- May 15, 2006
As many of you know, I rarely have to resort to creating a thread asking for help. I've been smashing my face on my desk for the past few days trying to get it to work. Let me lay out some information.
This is for my file server, the operating system is CentOS 5.0 (2.6.18-128.1.14.el5). I'm using Windows XP 64bit boxes to connect to the server via SAMBA. I'm trying to share out my RAID 5 array on my Dell Perc 5 controller (7tb RAID5) using the EXT3 filesystem with a 4096 block size that is mounted to "/share/hitachi". I finally got the filesystem ironed out, so that is working.
The issue I'm having is with SAMBA itself combined with permissions. I have a folder (/share/hitachi) that is used as the "base" share. I created two folders, "Media" and "Backups" inside the /share/hitachi folder. I then mapped those two folders to each station (along with the /share/hitachi itself only on my computer, no one else can access that share). There are two users, "thideras" and "skep" which are non-admins on the server and pretty much can't do anything except access that folder. They are both in the group "networkdrives", which I created thinking it would help with this, maybe it will.
If I create a folder from my computer (user "thideras"), I can not rename/delete or modify anything in that folder from a computer using the user "skep". If I go into the server and reset the permissions to 777 (recursively), it fixes the issue temporarily. That also works vise versa, if "skep" creates a folder, I have no permissions to change/modify the folder or its contents.
Below is my smb.conf file.
Basically, I'm looking for a way to give us both full access to the network share if we are logged in as either user (they use the username/password combos from the Windows box, no login prompts that way). I know that I can change the "security" to "share", but I'd like to keep my security much higher than that. As you can see in the "backups" section, I gave the group "networkdrives" the "valid users" flag, it yields the same result except that I can now rename the other user's folder; I can not, however create or modify anything in the folder itself.
I'm fairly fluent in Linux, I know my way around and I know how to look for help. I've poured over tons of SAMBA guides along with security, permissions, users, groups and anything that I find relevant. I just can't seem to grasp the concept here, I'm stuck in "Windows land". All I know is that I'm doing something wrong here.
Help?
Code:
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# For a step to step guide on installing, configuring and using samba,
# read the Samba-HOWTO-Collection. This may be obtained from:
# http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
# Many working examples of smb.conf files can be found in the
# Samba-Guide which is generated daily and can be downloaded from:
# http://www.samba.org/samba/docs/Samba-Guide.pdf
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
# SELINUX NOTES:
# If you want to use the useradd/groupadd family of binaries please run:
# setsebool -P samba_domain_controller on
# If you want to share home directories via samba please run:
# setsebool -P samba_enable_home_dirs on
# If you create a new directory you want to share you should mark it as
# "samba-share_t" so that selinux will let you write into it.
# Make sure not to do that on system directories as they may already have
# been marked with othe SELinux labels.
# Use ls -ldZ /path to see which context a directory has
# Set labels only on directories you created!
# To set a label use the following: chcon -t samba_share_t /path
# If you need to share a system created directory you can use one of the
# following (read-only/read-write):
# setsebool -P samba_export_all_ro on
# or
# setsebool -P samba_export_all_rw on
# If you want to run scripts (preexec/root prexec/print command/...) please
# put them into the /var/lib/samba/scripts directory so that smbd will be
# allowed to run them.
# Make sure you COPY them and not MOVE them so that the right SELinux context
# is applied, to check all is ok use restorecon -R -v /var/lib/samba/scripts
#======================= Global Settings =====================================
[global]
# ----------------------- Network Related Options -------------------------
# workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
# server string is the equivalent of the NT Description field
# netbios name can be used to specify a server name not tied to the hostname
# Interfaces lets you configure Samba to use multiple interfaces
# If you have multiple network interfaces then you can list the ones
# you want to listen on (never omit localhost)
# Hosts Allow/Hosts Deny lets you restrict who can connect, and you can
# specifiy it as a per share option as well
workgroup = SONGAHM
server string = Samba Server Version %v
; netbios name = MYSERVER
; interfaces = lo eth0 192.168.12.2/24 192.168.13.2/24
; hosts allow = 127. 192.168.12. 192.168.13.
