- Nov 26, 2011
- Berkeley, CA
Hey all! Regardless of your replies, thank you for your time/thoughts!
I have this motherboard (or at least a close approximation): http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Context of use: I'm an avid gamer and I play with a pair of Sennheiser 555 headphones. Open to considering another pair but happy with them.
My sound card questions:
1. Is it worth getting a dedicated sound card? Or, perhaps a better question, how much would it cost to get a sound card that exceeds on-board sound?
2. Any links to reliable articles that discuss why/when a sound card helps game performance?
3. If you feel a card is worthwhile, any suggestions for a gaming ring sound card?
My random question:
I have a GTX 570 and three PCI express slots to put it in. Does it need to go in the first slot? I ask because the first PCI express slot puts the GPU snug up against the PCI slot. Any sound card I stick there (such as my current four-year-old Creative X-Fi card) would block the fans at least and would be practically rubbing up against the GPU.
I think I can solve this in three ways: (a) move the GPU to the second or third PCI express slot, (b) purchase a sound card that fits PCI express instead of the standard PCI, or (c) just use on-board sound.
Thoughts?
*** EDIT ***
The correct mobo link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131346
For convenience, here's a picture of the layout to clarify my n00b rambling:
My random question:
Thoughts?
*** EDIT ***
