- Dec 12, 2004
- Hanover Park, IL
TBH I'm sick and tired of having a new case and rig every time I build a computer. Sure, it's fun, but it's really expensive. Rather than 1 or 2 years down the road thinking to myself "you know I could easily go higher end with my water cooling, and then I'd be able to overclock more..." I'd rather blow the cooling out of the water so-to-speak and get it all over with with an extremely intense rig.
I don't think being a beginner to custom rigs will be affected by whether I use 2 radiators or 4. Having to set up the radiator is a task I'll learn to do, and having to do it 2 times or 4 times is not going to make a difference to my inexperience.
The choice is, of course, yours. But understand, a 2-loop cooler, with the right fans\pumps\blocks is going to be able to strangle whatever you throw at it.
Actually, being a beginner will complicate things a bit for you. Unless you're a truly singular individual who can get everything perfect on the first try, there is going to be a learning curve, and along with it some regrets. Remember, I'm not trying to talk you out of anything here, only express an opinion based on the components you mentioned.
