Running my 6700XT at 6800 speed?
kyle2227
Hello!
Does anyone have any idea what specs I would need to hit to have my 6700XT run at close to a 6800?
I am currently running at Memory 2150 - with the minimum and maximum clock speeds set at 2750/2850.
I got to those speeds with only a small amount of effort so I am thinking I could easily push higher.
Ran AID64 for 1.5 hours with 0 issues at those settings.
The card I have is
XFX - Speedster QICK319 AMD Radeon RX 6700 XT
You can't come even close to the RX6800, just because RX6800 has a wider memory bus and more ROPs, which gives quite a lot in some games. OC of all these cards is about 5-7% while the base difference between both cards is more like 15%+ without additional OC so you will still miss ~10%.
2700-2800MHz core and 2150 memory are about the max you can make. Most higher series RX6000 have 2600MHz+ core and probably all have 2000MHz memory so there is not so big headroom for OC.
