so either redoing my loop did something or...
Adragontattoo
Trailer Chasing Senior
Microsoft changed their little performance score system.
Need to replace the HDD to raise the overall score but my last gen WCed rig is at all 7.0 or above excluding drive transfer rates.
Last time I ran it, it was lower, much lower overall..
Code:
HWiNFO32 Version 3.51-748
WCED-STACKER --------------------------------------------------------------
 [Current Computer]
 [Operating System]
  Operating System:                       Microsoft Windows 7 Business Build 7600
Central Processor(s) ------------------------------------------------------
 [CPU Unit Count]
  Number Of Processor Packages (Physical): 1
  Number Of Processors Cores:             4
  Number Of Logical Processors:           4
Intel Core 2 Quad Q6600 ---------------------------------------------------
 [General Information]
  Processor Name:                         Intel Core 2 Quad Q6600
  Original Processor Freqency:            2400.0 MHz
  Original Processor Freqency [MHz]:      2400
  CPU ID:                                 000006FB
  CPU Brand Name:                         Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz
  CPU Vendor:                             GenuineIntel
  CPU Stepping:                           G0
  CPU Code Name:                          Kentsfield
  CPU S-Spec:                             SLACR
  CPU Thermal Design Power (TDP):         95 W
  CPU Max. Case Temperature (Tcase_max):  71 °C
  CPU Type:                               Production Unit
  CPU Platform:                           LGA775 (FC-LGA6)
  Microcode Update Revision:              B6
  Number of CPU Cores:                    4
  Number of Logical CPUs:                 4
 [Operating Points]
  CPU LFM (Minimum):                      1600.0 MHz = 6.00 x 266.7 MHz @ 1.1625 V
  CPU HFM (Maximum):                      2400.0 MHz = 9.00 x 266.7 MHz @ 1.2625 V [Locked]
  CPU Current:                            3424.4 MHz = 9.00 x 380.5 MHz @ 1.2625 V
  CPU Bus Type:                           FSB (QDR)
 [Cache and TLB]
  L1 Cache:                               Instruction: 32 KBytes, Data: 32 KBytes
  L2 Cache:                               Integrated: 2 x 4 MBytes
  Instruction TLB:                        4 KB Pages, 4-way set associative, 128 entries
  Data TLB:                               4 MB Pages, 4-way set associative, 32 entries
 [Standard Feature Flags]
  FPU on Chip                             Present
  Enhanced Virtual-86 Mode                Present
  I/O Breakpoints                         Present
  Page Size Extensions                    Present
  Time Stamp Counter                      Present
  Pentium-style Model Specific Registers  Present
  Physical Address Extension              Present
  Machine Check Exception                 Present
  CMPXCHG8B Instruction                   Present
  APIC On Chip / PGE (AMD)                Present
  Fast System Call                        Present
  Memory Type Range Registers             Present
  Page Global Feature                     Present
  Machine Check Architecture              Present
  CMOV Instruction                        Present
  Page Attribute Table                    Present
  36-bit Page Size Extensions             Present
  Processor Number                        Not Present
  CLFLUSH Instruction                     Present
  Debug Trace and EMON Store              Present
  Internal ACPI Support                   Present
  MMX Technology                          Present
  Fast FP Save/Restore (IA MMX-2)         Present
  Streaming SIMD Extensions               Present
  Streaming SIMD Extensions 2             Present
  Self-Snoop                              Present
  Multi-Threading Capable                 Present
  Automatic Clock Control                 Present
  IA-64 Processor                         Not Present
  Signal Break on FERR                    Present
  Streaming SIMD Extensions 3             Present
  Carryless Multiplication (PCLMULQDQ)/GFMUL Not Present
  64-Bit Debug Store                      Present
  MONITOR/MWAIT Support                   Present
  CPL Qualified Debug Store               Present
  Virtual Machine Extensions              Present
  Safer Mode Extensions (Intel TXT)       Not Present
  Thermal Monitor 2                       Present
  Supplemental Streaming SIMD Extensions 3 Present
  Enhanced SpeedStep Technology           Present
  L1 Context ID                           Not Present
  Segment Limit Checking                  Not Present
  CMPXCHG16B Support                      Present
  Send Task Priority Messages Disabling   Present
  Performance/Debug Capability MSR        Present
  Processor Context ID                    Not Present
  Direct Cache Access                     Not Present
  Streaming SIMD Extensions 4.1           Not Present
  Streaming SIMD Extensions 4.2           Not Present
  Extended xAPIC                          Not Present
  MOVBE Instruction                       Not Present
  POPCNT Instruction                      Not Present
  TSC-deadline Timer                      Not Present
  AES Cryptography Support                Not Present
  XSAVE/XRSTOR/XSETBV/XGETBV Instructions Not Present
  XGETBV/XSETBV OS Enabled                Not Present
  AVX Support                             Not Present
 [Extended Feature Flags]
  64-bit Extensions                       Present
  No Execute                              Present
  SYSCALL/SYSRET Support                  Not Present
  RDTSCP and TSC_AUX Support              Not Present
 [Enhanced Features]
  Thermal Monitor 1:                      Supported, Disabled
  Thermal Monitor 2:                      Supported, Disabled
  Enhanced Intel SpeedStep (GV3):         Supported, Enabled
  Bi-directional PROCHOT#:                N/A
  Extended Auto-HALT State C1E:           N/A
  Extended Stop Grant State C2E:          N/A
  Enhanced Halt State C3E:                N/A
  Enhanced Halt State C4E:                N/A
  Enhanced Halt State Hard C4E:           N/A
  Hardware Prefetcher:                    Supported, Enabled
  DCU Prefetcher:                         Supported, Enabled
  IP Prefetcher:                          Supported, Enabled
  Adjacent Cache Line Prefetch:           Supported, Enabled
  MLC Streamer Prefetcher                 Not Supported
  MLC Spatial Prefetcher                  Not Supported
  DCU Streamer Prefetcher                 Not Supported
  DCU IP Prefetcher                       Not Supported
  Intel Dynamic Acceleration (IDA) Technology: Not Supported
  Intel Dynamic FSB Switching:            Not Supported
  Enhanced Multi Threaded Thermal Management: N/A
  Intel Turbo Boost Technology:           Not Supported
  Programmabe Ratio Limits:               Not Supported
  Programmabe TDC/TDP Limits:             Not Supported
 [Memory Ranges]
  Maximum Pysical Address Size:           36-bit (64 GBytes)
  Maximum Virtual Address Size:           48-bit (256 TBytes)
 [MTRRs]
