- Jul 30, 2014
Hi all,
I have a Samsung laptop that I am trying to get going again.
The laptop will power on only for a few seconds before turning off right away.
The above issue happens both when trying to turn on via battery power and when plugged in at a power source.
Sometimes I am able to get it to boot up and it might work pefectly for that day or it will freeze, I go to reboot the laptop then it does the near instant shut off thing after a few seconds.
So far have checked its not;
My question is, Can I failing/dying bio battery cause this?
If not what tools would I need to get so I can check the motherboard to pin point where the failure is? (Never done this before so this will be a first time thing).
Need to get this back up and working so I can return it to my folks.
Cheers,
Bandit.
- Ram related
- CPU fan
- HDD
- All connections have been pulled out and put back in
- Battery works properly
- DVD Drive
Cheers,
Bandit.
