- Mar 10, 2011
- at Q8400 on GA-EP45T-UD3LR
Hi OC Team.. my name is h4mz
this is my first post in this forum..
i need suggest to setting my GA-EP45T-UD3LR with corsair CMX4GX3M2A1600C9
my problem
when i use 2 RAM sticks on slot 0 and 2 its no problem
when i use 4 RAM sticks on slot 0-1-2-3 my installed operating system go die (7 ultimate get BSOD), my ubuntu goes freeze
i don't know howto and about setting RAM in bios so i really need help on this forum
my specs like these
my last settings looks like this
with the latest settings, my box just cannot boot, event in BIOS, so i unplugged 3 power cable 2 from HDD and 1 Optical drive and it is still can not boot, so i reset the bios finally boot..
now my system running with 3 sticks RAM on flex interleaved mode
please anyone to suggest me the right settings because now i think im going crazy.. overclocking is fun, but i absolutely have no basic and experience on overclocking the PC.
please.. can anyone suggest me the correct settings?
my problem
my specs like these
Code:
Motherboard GA-EP45T-UD3LR Rev 1.0
Processor Intel Core2Quad Q8400
Memory CMX4GX3M2A1600C9
Video Card # 1 GeForce 9400 GT
Hard Drive # 1 SEAGATE 250GB ST3250318AS FOR OS
Hard Drive # 2 SEAGATE 1TB ST31000528AS
Hard Drive # 3 SEAGATE 2TB ST2000DL003-9VT166
Optical Drive # 1 SAMSUNG TSSTcorp CDDVDW SH-S223B
Power Supply SIMBADDA 500W
Case SIM X
Sound Card OnBoard ALC888
Monitor SAMSUNG SyncMaster 740N
Operating System 64bit ubuntu 10.04.1, macOSX 10.6.6(hackintosh)
Flash Drive NEXUS-8GB
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 7X
Fine CPU Clock Ratio.....................:.+0.5
CPU Frequency ...........................: 2.5GHz (333x7.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 333Mhz
PCI Express Frequency (Mhz) .........: 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800mV
PCI Express Clock Drive.................: 800mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance...................: [Standard]
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: Auto
Memory Frequency (Mhz) ..............: 1333 ->changed
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................ 9
tRCD ................................... 9
tRP'.................................... 9
tRAS.................................... 24
Advanced Timing Control
tRRD.......................................... 4 Auto
tWTR.......................................... 4 Auto
tWR........................................... 8 Auto
tRFC.......................................... 60 Auto
tRTP.......................................... 4 Auto
Command Rate (CMD) ........................... 2 Auto ->changed
Driving Strength Profiles
Driving Strength ............................
Channel A
Static tRead Value.........................:8 Auto
tRD Phase0 Adjustment...................: 0 Auto
tRD Phase1 Adjustment...................:0 Auto
tRD Phase2 Adjustment .................:0 Auto
tRD Phase3 Adjustment..................:0 Auto
Trd2rd(Different Rank)....................:9 Auto
Twr2wr(Different Rank)...................:7 Auto
Twr2rd(Different Rank)...................:7 Auto
Trd2wr(Same/Diff Rank)..................:10 Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
DDR Write Leveling.....................:Auto
DDR Write Training.....................:Auto
Channel B
Static tRead Value.........................:9 Auto
tRD Phase0 Adjustment...................:1 Auto
tRD Phase1 Adjustment...................:1 Auto
tRD Phase2 Adjustment .................:1 Auto
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................:1.2V
CPU Termination….......................:1.2V
CPU PLL………………….........................:1.550V
CPU Reference.………….......................:0.805V
MCH/ICH
MCH Core……………........................: 1.4V -> changed
MCH Reference….…….0.760V...........; <<< Auto
ICH I/O……………….....1.550V............: <<< Auto
ICH Core…………...……1.100V............: <<< Auto
DRAM
DRAM Voltage ……......................: 1.7V
DRAM Termination .…0.750V............: <<< Auto
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: Disabled
Virtualization Technology................: Enabled