  Range 0-80000000 (0MB-2048MB) Type:     Write Back (WB)
  Range 80000000-A0000000 (2048MB-2560MB) Type: Write Back (WB)
  Range 9FF00000-A0000000 (2559MB-2560MB) Type: Uncacheable (UC)
  Range 100000000-200000000 (4096MB-8192MB) Type: Write Back (WB)
  Range 200000000-240000000 (8192MB-9216MB) Type: Write Back (WB)
  Range 240000000-260000000 (9216MB-9728MB) Type: Write Back (WB)
Motherboard ---------------------------------------------------------------
 [Computer]
 [Motherboard]
  Motherboard Model:                       EVGA 132-CK-NF78
  Motherboard Chipset:                    nVidia nForce 780i SLI (C55) + MCP55P(XE)
  Motherboard Slots:                      2xPCI, 1xPCI Express x8, 3xPCI Express x16
 [BIOS]
  Super-IO/LPC Chip:                      Winbond/Nuvoton W83627DHG
  Trusted Platform Module (TPM) Chip:     Not Found
ACPI Devices --------------------------------------------------------------
ACPI Fixed Feature Button -------------------------------------------------
Intel Processor -----------------------------------------------------------
NVIDIA nForce RAID Controller ---------------------------------------------
 [Assigned Resources]
 [Alternative 1]
Programmable interrupt controller -----------------------------------------
 [Alternative 1]
System timer --------------------------------------------------------------
 [Alternative 1]
High precision event timer ------------------------------------------------
 [Alternative 1]
Direct memory access controller -------------------------------------------
 [Alternative 1]
Standard PS/2 Keyboard ----------------------------------------------------
 [Alternative 1]
System speaker ------------------------------------------------------------
 [Alternative 1]
PCI bus -------------------------------------------------------------------
 [Alternative 1]
System CMOS/real time clock -----------------------------------------------
 [Alternative 1]
System board --------------------------------------------------------------
 [Alternative 1]
Motherboard resources -----------------------------------------------------
 [Alternative 1]
 [Alternative 1]
 [Alternative 1]
 [Alternative 1]
Numeric data processor ----------------------------------------------------
 [Alternative 1]
ACPI Power Button ---------------------------------------------------------
Microsoft PS/2 Port Mouse (IntelliPoint) ----------------------------------
 [Alternative 1]
SMBIOS DMI ----------------------------------------------------------------
BIOS ----------------------------------------------------------------------
  BIOS Vendor:                            Phoenix Technologies, LTD
  BIOS Version:                             P08
  BIOS Release Date:                      09/09/2008
  BIOS Start Segment:                     E000
  BIOS Size:                              512 KBytes
  ISA Support:                            Present
  MCA Support:                            Not Present
  EISA Support:                           Not Present
  PCI Support:                            Present
  PC Card (PCMCIA) Support:               Not Present
  Plug-and-Play Support:                  Present
  APM Support:                            Present
  Flash BIOS:                             Present
  BIOS Shadow:                            Present
  VL-VESA Support:                        Not Present
  ESCD Support:                           Not Present
  Boot from CD:                           Present
  Selectable Boot:                        Present
  BIOS ROM Socketed:                      Present
  Boot from PC Card:                      Not Present
  EDD Support:                            Present
  NEC PC-98 Support:                      Not Present
  ACPI Support:                           Present
  USB Legacy Support:                     Present
  AGP Support:                            Not Present
  I2O Boot Support:                       Not Present
  LS-120 Boot Support:                    Present
  ATAPI ZIP Drive Boot Support:           Present
  IEE1394 Boot Support:                   Not Present
  Smart Battery Support:                  Not Present
System --------------------------------------------------------------------
  System Manufacturer:                     EVGA
  Product Name:                           132-CK-NF78
  Product Version:                        2
  Product Serial Number:                  1
  UUID:                                   {5AD1EC74-4B16-0004-0000-000000000000}
  SKU Number:
  Family:
Mainboard -----------------------------------------------------------------
  Mainboard Manufacturer:                  EVGA
  Mainboard Name:                         132-CK-NF78
  Mainboard Version:                      2
  Mainboard Serial Number:                1
System Enclosure ----------------------------------------------------------
  Manufacturer:                            EVGA
  Case Type:                              Desktop
  Version:                                132-CK-NF78
  Serial Number:
  Asset Tag Number:
Processor -----------------------------------------------------------------
  Processor Manufacturer:                 Intel
  Processor Version:                      Intel(R) Core(TM)2 Quad CPU
  External Clock:                         380 MHz
  Maximum Clock Supported:                200 MHz
  Current Clock:                          3420 MHz
  CPU Socket:                             Populated
  CPU Status:                             Enabled
  Processor Type:                         Central Processor
  Processor Voltage:                      1.7 V
  Processor Upgrade:                      ZIF
  Socket Designation:                     Socket 775
Memory Devices ------------------------------------------------------------
Memory Controller ---------------------------------------------------------
  Error Detecting Method:                 None
  Error Correction:                       None
  Supported Interleave:                   1-Way
  Current Interleave:                     1-Way
  Max. Memory Module Size:                32 MBytes
  Supported Memory Speed:                 70 ns, 60 ns
  Supported Memory Type:                  SPM, EDO
  Supported Memory Voltage:               5 V
  Associated Memory Slots:                4
A0 ------------------------------------------------------------------------
  Socket Designation:                     A0
  Memory Type:
  Memory Speed:                           Unknown
  Installed size:                         2048 MBytes
  Enabled size:                           2048 MBytes
A1 ------------------------------------------------------------------------
  Socket Designation:                     A1
  Memory Type:
A2 ------------------------------------------------------------------------
  Socket Designation:                     A2
  Memory Type:
A3 ------------------------------------------------------------------------
  Socket Designation:                     A3
  Memory Type:
Internal Cache ------------------------------------------------------------
