- Mar 9, 2001
- Sandpoint, ID.
I am finally upgrading from my 4 year old mobo - Abit Kt7-A v.1.0. Crazy, huh. Anyway, I just purchased an NF7-S v.2.0 from Newegg, along with 1 stick of Corsair XMS pc3200 (2-2-2-6), 512mb. I have a Tbred B XP 2100+, JUIHB running at 2100mhz (21x100) stable on air (way old WBK 38 hs/f, 42c max).
I have been reading up on the NF7-S v.2.0, and decided to go with it because of all the support, mods, discussion forums, and success others have found with it. I have a few questions about setting things up.
1. What BIOS should I use? I have seen over 50 different modded BIOS files, and not much explaination for what each of them do.
2. Should I do the L12 wire mod upon initial installation, or first try a BIOS with a L12 soft mod? I really dont like messing with my CPU, especially after I get the Arctic Silver 5 spread just right.
3. With plenty of case fans, as well as an aftermarket NB hs/f, what are my options for increasing the chipset voltage. In really old mod reviews, they talk about hardware mods, which looks pretty sketchy for me, since I am not skilled at soldering. Are higher voltage settings available through modded BIOS files?
Any additional "do's" / "dont's" would be appreciated.
Thanks!
Thanks!
