I told them that CWShreader found the trojans this forum has not been mentioned.recieved this a few minutes ago.
These are false alerts. Just ignor them. Actually SpyStopper tries to stop these adware items and have the info in SpyStopper database. CWShreader misidentify SpyStopper as the adware. Regarding how SpyStopper works, check #19-21 in the FAQ at
http://www.itcompany.com/stopfaq.htm. Feel free to contact us if you have any question. Thanks.
Support Team
InfoWorks Technology Company
this is what the FAQ had to say.
19. My AntiVirus program reports that the SpyStopper log file, spylog.txt, is infected with CodeRed.C worm. Why?
This is a false positive. SpyStopper blocks the CodeRed worm and simply logs the actual worm data into the optional text log file. This file is not infected. The alert is false. Just ignore it. You may contact Norton or other companies and ask them to correct the false alert problem.
Also, you can delete the log file and uncheck Keep a Log File in SpyStopper. This will also eliminate the problem. However, you will not have the log file to give you the information on the blocks in the future.
The new build of SpyStopper 2.45 has corrected this problem. Uninstall your current SpyStopper. Download it and reinstall it. Check #35 for information on how to upgrade it. Make sure you delete the folder C:\Program Files\SpyStopper before reinstalling SpyStopper.
20. I got warning message from my firewall that a remote system is attempting to access SspyStopper.exe. Can you explain this behavior?
When spy servers try to contact their agents or devices on your system, SpyStopper will intercept the requests, take over the attempts, block them, and lead the contact attempts to death. This is how SpyStopper protects you. That is why your firewall thinks SpyStopper is being contacted. To remove this false alert, allow SpyStopper to access Internet in your firewall software.
21. My firewall says that sdbl.exe is attempting to access Internet. Why is it?
Many tracking devices are delivered through graphics and ads. If SpyStopper simply blocks those intrusive graphics, some Web sites (such as news sites) don’t look good. Therefore, SpyStopper loads those pictures through free public proxy servers. This way, your identity is protected and at the same time, the original appearance of the web pages is preserved. SpyStopper proxy agent, sdbl.exe, handles loading the images through free public proxy server. If you don’t like using a public proxy server and using the agent, uncheck Use Safe Loading in SpyStopper. Restart SpyStopper. Visit some sites and you will see the difference.
I am not convinced there is no mention of the trojans & why they appear each time i start spystopper, the keep log file is off my firewall lets it through,i removed temp internet files,cookies & history ran adaware 6 disconnected cable modem & they still appear BUT ONLY IF SPYSTOPPER IS ACTIVE.???
