- Apr 10, 2012
- Ontario, Canada
So my Noctua D14 140mm fan started making clicking noises. Sometimes it will get louder, sometimes it's not so bad. But you can definitely hear it all the time.
Anyway I have some old Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fans lying around and I was considering putting them in the D14. I also have two 1450RPM AP-15's that are currently acting as case intake fans.
Which fans should I go with? Or should I just go buy another Noctua 140mm fan with the 120mm mounting holes?
