glock19owner said:
LOL so you were lying about teh C&Q crashing and locking up
glock19owner said:
Super Nade said:For the record, I can't boot with CnQ enabled, if I'm OC'd at about 2580MHz.
Say even at 234 x 11.
Sentential said:Thats because CNC boots to default of 1ghz reguardless. So if you raise the FSB it will attempt to default to the multi of 5X with whatever FSB you have with 1.0v.
For most winchesters that can handle as high as 1.5ghz before they start ****ing up from undervolting. Ive done it before but my FSB has to stay under 250 otherwise its unstable as hell.
gvblake22 said:So what seems to be the "Athlon XP-M IQYHA" of the Winchesters? Anything??
Seems like it is definately not CBBID...
DAMN! I figured there was a magic stepping out there somewhere, but at least 2.7 on air for CBBHD!glock19owner said:CBBHD If possible...find a later 04...earlier 05's are not doing as well...
0444 - 0447's seem to do on average between 2.7 - 2.9 on air...some have hit slightly over 3G's...
Yeah, I am definately aware of the performance advantage of the A64 architecture as well as the 90nm process, but my bank account is trying to make me forget!glock19owner said:And also take into account...with a A64...2.75 would be that of a Mobile running at 3+Ghz ...the A64's are around 15% faster then the XP's in 32bit programs...
gvblake22 said:but my bank account is trying to make me forget!
Super Nade said:The reason I ask is because effective implimentation of CnQ depends on the motherboard maker. The technology is supported by the CPU, but the MoBo maker is the one who needs to implement it correctly.
j3lly said:@glock19owner
one person says to keep under 250 HTT to be stable another says its unstable with 234 HTT
glock19owner said:Now why would I want to drop in HTT to run C&Q...if you have to drop in HT to run C&Q...does this not mean that in some way that it does and will hamper the OC...
And you have 1 persons that got a good result while almost everyone else disables it because it hurtst their top OC...
Also...if this was a OC friendly option and does increase the OC...then why do the top OCers disable it...dont you think they would want every Mhz the CPU will give for there benchmark runs?
hi_its_ryan said:all i know is that at 250 i am now stable, but i crash while loading windows with CnQ at the same clocks and settings
j3lly said:LOL who the hell is telling you to drop youre HTT?
what does youre teh stupib idiotical HTT has to do with anything?
where're teh links where they told you C&Q hampers OC???
http://www.ocforums.com/showthread.php?p=3491061#post3491061
j3lly said:C&Q has nothing to do with HTT.
Lon3R said:sry but C&Q help an OC , rofl nothing more but to laugh at
glock19owner said:Show the Proof that CnQ physically helps a OC...I can show a lot of post where they all say it hampers...including myself...just re-read a few of my post...
And not a thread where 1 or 2 people out of 20 gets a good result...
Better yet...lets see Both of your specs...show me that either one of you can hit 2.75+ with CnQ enabled...and not for 5 mintues