# --------------------------- Logging Options -----------------------------
# Log File let you specify where to put logs and how to split them up.
# Max Log Size let you specify the max size log files should reach
# logs split per machine
; log file = /var/log/samba/%m.log
# max 50KB per log file, then rotate
; max log size = 50
# ----------------------- Standalone Server Options ------------------------
# Security can be set to user, share(deprecated) or server(deprecated)
# Backend to store user information in. New installations should
# use either tdbsam or ldapsam. smbpasswd is available for backwards
# compatibility. tdbsam requires no further configuration.
security = user
passdb backend = smbpasswd
# ----------------------- Domain Members Options ------------------------
# Security must be set to domain or ads
# Use the realm option only with security = ads
# Specifies the Active Directory realm the host is part of
# Use password server option only with security = server or if you can't
# use the DNS to locate Domain Controllers
# The argument list may include:
# password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# or to auto-locate the domain controller/s
# password server = *
; security = domain
; passdb backend = tdbsam
; realm = MY_REALM
; password server = <NT-Server-Name>
# ----------------------- Domain Controller Options ------------------------
# Security must be set to user for domain controllers
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
# Domain Logons let Samba be a domain logon server for Windows workstations.
# Logon Scrpit let yuou specify a script to be run at login time on the client
# You need to provide it in a share called NETLOGON
# Logon Path let you specify where user profiles are stored (UNC path)
# Various scripts can be used on a domain controller or stand-alone
# machine to add or delete corresponding unix accounts
; security = user
; domain master = yes
; domain logons = yes
# the login script name depends on the machine name
; logon script = %m.bat
# the login script name depends on the unix user used
; logon script = %u.bat
; logon path = \\%L\Profiles\%u
# disables profiles support by specifing an empty path
; logon path =
; add user script = /usr/sbin/useradd "%u" -n -g users
; add group script = /usr/sbin/groupadd "%g"
; add machine script = /usr/sbin/useradd -n -c "Workstation (%u)" -M -d /nohome -s /bin/false "%u"
; delete user script = /usr/sbin/userdel "%u"
; delete user from group script = /usr/sbin/userdel "%u" "%g"
; delete group script = /usr/sbin/groupdel "%g"
# ----------------------- Browser Control Options ----------------------------
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
; local master = no
; os level = 33
; preferred master = yes
#----------------------------- Name Resolution -------------------------------
# Windows Internet Name Serving Support Section:
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
# - WINS Support: Tells the NMBD component of Samba to enable it's WINS Server
# - WINS Server: Tells the NMBD components of Samba to be a WINS Client
# - WINS Proxy: Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one WINS Server on the network. The default is NO.
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups.
; wins support = yes
; wins server = w.x.y.z
; wins proxy = yes
; dns proxy = yes
# --------------------------- Printing Options -----------------------------
# Load Printers let you load automatically the list of printers rather
# than setting them up individually
# Cups Options let you pass the cups libs custom options, setting it to raw
# for example will let you use drivers on your Windows clients
# Printcap Name let you specify an alternative printcap file
# You can choose a non default printing system using the Printing option
load printers = yes
cups options = raw
; printcap name = /etc/printcap
#obtain list of printers automatically on SystemV
; printcap name = lpstat
; printing = cups
# --------------------------- Filesystem Options ---------------------------
# The following options can be uncommented if the filesystem supports
# Extended Attributes and they are enabled (usually by the mount option
# user_xattr). Thess options will let the admin store the DOS attributes
# in an EA and make samba not mess with the permission bits.
# Note: these options can also be set just per share, setting them in global
# makes them the default for all shares
; map archive = no
; map hidden = no
; map read only = no
; map system = no
; store dos attributes = yes
#============================ Share Definitions ==============================
;[homes]
; comment = Home Directories
; browseable = no
; writable = yes
; valid users = %S
; valid users = MYDOMAIN\%S
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
guest ok = no
writable = no
printable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /var/lib/samba/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
; [Profiles]
; path = /var/lib/samba/profiles
; browseable = no
; guest ok = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
[hitachi]
comment = Hitachi
path = /share/hitachi
public = yes
writable = yes
printable = no
valid users = thideras
[media]
comment = Media
path = /share/hitachi/Media
public = yes
writable = yes
printable = no
valid users = thideras, skep
[backups]
comment = Backups
path = /share/hitachi/Backups
public = yes
writable = yes
printable = no
valid users = @networkdrives
Help?