  Socket Designation:                     Internal Cache
  Cache State:                            Enabled
  Cache Type:                             Internal, Instruction
  Cache Scheme:                           Write-Back
  Supported SRAM Type:                    Synchronous
  Current SRAM Type:                      Synchronous
  Cache Speed:                            Unknown
  Error Correction Type:                  Unknown
  Maximum Cache Size:                     32 KBytes
  Installed Cache Size:                   32 KBytes
  Cache Associativity:                    8-way Set-Associative
External Cache ------------------------------------------------------------
  Socket Designation:                     External Cache
  Cache Type:                             External, Unified
  Maximum Cache Size:                     4096 KBytes
  Installed Cache Size:                   4096 KBytes
Port Connectors -----------------------------------------------------------
Port Connector ------------------------------------------------------------
  Port Type:                              Unknown
  Internal Reference:                     PRIMARY IDE
  Internal Connector Type:                On Board IDE
  External Reference:                     Unknown
  External Connector Type:                None
8251 FIFO Compatible ------------------------------------------------------
  Port Type:                              8251 FIFO Compatible
  Internal Reference:                     FDD
  Internal Connector Type:                On Board Floppy
Serial Port 16450 Compatible ----------------------------------------------
  Port Type:                              Serial Port 16450 Compatible
  Internal Reference:                     COM1
  Internal Connector Type:                9 Pin Dual Inline (pin 10 cut)
  External Reference:
  External Connector Type:                DB-9 pin male
Keyboard Port -------------------------------------------------------------
  Port Type:                              Keyboard Port
  Internal Reference:                     Keyboard
  Internal Connector Type:                PS/2
  External Reference:
  External Connector Type:                PS/2
Mouse Port ----------------------------------------------------------------
  Port Type:                              Mouse Port
  Internal Reference:                     PS/2 Mouse
  External Reference:
USB -----------------------------------------------------------------------
  Port Type:                              USB
  Internal Reference:                     Unknown
  Internal Connector Type:                None
  External Reference:                     USB0
  External Connector Type:                Unknown
  Port Type:                              USB
  External Reference:                     USB1
  Port Type:                              USB
  External Reference:                     USB2
  Port Type:                              USB
  External Reference:                     USB3
  Port Type:                              USB
  External Reference:                     USB4
  Port Type:                              USB
  External Reference:                     USB5
System Slots --------------------------------------------------------------
PCI0 ----------------------------------------------------------------------
  Slot Designation:                       PCI0
  Slot Type:                              PCI
  Slot Usage:                             In use
  Slot Data Bus Width:                    32-bit
  Slot Length:                            Long
PCI1 ----------------------------------------------------------------------
  Slot Designation:                       PCI1
  Slot Type:                              PCI
  Slot Usage:                             Empty
  Slot Length:                            Long
BIOS Language -------------------------------------------------------------
Physical Memory Array -----------------------------------------------------
  Array Location:                         System board
  Array Use:                              System memory
  Memory Capacity:                        2097152 KBytes
  Memory Devices:                         4
Memory Device -------------------------------------------------------------
  Total Width:                            128 bits
  Data Width:                             128 bits
  Device Size:                            2048 MBytes
  Device Form Factor:                     DIMM
  Device Locator:                         A0
  Bank Locator:                           Bank0/1
  Device Type:                            DRAM
  Device Type Detail:
  Memory Speed:                           761 MHz
  Manufacturer:                           None
  Serial Number:                          None
  Part Number:                            None
  Asset Tag:                              None
  Device Locator:                         A1
  Bank Locator:                           Bank2/3
  Device Type:                            DRAM
  Device Type Detail:
  Manufacturer:                           None
  Serial Number:                          None
  Part Number:                            None
  Asset Tag:                              None
  Device Locator:                         A2
  Bank Locator:                           Bank4/5
  Device Type:                            DRAM
  Device Type Detail:
  Manufacturer:                           None
  Serial Number:                          None
  Part Number:                            None
  Asset Tag:                              None
  Device Locator:                         A3
  Bank Locator:                           Bank6/7
  Device Type:                            DRAM
  Device Type Detail:
  Manufacturer:                           None
  Serial Number:                          None
  Part Number:                            None
  Asset Tag:                              None
Memory Array Mapped Address -----------------------------------------------
  Starting Address:                       00000000
  Ending Address:                         007FFFFF
  Partition Width:                        1
Memory Device Mapped Address ----------------------------------------------
  Ending Address:                         001FFFFF
  Partition Row Position:                 1
  Interleave Position:                    Non-interleaved
  Interleave Data Depth:                  0
  Starting Address:                       00200000
  Ending Address:                         003FFFFF
  Starting Address:                       00400000
  Ending Address:                         005FFFFF
  Starting Address:                       00600000
System Boot Information ---------------------------------------------------
  Boot Status:                            No error occured
Memory --------------------------------------------------------------------
 [General information]
  Total Memory Size:                      8 GBytes
  Total Memory Size [MB]:                 8192
 [Current Performance Settings]
  Current Memory Clock:                   380.5 MHz (1 : 1 ratio)
