What the hell... The 4-pin ATX 12V connector on my Silverstone Zeus 560W PSU is backwards!
I bought this PSU about a year ago specifically for the fact that it would work with my old mobo (Asus A7N8X) which had a 20-pin ATX connector and would work with newer mobos that require a 24 pins or a 20 and a 4 pin power connection.
Anyways here is the problem, I got my new Mobo/CPU today (AsRock 4CoreDual-VSTA and E4400) and I'm trying to install them right now, but the 4-pin ATX 12V connector is messed up. There are 4 pins in a 2 by 2 arrangement, and two of the pins are "contoured" rather than perfect squares (just like any PSU connector is). But the wrong pins are contoured! I can't plug it into the mobo because it's like trying to put a round pegs into square holes and square pegs into round holes. So I dug out my old azz Antec 300W PSU and the pins on that are contoured correctly and plug right into the mobo as they should, but my expensive, newer PSU doesn't. What gives?
I though of perhaps cutting the connector off of each PSU and connecting the one that works to my Zeus, but I'm wary of doing that, how would I know that I've got the wires in the correct orientation? I don't want to go frying my mobo or CPU... any advice?
