20-2,500 Hz *Fs: 29 Hz *SPL: 90 dB 2.83V/1m *Vas: 9.69 cu. ft. *Qms: 5.07 *Qes: 1.29 *Qts: 1.03 *Xmax: 3.5mm *Dimensions: A: 15", B: 13-3/4", C: 5-1/2".
