- Nov 6, 2003
- Rochester, Michigan
Ok here is the deal, I'll start from the begining. I got my 165 a few months ago and all was well. Temps were really good. Stock Heatsink and fan got me up to 2.6 fully stable and 2.7 partialy. Temps we about 27c idle and about 42c load if I remember correctly without checking my logs. This is with th stock fan on it. So I decided to put a new fan on it to see what I could get. I put a 120mm smart fan on it with a 80-120 adapter. Temps went down. At night with the window open it would turn the fan off cause it would get below 25c and dip as low as 22c. Now I dont have a temp probe the check it but it was very very cool to the touch and the air being blown around the heatsink and fan when it was just slightly above 25c was the coolest I have felt in a case. And the load was in the high 30's some times 40c if the room temp was a little higher.
Now here is where it gets odd atleast for me. I bought a AC Freezer 64 pro for like 15 on sale and wanted to try it out. It a big thing with a bunch of heat pipes. So I lapped the sink before I put it on and got a pretty good finish on it(atleast for me being my first time) and put it on and tested it out. First thing I noticed was the temps jumped about 10c. So at first I was like well thats odd but maybe its the as5 and it needs to settle in and the temnps will drop. But then after a day or 2 I knew something was up as i have never seen a big drop in temps with as5 settleing in after a week or 2. Maybe a 2-3 degree drop, and that is about it. So I reseated it to make sure all was well and still the same temps. I decided to lapp my stock heasink while I was waiting for the temps to drop after putting the new sink on the first time. I got a better finish on the stock HS then I did on the freezer. Made sure no wobbles in it with the graph thing I d/led, and tossed it on and made sure it was seated well. Still the same temps 38c idle and high 40's sometime 50c. This way way hotter than it use to be. I didnt damage the core or the board as I was carefull to remove and put it back in. I've done this enough times to know how carefull to be. But I can't understand why I would get this jump in temps like this. Its been week and a half since I put the stock lapped HS back in so there has been enough time for the as5 to settle in. I got maybe a 1-2c drop at idle but that maybe because of room temps.
I have the ac on and its rather cool in the room. The coolest I've seen it at idle now is 34-35 and that is when its chilly in the room. Any suggestions or reason why this would be? Lapping is suppose to drop temps. Even if its only a degree or 2. But now its jumping up 10 or more? Im so frustrated and need help.
Thanks guys.
Thanks guys.
