- Jun 11, 2014
after some bsod errors, removing of ram things seem to be running better thankfully... well that is to say l havent had a bsod again since removing the older set of ram.
now l was told l had some issues with my drivers, however l want to know if lve fixed at least where usb 3.0 drivers are concerned:
where can l find the logs that would show errors like the below:
reason l ask is lve updated my Bios to the latest posted on my motherboards website and l received the following error:
and so far lve only received the error while copying content onto a usb connected drive (thumb drives and externals) which leads me to believe that my issues with teracopy may likely be linked to the fact that lm still experiencing usb 3.0 driver issues.
fffff880`035fe128 00000000`00000000
fffff880`035fe130 fffff880`05834c00Unable to load image \SystemRoot\system32\DRIVERS\iusb3hub.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for iusb3hub.sys
*** ERROR: Module load completed but symbols could not be loaded for iusb3hub.sys
iusb3hub+0x34c00
fffff880`035fe138 fffff880`05802147 iusb3hub+0x2147
fffff880`035fe140 fffffa80`144a4700
fffff880`035ff528 00000000`00000000
fffff880`035ff530 fffff880`04f6ade0Unable to load image \SystemRoot\system32\DRIVERS\iusb3xhc.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for iusb3xhc.sys
*** ERROR: Module load completed but symbols could not be loaded for iusb3xhc.sys
iusb3xhc+0x6bde0
fffff880`035ff538 00000000`000003e7
fffff880`035ff540 fffff880`04f79f60 iusb3xhc+0x7af60
fffff880`035ff548 00000000`00000000
fffff880`035ff550 fffffa80`1644c0b8
Faulting application name: teracopy.exe, version: 2.3.0.0, time stamp: 0x52a2ba02
Faulting module name: ntdll.dll, version: 6.1.7601.22436, time stamp: 0x521eaa80
Exception code: 0xc0000005
Fault offset: 0x00032532
Faulting process id: 0x710
Faulting application start time: 0x01cfd4875bf40e52
Faulting application path: C:\Program Files\TeraCopy\teracopy.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: a3d32145-407a-11e4-9b85-c3289d97281b