  Current Timing (tCAS-tRCD-tRP-tRAS):    5.0-5-5-15
  Memory Runs At:                         Dual-Channel
  Command Rate:                           2T
  Read to Write Delay (tRD_WR) Same Rank: 5T
  Write to Read Delay (tWR_RD) Same Rank (tWTR): 9T
  Read to Precharge Delay (tRTP):         3T
  Write to Precharge Delay (tWTP/tWR):    12T
  RAS# to RAS# Delay (tRRD):              3T
  Four Activate Window (tFAW):            14T
Row: 0 - 2048 MB PC2-6400 DDR2-SDRAM G Skill F2-6400CL4-2GBPI-B -----------
 [General Module Information]
  Module Number:                          0
  Module Size:                            2048 MBytes
  Memory Type:                            DDR2-SDRAM
  DIMM Type:                              Regular Unbuffered (UDIMM)
  Error Check/Correction:                 None
  Memory Speed:                           400.0 MHz (PC2-6400)
  Module Manufacturer:                    G Skill
  Module Model:                           F2-6400CL4-2GBPI-B
  Serial Number:                          N/A
  Manufacturing Date:                     N/A
 [Module characteristics]
  Module Width:                           64-bits
  Module Voltage:                         SSTL 1.8V
  SPD Revision:                           1.2
  Number Of Ranks:                        2
  Row Address Bits:                       14
  Column Address Bits:                    10
  Number Of Banks:                        8
 [Module timing]
  Supported Burst Lengths:                4, 8
  Refresh Rate:                           Reduced 0.5x (7.8 us)
  Supported CAS Latencies (tCAS):         5.0, 4.0, 3.0
  Min. RAS-to-CAS Delay (tRCD):           12.50 ns
  Min. Row Precharge Time (tRP):          12.50 ns
  Min. RAS Pulse Width (tRAS):            37 ns
  Supported Module Timing at 400.0 MHz:   5.0-5-5-15
  Supported Module Timing at 266.7 MHz:   4.0-4-4-10
  Supported Module Timing at 200.0 MHz:   3.0-3-3-8
  Min. Row-Activate To Row-Activate Delay (tRRD): 7.50 ns
  Write Recovery Time (tWR):              15.00 ns
  Internal write to read command delay (tWTR): 7.50 ns
  Internal read to precharge command delay (tRTP): 7.50 ns
  Minimum Activate to Activate/Refresh Time (tRC): 57.50 ns
  Minimum Refresh to Activate/Refresh Command Period (tRFC): 127.50 ns
  Address and Command Setup Time Before Clock (tIS): 0.17 ns
  Address and Command Setup Time After Clock (tIH): 0.25 ns
  Data Input Setup Time Before Strobe (tDS): 0.05 ns
  Data Input Setup Time After Strobe (tDH): 0.12 ns
 [Enhanced Performance Profiles]
  Optimal Performance Profile:            #0
 [Profile #0]
  Voltage Level:                          1.90 V
  Address Command Rate:                   2T
  CAS Latency:                            4
  Min. Cycle Time At Supported CAS Latency: 2.500 ns (400.0 MHz)
  Min. RAS-to-CAS Delay (tRCD):           10.00 ns
  Min. Row Precharge Time (tRP):          10.00 ns
  Min. RAS Pulse Width (tRAS):            30 ns
  Supported Module Timing at 400.0 MHz:   4.0-4-4-12
  Min. Activate to Activate/Refresh Time (tRC): 90 ns
  Write Recovery Time (tWR):              24.00 ns
  Address Drive Strength:                 1.00x
  Chip Select Drive Strength:             1.00x
  Clock Drive Strength:                   1.00x
  Data Drive Strength:                    1.00x
  DQS Drive Strength:                     1.00x
  Address/Command Fine Delay:             None
  Address/Command Setup Time:             1 MEMCLK
  Address/Command Fine Delay:             5/64 MEMCLKs
Row: 1 - 2048 MB PC2-6400 DDR2-SDRAM G Skill F2-6400CL4-2GBPI-B -----------
  Module Number:                          1
  Serial Number:                          N/A
  SPD Revision:                           1.2
  Number Of Ranks:                        2
  Number Of Banks:                        8
 [Module timing]
 [Profile #0]
  CAS Latency:                            4
Row: 2 - 2048 MB PC2-6400 DDR2-SDRAM G Skill F2-6400CL4-2GBPI-B -----------
  Module Number:                          2
  Serial Number:                          N/A
  SPD Revision:                           1.2
  Number Of Ranks:                        2
  Number Of Banks:                        8
 [Module timing]
 [Profile #0]
  CAS Latency:                            4
Row: 3 - 2048 MB PC2-6400 DDR2-SDRAM G Skill F2-6400CL4-2GBPI-B -----------
  Module Number:                          3
  Serial Number:                          N/A
  SPD Revision:                           1.2
  Number Of Ranks:                        2
  Number Of Banks:                        8
 [Module timing]
 [Profile #0]
  CAS Latency:                            4
Bus -----------------------------------------------------------------------
PCI Bus #0 ----------------------------------------------------------------
nVIDIA nForce 680i/780i SLI (C55) Chipset - Host Bridge -------------------
  Original Device Name:                   nVIDIA nForce 680i/780i SLI (C55) Chipset - Host Bridge
  Device Class:                           Host-to-PCI Bridge
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        0
  PCI Latency Timer:                      0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
  Bus Mastering:                          Enabled
  Running At 66 MHz:                      Capable
  Fast Back-to-Back Transactions:         Capable
nVIDIA C55 Chipset - Hypertransport Control (DLDT) ------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Hypertransport Control (DLDT)
  Device Class:                           RAM/Memory Controller
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
  Bus Mastering:                          Disabled
  Fast Back-to-Back Transactions:         Not Capable
nVIDIA C55 Chipset - Miscellaneous P4 Controller for FSB ------------------
  Original Device Name:                   nVIDIA C55 Chipset - Miscellaneous P4 Controller for FSB
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        2
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Miscellaneous Common Configuration -------------------
  Original Device Name:                   nVIDIA C55 Chipset - Miscellaneous Common Configuration
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        3
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Clock Controller -------------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Clock Controller
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        4
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller ------------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        5
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Hypertransport Control (DLDT2) -----------------------
  Original Device Name:                   nVIDIA C55 Chipset - Hypertransport Control (DLDT2)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        6
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller (Misc Pads) ------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller (Misc Pads)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        7
