- Jul 1, 2001
I currently run an overclocked DLT3C 1700+ in a Chieftec case, Alpha PAL8045 heatsink with a Elanvital 8cm fan (link). According to specs, it's a 44CFM at 31dBA.
Since I'll be getting an AXP-M soon and summer is approaching, I'm considering to invest in some new cooling gears, probably a new HSF for my CPU. Is it worth it upgrade from PAL8045 to a Thermalright? Shall I replace my 8cm fan as well? How much of a difference will it make?
Also, what're the differences between SLK-800U, SLK-900U and SLK-947U? My board has the mounting holes, so they should fit no problem.
Thanks in advance.
Thanks in advance.
