Hi,
"SetFSB for GA-8IEXP Ultra Version 1.4d" supported ASUS P4B266/P4B533/P4PE.
http://www.page.sannet.ne.jp/k-hazama/other/setfsb/setfsbU14d_8iexp.zip
Notes
1.GIVEIO.SYS
IF you use SetFSB by WindowsNT4/2000/XP,
You must put "GIVEIO.SYS" in your SetFSB dir.
GIVEIO can be received from here.
http://www.ddj.com/ftp/1996/1996.05/directio.zip
2.Supported Command Line options. (-x,-X,/x,/X)
-w[00-99] : Wait [sec] (default)=10sec
-s[000-999] : Set FSB [MHz]
-m[0-9] : Mode (0:default)=normal , 1=ultra
-i[00-99] : Increment [MHz] (0:default)=max
You need to run it each time the computer starts.
That's what makes the command line switches so cool.
I have a shortcut in my startup folder that looks like the following:
Example : Wait=5sec, Mode=(0:default), Set FSB=150MHz, Increment=5MHz
"C:\Program Files\setfsbU14d_8iexp\SetFSBu_8IEXP.exe" -w05 -s150 -i05
Japanese http://www.page.sannet.ne.jp/k-hazama/setfsb_command.htm
3.SetFSB(s) can be downloaded from here.
Japanese(latest) http://www.page.sannet.ne.jp/k-hazama/software.htm
English http://www.maximumoc.com/setfsb.html
Thanks-abo333
Notes
1.GIVEIO.SYS
Thanks-abo333