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller 2 ----------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller 2
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller (CPURR) ----------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller (CPURR)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        2
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory I/O Controller --------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory I/O Controller
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        3
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller (PAD CAL) --------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller (PAD CAL)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        4
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory Controller (SSO) ------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory Controller (SSO)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        5
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory I/O Controller 2 ------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory I/O Controller 2
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          1
  Function Number:                        6
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - ECC Memory Controller --------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - ECC Memory Controller
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          2
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Clock Controller 2 -----------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Clock Controller 2
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          2
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - Memory I/O Controller 3 ------------------------------
  Original Device Name:                   nVIDIA C55 Chipset - Memory I/O Controller 3
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          2
  Function Number:                        2
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA C55 Chipset - PCI Express Bridge (x16) -----------------------------
  Original Device Name:                   nVIDIA C55 Chipset - PCI Express Bridge (x16)
  Device Class:                           PCI-to-PCI Bridge
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          3
  Function Number:                        0
 [PCI Express]
  Version:                                1.0
  Maximum Link Width:                     16x
  Current Link Width:                     16x
  Maximum Link Speed:                     2.5 Gb/s
  Current Link Speed:                     2.5 Gb/s
  Device/Port Type:                       Root Port of PCI Express Root Complex
  Slot Implemented:                       Yes
  Hot-Plug:                               Not Capable
  Hot-Plug Surprise:                      Not Capable
  Active State Power Management (ASPM) Support: L0s Entry
  Active State Power Management (ASPM) Status: Disabled
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
  Running At 66 MHz:                      Not Capable
PCI Express x16 Bus #1 ----------------------------------------------------
nVIDIA nForce 200 (BR04) 32-Lane PCI Express 2.0 Switch -------------------
  Original Device Name:                   nVIDIA nForce 200 (BR04) 32-Lane PCI Express 2.0 Switch
  Revision ID:                            A2
  Bus Number:                             1
  Device Number:                          0
  Function Number:                        0
 [PCI Express]
  Version:                                2.0
  Maximum Link Speed:                     5.0 Gb/s
  Device/Port Type:                       Upstream Port of PCI Express Switch
  Slot Implemented:                       No
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI Express x16 Bus #2 ----------------------------------------------------
  Revision ID:                            A2
  Bus Number:                             2
  Device Number:                          0
  Function Number:                        0
 [PCI Express]
  Version:                                2.0
  Current Link Speed:                     5.0 Gb/s
  Device/Port Type:                       Downstream Port of PCI Express Switch
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI Express x16 Bus #3 ----------------------------------------------------
EVGA e-GeForce 9800 GTX+ --------------------------------------------------
  Original Device Name:                   nVIDIA GeForce 9800 GTX+ (G92)
  Device Class:                           VGA Compatible Adapter
  Revision ID:                            A2
  Bus Number:                             3
  Device Number:                          0
  Function Number:                        0
 [PCI Express]
  Version:                                2.0
  Device/Port Type:                       PCI Express Endpoint
  Active State Power Management (ASPM) Support: L0s and L1 Entry
 [System Resources]
  Interrupt Line:                         IRQ16
  Interrupt Pin:                          INTA#
  Memory Base Address 0                   CA000000
  Memory Base Address 1                   A0000000
  Memory Base Address 3                   C8000000
  I/O Base Address 5                      9C00
 [Features]
  Revision ID:                            A2
  Bus Number:                             2
  Device Number:                          2
  Function Number:                        0
 [PCI Express]
  Version:                                2.0
  Current Link Width:                     8x
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI Express x16 Bus #4 ----------------------------------------------------
Intel 80333 Segment-A PCI Express-to-PCI-X Bridge -------------------------
  Original Device Name:                   Intel 80333 Segment-A PCI Express-to-PCI-X Bridge
  Revision ID:                            0
  Bus Number:                             4
  Device Number:                          0
  Function Number:                        0
  PCI-X Mode:                             PCI-X 266
 [PCI Express]
  Version:                                1.0
  Maximum Link Width:                     8x
  Device/Port Type:                       PCI Express-to-PCI/PCI-X Bridge
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI-X 266 Bus #5 ----------------------------------------------------------
DELL PERC 5/i Integrated RAID Controller ----------------------------------
  Original Device Name:                   DELL PERC 5 Family RAID Controller
  Device Class:                           RAID controller
  Revision ID:                            0
  Bus Number:                             5
  Device Number:                          14
  Function Number:                        0
  PCI Latency Timer:                      32
  PCI-X Mode:                             PCI-X 66
 [System Resources]
  Memory Base Address 0                   BFFF0000
  Memory Base Address 2                   CDFC0000
 [Features]
Intel 80333 Segment-B PCI Express-to-PCI-X Bridge -------------------------
  Original Device Name:                   Intel 80333 Segment-B PCI Express-to-PCI-X Bridge
  Revision ID:                            0
  Bus Number:                             4
  Device Number:                          0
  Function Number:                        2
 [PCI Express]
  Version:                                1.0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI-X 266 Bus #6 ----------------------------------------------------------
nVIDIA MCP55 - Host Bridge (Upstream HyperTransport Controller) -----------
  Original Device Name:                   nVIDIA MCP55 - Host Bridge (Upstream HyperTransport Controller)
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          9
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
nVIDIA MCP55P(XE) - LPC Bridge --------------------------------------------
  Original Device Name:                   nVIDIA MCP55P(XE) - LPC Bridge
  Device Class:                           PCI-to-ISA Bridge
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          10
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
  I/O Base Address 0                      FC00
 [Features]
nVIDIA MCP55 - SMBus Controller -------------------------------------------
  Original Device Name:                   nVIDIA MCP55 - SMBus Controller
  Device Class:                           SMBus (System Management Bus)
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          10
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         N/A
  I/O Base Address 0                      F800
  I/O Base Address 4                      F400
  I/O Base Address 5                      F000
 [Features]
nVIDIA MCP55 - USB 1.1 OHCI Controller ------------------------------------
  Original Device Name:                   nVIDIA MCP55 - USB 1.1 OHCI Controller
  Device Class:                           Universal Serial Bus (USB)
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          11
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         IRQ23
  Memory Base Address 0                   CFFFF000
 [Features]
nVIDIA MCP55 - USB 2.0 EHCI Controller ------------------------------------
  Original Device Name:                   nVIDIA MCP55 - USB 2.0 EHCI Controller
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          11
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         IRQ22
  Interrupt Pin:                          INTB#
  Memory Base Address 0                   CFFFE000
 [Features]
nVIDIA MCP55 - IDE Controller ---------------------------------------------
  Original Device Name:                   nVIDIA MCP55 - IDE Controller
  Device Class:                           IDE Controller
  Revision ID:                            A1
  Bus Number:                             0
  Device Number:                          13
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
  I/O Base Address 4                      EC00
 [Features]
nVIDIA MCP55 - SATA Controller --------------------------------------------
  Original Device Name:                   nVIDIA MCP55 - SATA Controller
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          14
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         IRQ20
  I/O Base Address 0                      9F0
  I/O Base Address 1                      BF0
  I/O Base Address 2                      970
  I/O Base Address 3                      B70
  I/O Base Address 4                      D800
  Memory Base Address 5                   CFFFD000
 [Features]
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          14
  Function Number:                        1
 [System Resources]
  Interrupt Line:                         IRQ21
  I/O Base Address 0                      9E0
  I/O Base Address 1                      BE0
  I/O Base Address 2                      960
  I/O Base Address 3                      B60
  I/O Base Address 4                      C400
  Memory Base Address 5                   CFFFC000
 [Features]
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          14
  Function Number:                        2
 [System Resources]
  Interrupt Pin:                          INTC#
  I/O Base Address 0                      C000
  I/O Base Address 1                      BC00
  I/O Base Address 2                      B800
  I/O Base Address 3                      B400
  I/O Base Address 4                      B000
  Memory Base Address 5                   CFFFB000
 [Features]
nVIDIA MCP55 - PCI-to-PCI Bridge ------------------------------------------
  Original Device Name:                   nVIDIA MCP55 - PCI-to-PCI Bridge
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          15
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI Bus #7 ----------------------------------------------------------------
Razer Barracuda AC-1 Gaming Audio Card ------------------------------------
  Original Device Name:                   C-Media Electronics CMI8788 Audio Chip
  Device Class:                           Multimedia Audio Adapter
  Revision ID:                            0
  Bus Number:                             7
  Device Number:                          10
  Function Number:                        0
 [System Resources]
  Interrupt Line:                         IRQ18
  I/O Base Address 0                      8C00
 [Features]
nVIDIA MCP55 - High Definition Audio Controller ---------------------------
  Original Device Name:                   nVIDIA MCP55 - High Definition Audio Controller
  Device Class:                           Mixed mode device
  Revision ID:                            A2
  Bus Number:                             0
  Device Number:                          15
  Function Number:                        1
 [System Resources]
  Memory Base Address 0                   CFFF0000
 [Features]
nVIDIA MCP55 - Network Bus Enumerator -------------------------------------
  Original Device Name:                   nVIDIA MCP55 - Network Bus Enumerator
  Device Class:                           Unknown Bridge
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          17
  Function Number:                        0
 [System Resources]
  Memory Base Address 0                   CFFFA000
  I/O Base Address 1                      0
  Memory Base Address 2                   CFFF9000
  Memory Base Address 3                   CFFF8000
 [Features]
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          18
  Function Number:                        0
 [System Resources]
  Memory Base Address 0                   CFFF7000
  Memory Base Address 2                   CFFF6000
  Memory Base Address 3                   CFFF5000
 [Features]
nVIDIA MCP55 - PCI Express Root Port (X8 + VC1) ---------------------------
  Original Device Name:                   nVIDIA MCP55 - PCI Express Root Port (X8 + VC1)
  Revision ID:                            A3
  Bus Number:                             0
  Device Number:                          19
  Function Number:                        0
 [PCI Express]
  Version:                                1.0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
PCI Express x8 Bus #8 -----------------------------------------------------
Video Adapter -------------------------------------------------------------
nVIDIA GeForce 9800 GTX+ (G92) --------------------------------------------
 [Video chipset]
  Video Chipset:                          nVIDIA GeForce 9800 GTX+ (G92)
  Video Memory:                           512 MBytes of GDDR3 SDRAM
 [Video Card]
  Video Card:                             EVGA e-GeForce 9800 GTX+
  Video Bus:                              PCIe v2.0 x16 (5.0 Gb/s) @ x16 (5.0 Gb/s)
  Video BIOS Version:                     62.92.64.00.80
  Video Chipset Revision:                 A2
 [Performance]
  Geometry Unit Clock:                    756.0 MHz
  Shader Unit Clock:                      1836.0 MHz
  Memory Clock:                           1123.2 MHz (Effective 2246.4 MHz)
  Memory Bus Width:                       256-bit
  Number Of Pixel Pipelines:              16
  Number Of Unified Shaders:              128
Monitor -------------------------------------------------------------------
SyncMaster    -------------------------------------------------------------
  Monitor Name:                           SyncMaster
  Serial Number:                          1162228275
  Date Of Manufacture:                    Week: 45, Year: 2009
  Max. Vertical Size:                     9 cm
  Max. Horizontal Size:                   16 cm
  Horizontal Frequency:                   27 - 81 kHz
  Vertical Frequency:                     50 - 60 Hz
  Maximum Pixel Clock:                    170 MHz
 [Advanced parameters]
  Input Signal:                           Digital
  Display Type:                           RGB color
  Gamma Factor:                           2.20
 [DPMS Modes]
  Standby:                                Not Supported
  Suspend:                                Not Supported
  Active Off:                             Supported
  Standard Colour Space:                  Not Supported
  Preferred Timing Mode:                  Supported
  Default GTF Supported:                  Not Supported
  DFP 1.x Compatible:                     No
 [Supported Video Modes]
  1600 x 1200                             60 Hz
  1280 x 1024                             60 Hz
  1280 x 960                              60 Hz
  1280 x 800                              60 Hz
  1440 x 900                              60 Hz
  1680 x 1050                             60 Hz
  1920 x 1080                             160 x 90 mm, Pixel Clock 148.50 MHz
  1280 x 720                              160 x 90 mm, Pixel Clock 74.25 MHz
L2220HW       -------------------------------------------------------------
  Monitor Name:                           L2220HW
  Serial Number:                          5870K84701848
  Date Of Manufacture:                    Week: 47, Year: 2008
  Max. Vertical Size:                     29 cm
  Max. Horizontal Size:                   50 cm
  Horizontal Frequency:                   31 - 82 kHz
  Vertical Frequency:                     56 - 76 Hz
  Maximum Pixel Clock:                    160 MHz
  Gamma Factor:                           2.20
 [DPMS Modes]
  Standby:                                Supported
  Suspend:                                Supported
  1280 x 1024                             60 Hz
  1440 x 900                              60 Hz
  1600 x 1200                             60 Hz
  1680 x 1050                             60 Hz
  1920 x 1080                             497 x 292 mm, Pixel Clock 148.50 MHz
Drives --------------------------------------------------------------------
Floppy Drives -------------------------------------------------------------
(S)ATA/ATAPI Drives -------------------------------------------------------
WDC WD1600JS-22MHB0 -------------------------------------------------------
  Drive Controller:                       Serial ATA 3Gb/s
  Drive Model:                            WDC WD1600JS-22MHB0
  Drive Revision:                         02.01C03
  Drive Serial Number:                    WD-WCANM4667539
  Drive Capacity:                         152,627 MBytes (160 GB)
  Drive Capacity [MB]:                    152627
 [Drive Geometry]
  Number of Cylinders:                    16383
  Number of Heads:                        16
  Sectors Per Track:                      63
  Bytes Per Sector:                       Unknown
  Bytes Per Track:                        Unknown
  Number Of ECC Bytes:                    50
  Number of Sectors:                      16514064
  Total 32-bit LBA Sectors:               268435455
  Total 48-bit LBA Sectors:               312581808
  Cache Buffer Size:                      8192 KBytes
  Controller Type:                        Not Specified
 [Transfer Modes]
  Sectors Per Interrupt:                  Total: 16, Active: 16
  Max. PIO Transfer Mode:                 4
  Multiword DMA Mode:                     Total: 2, Active: -
  Singleword DMA Mode:                    Total: -, Active: -
  Ultra-DMA Mode:                         Total: 6 (ATA-133), Active: 6 (ATA-133)
  Max. Multiword DMA Transfer Rate:       16.7 MBytes/s
  Max. PIO with IORDY Transfer Rate:      16.7 MBytes/s
  Max. PIO w/o IORDY Transfer Rate:       16.7 MBytes/s
  Transfer Width:                         16-bit
  Native Command Queuing:                 Not Supported
  TRIM Command:                           Not Supported
 [Device flags]
  Fixed Drive:                            Present
  Removable Drive:                        Not Present
  Magnetic Storage:                       Present
  LBA Mode:                               Supported
  DMA Mode:                               Supported
  IORDY:                                  Supported
  IORDY Disableable:                      Supported
 [Features]
  Write Cache:                            Present, Active
  S.M.A.R.T. Feature:                     Present, Active
  Security Feature:                       Present, Inactive
  Removable Media Feature:                Not Present, Disabled
  Power Management:                       Present, Active
  Advanced Power Management:              Not Present, Inactive
  Packet Interface:                       Not Present, Disabled
  Look-Ahead Buffer:                      Present, Active
  Host Protected Area:                    Present, Enabled
  Power-Up In Standby:                    Not Suppported, Inactive
  Automatic Acoustic Management:          Supported, Inactive
  48-bit LBA:                             Supported, Active
 [Self-Monitoring, Analysis and Reporting Technology]
  Raw Read Error Rate:                    200/51, Worst: 200
  Spin Up Time:                           217/21, Worst: 186 (Data = 2108)
  Start/Stop Count:                       100/Always OK, Worst: 100 (Data = 196)
  Reallocated Sector Count:               200/140, Worst: 200
  Seek Error Rate:                        200/51, Worst: 200
  Power-On Time Count:                    94/Always OK, Worst: 94 (Data = 5079)
  Spin Retry Count:                       100/51, Worst: 100
  Calibration Retry Count:                100/51, Worst: 100
  Power Cycle Count:                      100/Always OK, Worst: 100 (Data = 194)
  Airflow Temperature:                    68/45, Worst: 47 (Data = 32)
  Temperature                             115/Always OK, Worst: 94 (Data = 32.0 °C)
  Reallocation Event Count:               200/Always OK, Worst: 200
  Current Pending Sector Count:           200/Always OK, Worst: 200
  Off-Line Uncorrectable Sector Count:    200/Always OK, Worst: 200
  Ultra ATA CRC Error Rate:               200/Always OK, Worst: 200
  Write Error Rate:                       200/51, Worst: 200
  Drive Serial Number:                    WD-WCANM4493731
  Drive Capacity:                         152,626 MBytes (160 GB)
  Drive Capacity [MB]:                    152626
 [Drive Geometry]
  Number of Heads:                        16
  Total 48-bit LBA Sectors:               312579695
 [Transfer Modes]
 [Device flags]
  LBA Mode:                               Supported
  DMA Mode:                               Supported
  IORDY:                                  Supported
 [Features]
  Spin Up Time:                           206/21, Worst: 186 (Data = 2683)
  Start/Stop Count:                       100/Always OK, Worst: 100 (Data = 185)
  Power-On Time Count:                    94/Always OK, Worst: 94 (Data = 4483)
  Power Cycle Count:                      100/Always OK, Worst: 100 (Data = 181)
  Airflow Temperature:                    60/45, Worst: 56 (Data = 40)
  Temperature                             107/Always OK, Worst: 103 (Data = 40.0 °C)
  Ultra ATA CRC Error Rate:               200/Always OK, Worst: 200 (Data = 1)
PIONEER DVD-RW  DVR-110D --------------------------------------------------
  Drive Model:                            PIONEER DVD-RW  DVR-110D
  Drive Revision:                         1.17
  Serial Number:                          EJDL432798WL
  Device Type:                            DVD+R DL
 [Device capabilities]
  Drive can read:                         CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
  Drive can write:                        CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
DELL PERC 5/i -------------------------------------------------------------
  Drive Model:                            DELL PERC 5/i
  Drive Revision:                         1.03
  Device Type:                            Disk drive
  RAID  DummyDevice -------------------------------------------------------
  Drive Model:                              RAID  DummyDevice
  Drive Revision:                         0001
  Device Type:                            Unknown device
Audio ---------------------------------------------------------------------
Sensors -------------------------------------------------------------------
 [CPU Digital Thermal Sensor]
  CPU#0 Core0                             29.0 °C
  CPU#0 Core1                             29.0 °C
  CPU#0 Core2                             22.0 °C
  CPU#0 Core3                             22.0 °C
 [Winbond/Nuvoton W83627DHG]
  Motherboard                             3.0 °C
  CPU                                     34.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2721 RPM
 [nVidia SPP]
  SPP Temperature                         47.5 °C
 [S.M.A.R.T.]
  WDC WD1600JS-22MHB0                     32.0 °C
  WDC WD1600JS-22MHB0                     40.0 °C
 [nVidia On-die @ GPU[#0] nVIDIA GeForce 9800 GTX+ (G92)]
  GPU Temperature                         33.8 °C
  GPU Fan                                 34.000 %
 [NVAPI @ GPU[#0] nVIDIA GeForce 9800 GTX+ (G92)]
  GPU Temperature                         31.0 °C
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  Motherboard                             1.0 °C
  CPU                                     30.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2721 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Temperature                         33.7 °C
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2678 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Temperature                         33.6 °C
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2766 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2721 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Temperature                         33.5 °C
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2766 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2766 RPM
  System                                  2678 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2766 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2636 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.5 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2766 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Fan                                 34.000 %
  CPU#0 Core0                             23.0 °C
  CPU#0 Core1                             23.0 °C
  CPU#0 Core2                             21.0 °C
  CPU#0 Core3                             21.0 °C
  CPU                                     29.0 °C
  Auxiliary                               33.5 °C
  Vcore                                   1.440 V
  Vccp2                                   2.992 V
  +3.3V                                   3.232 V
  +3.3V                                   3.232 V
  +5V                                     4.176 V
  VIN5                                    3.168 V
  VIN6                                    3.648 V
  3VSB                                    3.232 V
  VBAT                                    3.024 V
  CPU1                                    2812 RPM
  System                                  2678 RPM
 [nVidia SPP]
 [S.M.A.R.T.]
  GPU Temperature                         33.9 °C
  GPU Fan                                 34.000 %
Not to be blunt here, but that is a hell of a lot of scrolling for system information. I might have missed it, but I don't know what your score is...
To answer the thread title, I don't think changing a loop can affect performance, but you never know...
I know that most on here (OCF) don't think to highly of WEI. If it means a lot to you, post a screeny of the WEI screen for comparison.
If it was cpu, you lowered/raised your clock or changed another cpu related setting (FSB). If it was ram, I would point to timings. Graphics, I would say driver change and you excluded the hard drive.
:shrug::shrug::shrug::shrug::shrug:
Ohhh... That's all? Well was it possibly because of
Ram is set to stock speeds.
No drivers changed (if it works and there isnt a drastic change, why break something)
Only change between the two runs is time and a loop redo.
Ahh well either way, doesnt really matter as the windows score means as much to me as synthetic benchmarks do to real life.
Well come to think of it, I had a similar type thing. I ran the bench a while ago and my graphics was a 7. I reran it after I installed on my SSD and got a 6. I'm pretty sure it was switching from 196.18 to the newest drivers though. :shrug:
