squidguard hates me
CougarSE
I'm having issues with squidguard. It wont block anything. Now per this website http://www.maynidea.com/squidguard/faq-plus.html and going to "why isn't squid blocking anything. The first thing it says is not there!
redirect_program <path to squidGuard binary>/squidGuard -c <path to squidguard.conf>/squidguard.conf
I don't have anything in my squid.conf that looks like this. I tried putting it in there with my paths but then squid will not start :bang head
My squid.conf
Code:
#	WELCOME TO SQUID 2.6.STABLE5
#	This is the default Squid configuration file. You may wish
#	to look at the Squid home page (http://www.squid-cache.org/)
#	for the FAQ and other documentation.
#	The default Squid config file shows what the defaults for
#	various options happen to be.  If you don't need to change the
#	default, you shouldn't uncomment the line.  Doing so may cause
#	run-time problems.  In some cases "none" refers to no default
#	setting at all, while in other cases it refers to a valid
#	option - the comments for that keyword indicate if this is the
#	case.
# NETWORK OPTIONS
#  TAG: http_port
#	Usage:	port [options]
#		hostname:port [options]
#		1.2.3.4:port [options]
#	The socket addresses where Squid will listen for HTTP client
#	requests.  You may specify multiple socket addresses.
#	There are three forms: port alone, hostname with port, and
#	IP address with port.  If you specify a hostname or IP
#	address, Squid binds the socket to that specific
#	address.  This replaces the old 'tcp_incoming_address'
#	option.  Most likely, you do not need to bind to a specific
#	address, so you can use the port number alone.
#	The default port number is 3128.
#	If you are running Squid in accelerator mode, you
#	probably want to listen on port 80 also, or instead.
#	The -a command line option will override the *first* port
#	number listed here.   That option will NOT override an IP
#	address, however.
#	You may specify multiple socket addresses on multiple lines.
#	options are:
#		transparent	Support for transparent proxies
#		vhost		Accelerator using Host directive
#		vport		Accelerator with IP virtual host support
#		vport=		As above, but uses specified port number
#				rather than the http_port number.
#		defaultsite=	Main web site name for accelerators.
#		urlgroup=	Default urlgroup to mark requests
#				with (see also acl urlgroup and
#				url_rewrite_program)
#		protocol=	Protocol to reconstruct accelerated
#				requests with. Defaults to http.
#		no-connection-auth
#				Prevent forwarding of Microsoft
#				connection oriented authentication
#				(NTLM, Negotiate and Kerberos)
#		tproxy		Support Linux TPROXY for spoofing
#				outgoing connections using the client
#				IP address.
#	If you run Squid on a dual-homed machine with an internal
#	and an external interface we recommend you to specify the
#	internal address:port in http_port. This way Squid will only be
#	visible on the internal address.
# Squid normally listens to port 3128
http_port 3128
#  TAG: https_port
# Note: This option is only available if Squid is rebuilt with the
#       --enable-ssl option
#	Usage:  [ip:]port cert=certificate.pem [key=key.pem] [options...]
#	The socket address where Squid will listen for HTTPS client
#	requests.
#	This is really only useful for situations where you are running
#	squid in accelerator mode and you want to do the SSL work at the
#	accelerator level.
#	You may specify multiple socket addresses on multiple lines,
#	each with their own SSL certificate and/or options.
#	Options:
#	   defaultsite=	The name of the https site presented on
#			this port.
#	   urlgroup=	Default urlgroup to mark requests with (see
#			also acl urlgroup and url_rewrite_program)
#	   protocol=	Protocol to reconstruct accelerated requests
#			with. Defaults to https.
#	   cert=	Path to SSL certificate (PEM format)
#	   key=		Path to SSL private key file (PEM format)
#			if not specified, the certificate file is
#			assumed to be a combined certificate and
#			key file
#	   version=	The version of SSL/TLS supported
#			    1	automatic (default)
#			    2	SSLv2 only
#			    3	SSLv3 only
#			    4	TLSv1 only
#	   cipher=	Colon separated list of supported ciphers
#	   options=	Various SSL engine options. The most important
#			being:
#			    NO_SSLv2  Disallow the use of SSLv2
#			    NO_SSLv3  Disallow the use of SSLv3
#			    NO_TLSv1  Disallow the use of TLSv1
#			    SINGLE_DH_USE Always create a new key when using
#				      temporary/ephemeral DH key exchanges
#			See src/ssl_support.c or OpenSSL SSL_CTX_set_options
#			documentation for a complete list of options.
#	   clientca=	File containing the list of CAs to use when
#			requesting a client certificate
#	   cafile=	File containing additional CA certificates to
#			use when verifying client certificates. If unset
#			clientca will be used.
#	   capath=	Directory containing additional CA certificates
#			and CRL lists to use when verifying client certificates
#	   crlfile=	File of additional CRL lists to use when verifying
#			the client certificate, in addition to CRLs stored in
#			the capath. Implies VERIFY_CRL flag below.
#	   dhparams=	File containing DH parameters for temporary/ephemeral
#			DH key exchanges
#	   sslflags=	Various flags modifying the use of SSL:
#			    DELAYED_AUTH
#				Don't request client certificates
#				immediately, but wait until acl processing
#				requires a certificate (not yet implemented)
#			    NO_DEFAULT_CA
#				Don't use the default CA lists built in
#				to OpenSSL.
#			    NO_SESSION_REUSE
#				Don't allow for session reuse. Each connection
#				will result in a new SSL session.
#			    VERIFY_CRL
#				Verify CRL lists when accepting client
#				certificates
#			    VERIFY_CRL_ALL
#				Verify CRL lists for all certificates in the
#				client certificate chain
#	   sslcontext=	SSL session ID context identifier.
#Default:
# none
#  TAG: ssl_unclean_shutdown
#	Some browsers (especially MSIE) bugs out on SSL shutdown
#	messages.
#Default:
# ssl_unclean_shutdown off
#  TAG: ssl_engine
#	The OpenSSL engine to use. You will need to set this if you
#	would like to use hardware SSL acceleration for example.
#Default:
# none
#  TAG: sslproxy_client_certificate
#	Client SSL Certificate to use when proxying https:// URLs
#Default:
# none
#  TAG: sslproxy_client_key
#	Client SSL Key to use when proxying https:// URLs
#Default:
# none
#  TAG: sslproxy_version
#	SSL version level to use when proxying https:// URLs
#Default:
# sslproxy_version 1
#  TAG: sslproxy_options
#	SSL engine options to use when proxying https:// URLs
#Default:
# none
#  TAG: sslproxy_cipher
#	SSL cipher list to use when proxying https:// URLs
#Default:
# none
#  TAG: sslproxy_cafile
#  TAG: sslproxy_capath
#  TAG: sslproxy_flags
#  TAG: sslpassword_program
#	Specify a program used for entering SSL key passphrases
#	when using encrypted SSL certificate keys. If not specified
#	keys must either be unencrypted, or Squid started with the -N
#	option to allow it to query interactively for the passphrase.
#Default:
# none
#  TAG: icp_port
#	The port number where Squid sends and receives ICP queries to
#	and from neighbor caches.  Default is 3130.  To disable use
#	"0".  May be overridden with -u on the command line.
#Default:
# icp_port 3130
#  TAG: htcp_port
#	The port number where Squid sends and receives HTCP queries to
#	and from neighbor caches.  To turn it on you want to set it 4827.
#	By default it is set to "0" (disabled).
#Default:
# htcp_port 0
#  TAG: mcast_groups
#	This tag specifies a list of multicast groups which your server
#	should join to receive multicasted ICP queries.
#	NOTE!  Be very careful what you put here!  Be sure you
#	understand the difference between an ICP _query_ and an ICP
#	_reply_.  This option is to be set only if you want to RECEIVE
#	multicast queries.  Do NOT set this option to SEND multicast
#	ICP (use cache_peer for that).  ICP replies are always sent via
#	unicast, so this option does not affect whether or not you will
#	receive replies from multicast group members.
#	You must be very careful to NOT use a multicast address which
#	is already in use by another group of caches.
#	If you are unsure about multicast, please read the Multicast
#	chapter in the Squid FAQ (http://www.squid-cache.org/FAQ/).
#	Usage: mcast_groups 239.128.16.128 224.0.1.20
#	By default, Squid doesn't listen on any multicast groups.
#Default:
# none
#  TAG: udp_incoming_address
#  TAG: udp_outgoing_address
#	udp_incoming_address	is used for the ICP socket receiving packets
#				from other caches.
#	udp_outgoing_address	is used for ICP packets sent out to other
#				caches.
#	The default behavior is to not bind to any specific address.
#	A udp_incoming_address value of 0.0.0.0 indicates Squid
#	should listen for UDP messages on all available interfaces.
#	If udp_outgoing_address is set to 255.255.255.255 (the default)
#	it will use the same socket as udp_incoming_address. Only
#	change this if you want to have ICP queries sent using another
#	address than where this Squid listens for ICP queries from other
#	caches.
#	NOTE, udp_incoming_address and udp_outgoing_address can not
#	have the same value since they both use port 3130.
#Default:
# udp_incoming_address 0.0.0.0
# udp_outgoing_address 255.255.255.255
# OPTIONS WHICH AFFECT THE NEIGHBOR SELECTION ALGORITHM
#  TAG: cache_peer
#	To specify other caches in a hierarchy, use the format:
#		cache_peer hostname type http_port icp_port [options]
#	For example,
#	#                                        proxy  icp
#	#          hostname             type     port   port  options
#	cache_peer parent.foo.net       parent    3128  3130  [proxy-only]
#	cache_peer sib1.foo.net         sibling   3128  3130  [proxy-only]
#	cache_peer sib2.foo.net         sibling   3128  3130  [proxy-only]
#	      type:  either 'parent', 'sibling', or 'multicast'.
#	proxy_port:  The port number where the cache listens for proxy
#		     requests.
#	  icp_port:  Used for querying neighbor caches about
#		     objects.  To have a non-ICP neighbor
#		     specify '7' for the ICP port and make sure the
#		     neighbor machine has the UDP echo port
#		     enabled in its /etc/inetd.conf file.
#	    options: proxy-only
#		     weight=n
#		     ttl=n
#		     no-query
#		     default
#		     round-robin
#		     multicast-responder
#		     closest-only
#		     no-digest
#		     no-netdb-exchange
#		     no-delay
#		     login=user:password | PASS | *:password
#		     connect-timeout=nn
#		     digest-url=url
#		     allow-miss
#		     max-conn
#		     htcp
#		     htcp-oldsquid
#		     carp-load-factor
#		     originserver
#		     userhash
#		     sourcehash
#		     name=xxx
#		     monitorurl=url
#		     monitorsize=sizespec
#		     monitorinterval=seconds
#		     monitortimeout=seconds
#		     group=name
#		     forceddomain=name
#		     ssl
#		     sslcert=/path/to/ssl/certificate
#		     sslkey=/path/to/ssl/key
#		     sslversion=1|2|3|4
#		     sslcipher=...
#		     ssloptions=...
#		     front-end-https[=on|auto]
#		     connection-auth[=on|off|auto]
#		     use 'proxy-only' to specify objects fetched
#		     from this cache should not be saved locally.
#		     use 'weight=n' to specify a weighted parent.
#		     The weight must be an integer.  The default weight
#		     is 1, larger weights are favored more.
#		     use 'ttl=n' to specify a IP multicast TTL to use
#		     when sending an ICP queries to this address.
#		     Only useful when sending to a multicast group.
#		     Because we don't accept ICP replies from random
#		     hosts, you must configure other group members as
#		     peers with the 'multicast-responder' option below.
#		     use 'no-query' to NOT send ICP queries to this
#		     neighbor.
#		     use 'default' if this is a parent cache which can
#		     be used as a "last-resort." You should probably
#		     only use 'default' in situations where you cannot
#		     use ICP with your parent cache(s).
#		     use 'round-robin' to define a set of parents which
#		     should be used in a round-robin fashion in the
#		     absence of any ICP queries.
#		     'multicast-responder' indicates the named peer
#		     is a member of a multicast group.  ICP queries will
#		     not be sent directly to the peer, but ICP replies
#		     will be accepted from it.
#		     'closest-only' indicates that, for ICP_OP_MISS
#		     replies, we'll only forward CLOSEST_PARENT_MISSes
#		     and never FIRST_PARENT_MISSes.
#		     use 'no-digest' to NOT request cache digests from
#		     this neighbor.
#		     'no-netdb-exchange' disables requesting ICMP
#		     RTT database (NetDB) from the neighbor.
#		     use 'no-delay' to prevent access to this neighbor
#		     from influencing the delay pools.
#		     use 'login=user:password' if this is a personal/workgroup
#		     proxy and your parent requires proxy authentication.
#		     Note: The string can include URL escapes (i.e. %20 for
#		     spaces). This also means % must be written as %%.
#		     use 'login=PASS' to forward authentication to the peer.
#		     Needed if the peer requires login.
#		     Note: To combine this with local authentication the Basic
#		     authentication scheme must be used, and both servers must
#		     share the same user database as HTTP only allows for
#		     a single login (one for proxy, one for origin server).
#		     use 'login=*:password' to pass the username to the
#		     upstream cache, but with a fixed password. This is meant
#		     to be used when the peer is in another administrative
#		     domain, but it is still needed to identify each user.
#		     The star can optionally be followed by some extra
#		     information which is added to the username. This can
#		     be used to identify this proxy to the peer, similar to
#		     the login=username:password option above.
#		     use 'connect-timeout=nn' to specify a peer
#		     specific connect timeout (also see the
#		     peer_connect_timeout directive)
#		     use 'digest-url=url' to tell Squid to fetch the cache
#		     digest (if digests are enabled) for this host from
#		     the specified URL rather than the Squid default
#		     location.
#		     use 'allow-miss' to disable Squid's use of only-if-cached
#		     when forwarding requests to siblings. This is primarily
#		     useful when icp_hit_stale is used by the sibling. To
#		     extensive use of this option may result in forwarding
#		     loops, and you should avoid having two-way peerings
#		     with this option. (for example to deny peer usage on
#		     requests from peer by denying cache_peer_access if the
#		     source is a peer)
#		     use 'max-conn' to limit the amount of connections Squid
#		     may open to this peer.
#		     use 'htcp' to send HTCP, instead of ICP, queries
#		     to the neighbor.  You probably also want to
#		     set the "icp port" to 4827 instead of 3130.
#		     use 'htcp-oldsquid' to send HTCP to old Squid versions
#		     use 'carp-load-factor=f' to define a parent
#		     cache as one participating in a CARP array.
#		     The 'f' values for all CARP parents must add
#		     up to 1.0.
#		     'originserver' causes this parent peer to be contacted as
#		     a origin server. Meant to be used in accelerator setups.
#		     use 'userhash' to load-balance amongst a set of parents
#		     based on the client proxy_auth or ident username.
#		     use 'sourcehash' to load-balanse amongs a set of parents
#		     based on the client source ip.
#		     use 'name=xxx' if you have multiple peers on the same
#		     host but different ports. This name can then be used to
#		     differentiate the peers in cache_peer_access and similar
#		     directives.
#		     use 'monitorurl=url' to have periodically request a given
#		     URL from the peer, and only consider the peer as alive
#		     if this monitoring is successful (default none)
#		     use 'monitorsize=min[-max]' to limit the size range of
#		     'monitorurl' replies considered valid. Defaults to 0 to
#		     accept any size replies as valid.
#		     use 'monitorinterval=seconds' to change frequency of
#		     how often the peer is monitored with 'monitorurl'
#		     (default 300 for a 5 minute interval). If set to 0
#		     then monitoring is disabled even if a URL is defined.
#		     use 'monitortimeout=seconds' to change the timeout of
#		     'monitorurl'. Defaults to 'monitorinterval'.
#		     use 'forceddomain=name' to forcibly set the Host header
#		     of requests forwarded to this peer. Useful in accelerator
#		     setups where the server (peer) expects a certain domain
#		     name and using redirectors to feed this domain name
#		     is not feasible.
#		     use 'ssl' to indicate that connections to this peer should
#		     bs SSL/TLS encrypted.
#		     use 'sslcert=/path/to/ssl/certificate' to specify a client
#		     SSL certificate to use when connecting to this peer.
#		     use 'sslkey=/path/to/ssl/key' to specify the private SSL
#		     key corresponding to sslcert above. If 'sslkey' is not
#		     specified then 'sslcert' is assumed to reference a
#		     combined file containing both the certificate and the key.
#		     Notes:
#		     On Debian/Ubuntu system a default snakeoil certificate is
#		     available in /etc/ssl and users can set:
#		       cert=/etc/ssl/certs/ssl-cert-snakeoil.pem
#		     and
#		       key=/etc/ssl/private/ssl-cert-snakeoil.key
#		     for testing.
#		     use sslversion=1|2|3|4 to specify the SSL version to use
#		     when connecting to this peer
#			1 = automatic (default)
#			2 = SSL v2 only
#			3 = SSL v3 only
#			4 = TLS v1 only
#		     use sslcipher=... to specify the list of valid SSL ciphers
#		     to use when connecting to this peer.
#		     use ssloptions=... to specify various SSL engine options:
#		     See src/ssl_support.c or the OpenSSL documentation for
#		     a more complete list.
#		     use sslcafile=... to specify a file containing
#		     additional CA certificates to use when verifying the
#		     peer certificate.
#		     use sslcapath=... to specify a directory containing
#		     peer certificate.
#		     use sslcrlfile=... to specify a certificate revocation
#		     list file to use when verifying the peer certificate.
#		     use sslflags=... to specify various flags modifying the
#		     SSL implementation:
#			DONT_VERIFY_PEER
#				Accept certificates even if they fail to
#				verify.
#			NO_DEFAULT_CA
#				Don't use the default CA list built in
#				to OpenSSL.
#		     use ssldomain= to specify the peer name as advertised
#		     in it's certificate. Used for verifying the correctness
#		     of the received peer certificate. If not specified the
#		     peer hostname will be used.
#		     use front-end-https to enable the "Front-End-Https: On"
#		     header needed when using Squid as a SSL frontend in front
#		     of Microsoft OWA. See MS KB document Q307347 for details
#		     on this header. If set to auto then the header will
#		     only be added if the request is forwarded as a https://
#		     URL.
#		     use connection-auth=off to tell Squid that this peer does
#		     not support Microsoft connection oriented authentication,
#		     and any such challenges received from there should be
#		     ignored. Default is auto to automatically determine the
#		     status of the peer.
#	NOTE: non-ICP/HTCP neighbors must be specified as 'parent'.
#Default:
# none
#  TAG: cache_peer_domain
#	Use to limit the domains for which a neighbor cache will be
#	queried.  Usage:
#	cache_peer_domain cache-host domain [domain ...]
#	cache_peer_domain cache-host !domain
#	For example, specifying
#		cache_peer_domain parent.foo.net	.edu
#	has the effect such that UDP query packets are sent to
#	'bigserver' only when the requested object exists on a
#	server in the .edu domain.  Prefixing the domain name
#	with '!' means the cache will be queried for objects
#	NOT in that domain.
#	NOTE:	* Any number of domains may be given for a cache-host,
#		  either on the same or separate lines.
#		* When multiple domains are given for a particular
#		  cache-host, the first matched domain is applied.
#		* Cache hosts with no domain restrictions are queried
#		  for all requests.
#		* There are no defaults.
#		* There is also a 'cache_peer_access' tag in the ACL
#		  section.
#Default:
# none
#  TAG: neighbor_type_domain
#	usage: neighbor_type_domain neighbor parent|sibling domain domain ...
#	Modifying the neighbor type for specific domains is now
#	possible.  You can treat some domains differently than the the
#	default neighbor type specified on the 'cache_peer' line.
#	Normally it should only be necessary to list domains which
#	should be treated differently because the default neighbor type
#	applies for hostnames which do not match domains listed here.
#EXAMPLE:
#	cache_peer  parent cache.foo.org 3128 3130
#	neighbor_type_domain cache.foo.org sibling .com .net
#	neighbor_type_domain cache.foo.org sibling .au .de
#Default:
# none
#  TAG: icp_query_timeout	(msec)
#	Normally Squid will automatically determine an optimal ICP
#	query timeout value based on the round-trip-time of recent ICP
#	queries.  If you want to override the value determined by
#	Squid, set this 'icp_query_timeout' to a non-zero value.  This
#	value is specified in MILLISECONDS, so, to use a 2-second
#	timeout (the old default), you would write:
#		icp_query_timeout 2000
#Default:
# icp_query_timeout 0
#  TAG: maximum_icp_query_timeout	(msec)
#	Normally the ICP query timeout is determined dynamically.  But
#	sometimes it can lead to very large values (say 5 seconds).
#	Use this option to put an upper limit on the dynamic timeout
#	value.  Do NOT use this option to always use a fixed (instead
#	of a dynamic) timeout value. To set a fixed timeout see the
#	'icp_query_timeout' directive.
#Default:
# maximum_icp_query_timeout 2000
#  TAG: mcast_icp_query_timeout	(msec)
#	For multicast peers, Squid regularly sends out ICP "probes" to
#	count how many other peers are listening on the given multicast
#	address.  This value specifies how long Squid should wait to
#	count all the replies.  The default is 2000 msec, or 2
#	seconds.
#Default:
# mcast_icp_query_timeout 2000
#  TAG: dead_peer_timeout	(seconds)
#	This controls how long Squid waits to declare a peer cache
#	as "dead."  If there are no ICP replies received in this
#	amount of time, Squid will declare the peer dead and not
#	expect to receive any further ICP replies.  However, it
#	continues to send ICP queries, and will mark the peer as
#	alive upon receipt of the first subsequent ICP reply.
#	This timeout also affects when Squid expects to receive ICP
#	replies from peers.  If more than 'dead_peer' seconds have
#	passed since the last ICP reply was received, Squid will not
#	expect to receive an ICP reply on the next query.  Thus, if
#	your time between requests is greater than this timeout, you
#	will see a lot of requests sent DIRECT to origin servers
#	instead of to your parents.
#Default:
# dead_peer_timeout 10 seconds
#  TAG: hierarchy_stoplist
#	A list of words which, if found in a URL, cause the object to
#	be handled directly by this cache.  In other words, use this
#	to not query neighbor caches for certain objects.  You may
#	list this option multiple times. Note: never_direct overrides
#	this option.
#We recommend you to use at least the following line.
hierarchy_stoplist cgi-bin ?
#  TAG: cache
#	A list of ACL elements which, if matched, cause the request to
#	not be satisfied from the cache and the reply to not be cached.
#	In other words, use this to force certain objects to never be cached.
#	You must use the word 'DENY' to indicate the ACL names which should
#	NOT be cached.
#	Default is to allow all to be cached
#We recommend you to use the following two lines.
acl QUERY urlpath_regex cgi-bin \?
cache deny QUERY
#  TAG: cache_vary
#	Set to off to disable caching of Vary:in objects.
#Default:
# cache_vary on
#  TAG: broken_vary_encoding
#	Many servers have broken support for on-the-fly Content-Encoding,
#	returning the same ETag on both plain and gzip:ed variants.
#	Vary replies matching this access list will have the cache split
#	on the Accept-Encoding header of the request and not trusting the
#	ETag to be unique.
# Apache mod_gzip and mod_deflate known to be broken so don't trust
# Apache to signal ETag correctly on such responses
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
# OPTIONS WHICH AFFECT THE CACHE SIZE
#  TAG: cache_mem	(bytes)
#	NOTE: THIS PARAMETER DOES NOT SPECIFY THE MAXIMUM PROCESS SIZE.
#	IT ONLY PLACES A LIMIT ON HOW MUCH ADDITIONAL MEMORY SQUID WILL
#	USE AS A MEMORY CACHE OF OBJECTS. SQUID USES MEMORY FOR OTHER
#	THINGS AS WELL. SEE THE SQUID FAQ SECTION 8 FOR DETAILS.
#	'cache_mem' specifies the ideal amount of memory to be used
#	for:
#		* In-Transit objects
#		* Hot Objects
#		* Negative-Cached objects
#	Data for these objects are stored in 4 KB blocks.  This
#	parameter specifies the ideal upper limit on the total size of
#	4 KB blocks allocated.  In-Transit objects take the highest
#	priority.
#	In-transit objects have priority over the others.  When
#	additional space is needed for incoming data, negative-cached
#	and hot objects will be released.  In other words, the
#	negative-cached and hot objects will fill up any unused space
#	not needed for in-transit objects.
#	If circumstances require, this limit will be exceeded.
#	Specifically, if your incoming request rate requires more than
#	'cache_mem' of memory to hold in-transit objects, Squid will
#	exceed this limit to satisfy the new requests.  When the load
#	decreases, blocks will be freed until the high-water mark is
#	reached.  Thereafter, blocks will be used to store hot
#	objects.
#Default:
# cache_mem 8 MB
#  TAG: cache_swap_low	(percent, 0-100)
#  TAG: cache_swap_high	(percent, 0-100)
#	The low- and high-water marks for cache object replacement.
#	Replacement begins when the swap (disk) usage is above the
#	low-water mark and attempts to maintain utilization near the
#	low-water mark.  As swap utilization gets close to high-water
#	mark object eviction becomes more aggressive.  If utilization is
#	close to the low-water mark less replacement is done each time.
#	Defaults are 90% and 95%. If you have a large cache, 5% could be
#	hundreds of MB. If this is the case you may wish to set these
#	numbers closer together.
#Default:
# cache_swap_low 90
# cache_swap_high 95
#  TAG: maximum_object_size	(bytes)
#	Objects larger than this size will NOT be saved on disk.  The
#	value is specified in kilobytes, and the default is 4MB.  If
#	you wish to get a high BYTES hit ratio, you should probably
#	increase this (one 32 MB object hit counts for 3200 10KB
#	hits).  If you wish to increase speed more than your want to
#	save bandwidth you should leave this low.
#	NOTE: if using the LFUDA replacement policy you should increase
#	this value to maximize the byte hit rate improvement of LFUDA!
#	See replacement_policy below for a discussion of this policy.
#Default:
# maximum_object_size 4096 KB
#  TAG: minimum_object_size	(bytes)
#	Objects smaller than this size will NOT be saved on disk.  The
#	value is specified in kilobytes, and the default is 0 KB, which
#	means there is no minimum.
#Default:
# minimum_object_size 0 KB
#  TAG: maximum_object_size_in_memory	(bytes)
#	Objects greater than this size will not be attempted to kept in
#	the memory cache. This should be set high enough to keep objects
#	accessed frequently in memory to improve performance whilst low
#	enough to keep larger objects from hoarding cache_mem.
#Default:
# maximum_object_size_in_memory 8 KB
#  TAG: ipcache_size	(number of entries)
#  TAG: ipcache_low	(percent)
#  TAG: ipcache_high	(percent)
#	The size, low-, and high-water marks for the IP cache.
#Default:
# ipcache_size 1024
# ipcache_low 90
# ipcache_high 95
#  TAG: fqdncache_size	(number of entries)
#	Maximum number of FQDN cache entries.
#Default:
# fqdncache_size 1024
#  TAG: cache_replacement_policy
#	The cache replacement policy parameter determines which
#	objects are evicted (replaced) when disk space is needed.
#	    lru       : Squid's original list based LRU policy
#	    heap GDSF : Greedy-Dual Size Frequency
#	    heap LFUDA: Least Frequently Used with Dynamic Aging
#	    heap LRU  : LRU policy implemented using a heap
#	Applies to any cache_dir lines listed below this.
#	The LRU policies keeps recently referenced objects.
#	The heap GDSF policy optimizes object hit rate by keeping smaller
#	popular objects in cache so it has a better chance of getting a
#	hit.  It achieves a lower byte hit rate than LFUDA though since
#	it evicts larger (possibly popular) objects.
#	The heap LFUDA policy keeps popular objects in cache regardless of
#	their size and thus optimizes byte hit rate at the expense of
#	hit rate since one large, popular object will prevent many
#	smaller, slightly less popular objects from being cached.
#	Both policies utilize a dynamic aging mechanism that prevents
#	cache pollution that can otherwise occur with frequency-based
#	replacement policies.
#	the value of maximum_object_size above its default of 4096 KB to
#	to maximize the potential byte hit rate improvement of LFUDA.
#	For more information about the GDSF and LFUDA cache replacement
#	policies see http://www.hpl.hp.com/techreports/1999/HPL-1999-69.html
#	and http://fog.hpl.external.hp.com/techreports/98/HPL-98-173.html.
#Default:
# cache_replacement_policy lru
#  TAG: memory_replacement_policy
#	The memory replacement policy parameter determines which
#	objects are purged from memory when memory space is needed.
#	See cache_replacement_policy for details.
#Default:
# memory_replacement_policy lru
# LOGFILE PATHNAMES AND CACHE DIRECTORIES
#  TAG: cache_dir
#	Usage:
#	cache_dir Type Directory-Name Fs-specific-data [options]
#	You can specify multiple cache_dir lines to spread the
#	cache among different disk partitions.
#	Type specifies the kind of storage system to use. Only "ufs"
#	is built by default. To enable any of the other storage systems
#	see the --enable-storeio configure option.
#	'Directory' is a top-level directory where cache swap
#	files will be stored. If you want to use an entire disk
#	for caching, this can be the mount-point directory.
#	The directory must exist and be writable by the Squid
#	process. Squid will NOT create this directory for you.
#	Only using COSS, a raw disk device or a stripe file can
#	be specified, but the configuration of the "cache_wap_log"
#	tag is mandatory.
#	The ufs store type:
#	"ufs" is the old well-known Squid storage format that has always
#	been there.
#	cache_dir ufs Directory-Name Mbytes L1 L2 [options]
#	'Mbytes' is the amount of disk space (MB) to use under this
#	directory.  The default is 100 MB.  Change this to suit your
#	configuration.  Do NOT put the size of your disk drive here.
#	Instead, if you want Squid to use the entire disk drive,
#	subtract 20% and use that value.
#	'Level-1' is the number of first-level subdirectories which
#	will be created under the 'Directory'.  The default is 16.
#	'Level-2' is the number of second-level subdirectories which
#	will be created under each first-level directory.  The default
#	is 256.
#	The aufs store type:
#	"aufs" uses the same storage format as "ufs", utilizing
#	POSIX-threads to avoid blocking the main Squid process on
#	disk-I/O. This was formerly known in Squid as async-io.
#	cache_dir aufs Directory-Name Mbytes L1 L2 [options]
#	see argument descriptions under ufs above
#	The diskd store type:
#	"diskd" uses the same storage format as "ufs", utilizing a
#	separate process to avoid blocking the main Squid process on
#	disk-I/O.
#	cache_dir diskd Directory-Name Mbytes L1 L2 [options] [Q1=n] [Q2=n]
#	Q1 specifies the number of unacknowledged I/O requests when Squid
#	stops opening new files. If this many messages are in the queues,
#	Squid won't open new files. Default is 64
#	Q2 specifies the number of unacknowledged messages when Squid
#	starts blocking.  If this many messages are in the queues,
#	Squid blocks until it receives some replies. Default is 72
#	When Q1 < Q2 (the default), the cache directory is optimized
#	for lower response time at the expense of a decrease in hit
#	ratio.  If Q1 > Q2, the cache directory is optimized for
#	higher hit ratio at the expense of an increase in response
#	time.
#	The COSS store type:
#	block-size=n defines the "block size" for COSS cache_dir's.
#	Squid uses file numbers as block numbers.  Since file numbers
#	are limited to 24 bits, the block size determines the maximum
#	size of the COSS partition.  The default is 512 bytes, which
#	leads to a maximum cache_dir size of 512<<24, or 8 GB.  Note
#	you should not change the COSS block size after Squid
#	has written some objects to the cache_dir.
#	overwrite-percent=n defines the percentage of disk that COSS
#	must write to before a given object will be moved to the
#	current stripe.  A value of "n" closer to 100 will cause COSS
#	to waste less disk space by having multiple copies of an object
#	on disk, but will increase the chances of overwriting a popular
#	object as COSS overwrites stripes.  A value of "n" close to 0
#	will cause COSS to keep all current objects in the current COSS
#	stripe at the expense of the hit rate.  The default value of 50
#	will allow any given object to be stored on disk a maximum of
#	2 times.
#	max-stripe-waste=n defines the maximum amount of space that COSS
#	will waste in a given stripe (in bytes).  When COSS writes data
#	to disk, it will potentially waste up to "max-size" worth of disk
#	space for each 1MB of data written.  If "max-size" is set to a
#	large value (ie >256k), this could potentially result in large
#	amounts of wasted disk space. Setting this value to a lower value
#	(ie 64k or 32k) will result in a COSS disk refusing to cache
#	larger objects until the COSS stripe has been filled to within
#	"max-stripe-waste" of the maximum size (1MB).
#	membufs=n defines the number of "memory-only" stripes that COSS
#	will use.  When an cache hit is performed on a COSS stripe before
#	COSS has reached the overwrite-percent value for that object,
#	COSS will use a series of memory buffers to hold the object in
#	while the data is sent to the client.  This will define the maximum
#	number of memory-only buffers that COSS will use.  The default value
#	is 10, which will use a maximum of 10MB of memory for buffers.
#	maxfullbufs=n defines the maximum number of stripes a COSS partition
#	will have in memory waiting to be freed (either because the disk is
#	under load and the stripe is unwritten, or because clients are still
#	transferring data from objects using the memory).  In order to try
#	and maintain a good hit rate under load, COSS will reserve the last
#	2 full stripes for object hits. (ie a COSS cache_dir will reject
#	new objects when the number of full stripes is 2 less than maxfullbufs)
#	Common options:
#	read-only, this cache_dir is read only.
#	max-size=n, refers to the max object size this storedir supports.
#	It is used to initially choose the storedir to dump the object.
#	Note: To make optimal use of the max-size limits you should order
#	the cache_dir lines with the smallest max-size value first and the
#	ones with no max-size specification last.
#	Note that for coss, max-size must be less than COSS_MEMBUF_SZ
#	(hard coded at 1 MB).
#Default:
# cache_dir ufs /var/spool/squid 100 16 256
cache_dir ufs /var/spool/squid 4096 16 256
#  TAG: logformat
#	Usage:
#	logformat <name> <format specification>
#	Defines an access log format.
#	The <format specification> is a string with embedded % format codes
#	% format codes all follow the same basic structure where all but
#	the formatcode is optional. Output strings are automatically escaped
#	as required according to their context and the output format
#	modifiers are usually not needed, but can be specified if an explicit
#	output format is desired.
#		% ["|[|'|#] [-] [[0]width] [{argument}] formatcode
#		"	output in quoted string format
#		[	output in squid text log format as used by log_mime_hdrs
#		#	output in URL quoted format
#		'	output as-is
#		-	left aligned
#		width	field width. If starting with 0 then the
#			output is zero padded
#		{arg}	argument such as header name etc
#	Format codes:
#		>a	Client source IP address
#		>A	Client FQDN
#		<A	Server IP address or peer name
#		la	Local IP address (http_port)
#		lp	Local port number (http_port)
#		ts	Seconds since epoch
#		tu	subsecond time (milliseconds)
#		tl	Local time. Optional strftime format argument
#			default %d/%b/%Y:%H:%M:%S %z
#		tg	GMT time. Optional strftime format argument
#		tr	Response time (milliseconds)
#		>h	Request header. Optional header name argument
#			on the format header[:[separator]element]
#		<h	Reply header. Optional header name argument
#			as for >h
#		un	User name
#		ul	User login
#		ui	User ident
#		us	User SSL
#		ue	User external acl
#		Hs	HTTP status code
#		Ss	Squid request status (TCP_MISS etc)
#		Sh	Squid hierarchy status (DEFAULT_PARENT etc)
#		mt	MIME content type
#		rm	Request method (GET/POST etc)
#		ru	Request URL
#		rv	Request protocol version
#		ea	Log string returned by external acl
#		<st	Reply size including HTTP headers
#		%	a literal % character
#logformat squid  %ts.%03tu %6tr %>a %Ss/%03Hs %<st %rm %ru %un %Sh/%<A %mt
#logformat squidmime  %ts.%03tu %6tr %>a %Ss/%03Hs %<st %rm %ru %un %Sh/%<A %mt [%>h] [%<h]
#logformat common %>a %ui %un [%tl] "%rm %ru HTTP/%rv" %Hs %<st %Ss:%Sh
#logformat combined %>a %ui %un [%tl] "%rm %ru HTTP/%rv" %Hs %<st "%{Referer}>h" "%{User-Agent}>h" %Ss:%Sh
#Default:
# none
#  TAG: access_log
#  These files log client request activities. Has a line every HTTP or
#  ICP request. The format is:
#  access_log <filepath> [<logformat name> [acl acl ...]]
#  Will log to the specified file using the specified format (which
#  must be defined in a logformat directive) those entries which match
#  ALL the acl's specified (which must be defined in acl clauses).
#  If no acl is specified, all requests will be logged to this file.
#  To disable logging of a request use the filepath "none", in which case
#  a logformat name should not be specified.
#  To log the request via syslog specify a filepath of "syslog"
access_log /var/log/squid/access.log squid
#  TAG: cache_log
#	Cache logging file. This is where general information about
#	your cache's behavior goes. You can increase the amount of data
#	logged to this file with the "debug_options" tag below.
#Default:
# cache_log /var/log/squid/cache.log
#  TAG: cache_store_log
#	Logs the activities of the storage manager.  Shows which
#	objects are ejected from the cache, and which objects are
#	saved and for how long.  To disable, enter "none". There are
#	not really utilities to analyze this data, so you can safely
#	disable it.
#Default:
# cache_store_log /var/log/squid/store.log
#  TAG: cache_swap_log
#	Location for the cache "swap.state" file. This log file holds
#	the metadata of objects saved on disk.  It is used to rebuild
#	the cache during startup.  Normally this file resides in each
#	'cache_dir' directory, but you may specify an alternate
#	pathname here.  Note you must give a full filename, not just
#	a directory. Since this is the index for the whole object
#	list you CANNOT periodically rotate it!
#	If %s can be used in the file name it will be replaced with a
#	a representation of the cache_dir name where each / is replaced
#	with '.'. This is needed to allow adding/removing cache_dir
#	lines when cache_swap_log is being used.
#	If have more than one 'cache_dir', and %s is not used in the name
#	these swap logs will have names such as:
#		cache_swap_log.00
#		cache_swap_log.01
#		cache_swap_log.02
#	The numbered extension (which is added automatically)
#	corresponds to the order of the 'cache_dir' lines in this
#	configuration file.  If you change the order of the 'cache_dir'
#	lines in this file, these log files will NOT correspond to
#	the correct 'cache_dir' entry (unless you manually rename
#	them).  We recommend you do NOT use this option.  It is
#	better to keep these log files in each 'cache_dir' directory.
#Default:
# none
#  TAG: emulate_httpd_log	on|off
#	The Cache can emulate the log file format which many 'httpd'
#	programs use.  To disable/enable this emulation, set
#	emulate_httpd_log to 'off' or 'on'.  The default
#	is to use the native log format since it includes useful
#	information Squid-specific log analyzers use.
#Default:
# emulate_httpd_log off
#  TAG: log_ip_on_direct	on|off
#	Log the destination IP address in the hierarchy log tag when going
#	direct. Earlier Squid versions logged the hostname here. If you
#	prefer the old way set this to off.
#Default:
# log_ip_on_direct on
#  TAG: mime_table
#	Pathname to Squid's MIME table. You shouldn't need to change
#	this, but the default file contains examples and formatting
#	information if you do.
#Default:
# mime_table /usr/share/squid/mime.conf
#  TAG: log_mime_hdrs	on|off
#	The Cache can record both the request and the response MIME
#	headers for each HTTP transaction.  The headers are encoded
#	safely and will appear as two bracketed fields at the end of
#	the access log (for either the native or httpd-emulated log
#	formats).  To enable this logging set log_mime_hdrs to 'on'.
#Default:
# log_mime_hdrs off
#  TAG: useragent_log
#	Squid will write the User-Agent field from HTTP requests
#	to the filename specified here.  By default useragent_log
#	is disabled.
#Default:
# none
#  TAG: referer_log
#	Squid will write the Referer field from HTTP requests to the
#	filename specified here.  By default referer_log is disabled.
#	Note that "referer" is actually a misspelling of "referrer"
#	however the misspelt version has been accepted into the HTTP RFCs
#	and we accept both.
#Default:
# none
#  TAG: pid_filename
#	A filename to write the process-id to.  To disable, enter "none".
#Default:
# pid_filename /var/run/squid.pid
#  TAG: debug_options
#	Logging options are set as section,level where each source file
#	is assigned a unique section.  Lower levels result in less
#	output,  Full debugging (level 9) can result in a very large
#	log file, so be careful.  The magic word "ALL" sets debugging
#	levels for all sections.  We recommend normally running with
#	"ALL,1".
#Default:
# debug_options ALL,1
#  TAG: log_fqdn	on|off
#	Turn this on if you wish to log fully qualified domain names
#	in the access.log. To do this Squid does a DNS lookup of all
#	IP's connecting to it. This can (in some situations) increase
#	latency, which makes your cache seem slower for interactive
#	browsing.
#Default:
# log_fqdn off
#  TAG: client_netmask
#	A netmask for client addresses in logfiles and cachemgr output.
#	Change this to protect the privacy of your cache clients.
#	A netmask of 255.255.255.0 will log all IP's in that range with
#	the last digit set to '0'.
#Default:
# client_netmask 255.255.255.255
# OPTIONS FOR EXTERNAL SUPPORT PROGRAMS
#  TAG: ftp_user
#	If you want the anonymous login password to be more informative
#	(and enable the use of picky ftp servers), set this to something
#	reasonable for your domain, like [email protected]
#	The reason why this is domainless by default is the
#	request can be made on the behalf of a user in any domain,
#	depending on how the cache is used.
#	Some ftp server also validate the email address is valid
#	(for example perl.com).
#Default:
# ftp_user Squid@
#  TAG: ftp_list_width
#	Sets the width of ftp listings. This should be set to fit in
#	the width of a standard browser. Setting this too small
#	can cut off long filenames when browsing ftp sites.
#Default:
# ftp_list_width 32
#  TAG: ftp_passive
#	If your firewall does not allow Squid to use passive
#	connections, turn off this option.
#Default:
# ftp_passive on
#  TAG: ftp_sanitycheck
#	For security and data integrity reasons Squid by default performs
#	sanity checks of the addresses of FTP data connections ensure the
#	data connection is to the requested server. If you need to allow
#	FTP connections to servers using another IP address for the data
#	connection turn this off.
#Default:
# ftp_sanitycheck on
#  TAG: ftp_telnet_protocol
#	The FTP protocol is officially defined to use the telnet protocol
#	as transport channel for the control connection. However, many
#	implementations are broken and does not respect this aspect of
#	the FTP protocol.
#	If you have trouble accessing files with ASCII code 255 in the
#	path or similar problems involving this ASCII code you can
#	try setting this directive to off. If that helps, report to the
#	operator of the FTP server in question that their FTP server
#	is broken and does not follow the FTP standard.
#Default:
# ftp_telnet_protocol on
#  TAG: check_hostnames
#	For security and stability reasons Squid by default checks
#	hostnames for Internet standard RFC compliance. If you do not want
#	Squid to perform these checks then turn this directive off.
#Default:
# check_hostnames on
#  TAG: allow_underscore
#	Underscore characters is not strictly allowed in Internet hostnames
#	but nevertheless used by many sites. Set this to off if you want
#	Squid to be strict about the standard.
#Default:
# allow_underscore on
#  TAG: cache_dns_program
#       --disable-internal-dns option
#	Specify the location of the executable for dnslookup process.
#Default:
# cache_dns_program /usr/lib/squid/dnsserver
#  TAG: dns_children
#	The number of processes spawn to service DNS name lookups.
#	For heavily loaded caches on large servers, you should
#	probably increase this value to at least 10.  The maximum
#	is 32.  The default is 5.
#	You must have at least one dnsserver process.
#Default:
# dns_children 5
#  TAG: dns_retransmit_interval
#	Initial retransmit interval for DNS queries. The interval is
#	doubled each time all configured DNS servers have been tried.
#Default:
# dns_retransmit_interval 5 seconds
#  TAG: dns_timeout
#	DNS Query timeout. If no response is received to a DNS query
#	within this time all DNS servers for the queried domain
#	are assumed to be unavailable.
#Default:
# dns_timeout 2 minutes
#  TAG: dns_defnames	on|off
#	Normally the RES_DEFNAMES resolver option is disabled
#	(see res_init(3)).  This prevents caches in a hierarchy
#	from interpreting single-component hostnames locally.  To allow
#	Squid to handle single-component names, enable this option.
#Default:
# dns_defnames off
#  TAG: dns_nameservers
#	Use this if you want to specify a list of DNS name servers
#	(IP addresses) to use instead of those given in your
#	/etc/resolv.conf file.
#	On Windows platforms, if no value is specified here or in
#	the /etc/resolv.conf file, the list of DNS name servers are
#	taken from the Windows registry, both static and dynamic DHCP
#	configurations are supported.
#	Example: dns_nameservers 10.0.0.1 192.172.0.4
#Default:
# none
#  TAG: hosts_file
#	Location of the host-local IP name-address associations
#	database. Most Operating Systems have such a file on different
#	default locations:
#	- Un*X & Linux:    /etc/hosts
#	- Windows NT/2000: %SystemRoot%\system32\drivers\etc\hosts
#			   (%SystemRoot% value install default is c:\winnt)
#	- Windows XP/2003: %SystemRoot%\system32\drivers\etc\hosts
#			   (%SystemRoot% value install default is c:\windows)
#	- Windows 9x/Me:   %windir%\hosts
#			   (%windir% value is usually c:\windows)
#	- Cygwin:          /etc/hosts
#	The file contains newline-separated definitions, in the
#	form ip_address_in_dotted_form name [name ...] names are
#	whitespace-separated. Lines beginning with an hash (#)
#	character are comments.
#	The file is checked at startup and upon configuration.
#	If set to 'none', it won't be checked.
#	If append_domain is used, that domain will be added to
#	domain-local (i.e. not containing any dot character) host
#	definitions.
#Default:
# hosts_file /etc/hosts
#  TAG: diskd_program
#	Specify the location of the diskd executable.
#	Note that this is only useful if you have compiled in
#	diskd as one of the store io modules.
#Default:
# diskd_program /usr/lib/squid/diskd-daemon
#  TAG: unlinkd_program
#	Specify the location of the executable for file deletion process.
#Default:
# unlinkd_program /usr/lib/squid/unlinkd
#  TAG: pinger_program
#       --enable-icmp option
#	Specify the location of the executable for the pinger process.
#Default:
# pinger_program /usr/lib/squid/pinger
#redirect_program /usr/bin/squidGuard -c /etc/squid/squidGuard.conf
#  TAG: url_rewrite_program
#	Specify the location of the executable for the URL rewriter.
#	Since they can perform almost any function there isn't one included.
#	For each requested URL rewriter will receive on line with the format
#	URL <SP> client_ip "/" fqdn <SP> user <SP> method <SP> urlgroup <NL>
#	And the rewriter may return a rewritten URL. The other components of
#	the request line does not need to be returned (ignored if they are).
#	The rewriter can also indicate that a client-side redirect should
#	be performed to the new URL. This is done by prefixing the returned
#	URL with "301:" (moved permanently) or 302: (moved temporarily).
#	It can also return a "urlgroup" that can subsequently be matched
#	in cache_peer_access and similar ACL driven rules. An urlgroup is
#	returned by prefixing the returned url with "!urlgroup!"
#	By default, a URL rewriter is not used.
#Default:
# none
#  TAG: url_rewrite_children
#	The number of redirector processes to spawn. If you start
#	too few Squid will have to wait for them to process a backlog of
#	URLs, slowing it down. If you start too many they will use RAM
#	and other system resources.
#Default:
# url_rewrite_children 5
#  TAG: url_rewrite_concurrency
#	The number of requests each redirector helper can handle in
#	parallel. Defaults to 0 which indicates that the redirector
#	is a old-style singlethreaded redirector.
#Default:
# url_rewrite_concurrency 0
#  TAG: url_rewrite_host_header
#	By default Squid rewrites any Host: header in redirected
#	requests.  If you are running an accelerator this may
#	not be a wanted effect of a redirector.
#	WARNING: Entries are cached on the result of the URL rewriting
#	process, so be careful if you have domain-virtual hosts.
#Default:
# url_rewrite_host_header on
#  TAG: url_rewrite_access
#	If defined, this access list specifies which requests are
#	sent to the redirector processes.  By default all requests
#	are sent.
#Default:
# none
#  TAG: location_rewrite_program
#	Specify the location of the executable for the Location rewriter,
#	used to rewrite server generated redirects. Usually used in
#	conjunction with a url_rewrite_program
#	For each Location header received the location rewriter will receive
#	one line with the format:
#	   location URL <SP> requested URL <SP> urlgroup <NL>
#	And the rewriter may return a rewritten Location URL or a blank line.
#	The other components of the request line does not need to be returned
#	(ignored if they are).
#	By default, a Location rewriter is not used.
#Default:
# none
#  TAG: location_rewrite_children
#	The number of location rewriting processes to spawn. If you start
#Default:
# location_rewrite_children 5
#  TAG: location_rewrite_concurrency
#	The number of requests each Location rewriter helper can handle in
#	parallel. Defaults to 0 which indicates that the helper
#	is a old-style singlethreaded helper.
#Default:
# location_rewrite_concurrency 0
#  TAG: location_rewrite_access
#	sent to the location rewriting processes.  By default all Location
#	headers are sent.
#Default:
# none
#  TAG: auth_param
#	This is used to define parameters for the various authentication
#	schemes supported by Squid.
#	format: auth_param scheme parameter [setting]
#	The order in which authentication schemes are presented to the client is
#	dependent on the order the scheme first appears in config file. IE
#	has a bug (it's not RFC 2617 compliant) in that it will use the basic
#	scheme if basic is the first entry presented, even if more secure
#	schemes are presented. For now use the order in the recommended
#	settings section below. If other browsers have difficulties (don't
#	recognize the schemes offered even if you are using basic) either
#	put basic first, or disable the other schemes (by commenting out their
#	program entry).
#	Once an authentication scheme is fully configured, it can only be
#	shutdown by shutting squid down and restarting. Changes can be made on
#	the fly and activated with a reconfigure. I.E. You can change to a
#	different helper, but not unconfigure the helper completely.
#	Please note that while this directive defines how Squid processes
#	authentication it does not automatically activate authentication.
#	To use authentication you must in addition make use of ACLs based
#	on login name in http_access (proxy_auth, proxy_auth_regex or
#	external with %LOGIN used in the format tag). The browser will be
#	challenged for authentication on the first such acl encountered
#	in http_access processing and will also be re-challenged for new
#	login credentials if the request is being denied by a proxy_auth
#	type acl.
#	WARNING: authentication can't be used in a transparently intercepting
#	proxy as the client then thinks it is talking to an origin server and
#	not the proxy. This is a limitation of bending the TCP/IP protocol to
#	transparently intercepting port 80, not a limitation in Squid.
#	=== Parameters for the basic scheme follow. ===
#	"program" cmdline
#	Specify the command for the external authenticator.  Such a program
#	reads a line containing "username password" and replies "OK" or
#	"ERR" in an endless loop. "ERR" responses may optionally be followed
#	by a error description available as %m in the returned error page.
#	By default, the basic authentication scheme is not used unless a
#	program is specified.
#	If you want to use the traditional proxy authentication, jump over to
#	the helpers/basic_auth/NCSA directory and type:
#		% make
#		% make install
#	Then, set this line to something like
#  	auth_param basic program /usr/lib/squid/ncsa_auth /usr/etc/passwd
#	"children" numberofchildren
#	The number of authenticator processes to spawn. If you start too few
#	squid will have to wait for them to process a backlog of credential
#	verifications, slowing it down. When credential verifications are
#	done via a (slow) network you are likely to need lots of
#	authenticator processes.
#	auth_param basic children 5
#	"concurrency" numberofconcurrentrequests
#	The number of concurrent requests/channels the helper supports.
#	Changes the protocol used to include a channel number first on
#	the request/response line, allowing multiple requests to be sent
#	to the same helper in parallell without wating for the response.
#	Must not be set unless it's known the helper supports this.
#	"realm" realmstring
#	Specifies the realm name which is to be reported to the client for
#	the basic proxy authentication scheme (part of the text the user
#	will see when prompted their username and password).
#	auth_param basic realm Squid proxy-caching web server
#	"credentialsttl" timetolive
#	Specifies how long squid assumes an externally validated
#	username:password pair is valid for - in other words how often the
#	helper program is called for that user. Set this low to force
#	revalidation with short lived passwords.  Note that setting this high
#	does not impact your susceptibility to replay attacks unless you are
#	using an one-time password system (such as SecureID). If you are using
#	such a system, you will be vulnerable to replay attacks unless you
#	also use the max_user_ip ACL in an http_access rule.
#	auth_param basic credentialsttl 2 hours
#	"casesensitive" on|off
#	Specifies if usernames are case sensitive. Most user databases are
#	case insensitive allowing the same username to be spelled using both
#	lower and upper case letters, but some are case sensitive. This
#	makes a big difference for user_max_ip ACL processing and similar.
#	auth_param basic casesensitive off
#	"blankpassword" on|off
#	Specifies if blank passwords should be supported. Defaults to off
#	as there is multiple authentication backends which handles blank
#	passwords as "guest" access.
#	=== Parameters for the digest scheme follow ===
#	"program" cmdline
#	reads a line containing "username":"realm" and replies with the
#	appropriate H(A1) value base64 encoded or ERR if the user (or his H(A1)
#	hash) does not exists.  See RFC 2616 for the definition of H(A1).
#	"ERR" responses may optionally be followed by a error description
#	available as %m in the returned error page.
#	By default, the digest authentication scheme is not used unless a
#	If you want to use a digest authenticator, jump over to the
#	helpers/digest_auth/ directory and choose the authenticator to use.
#	It it's directory type
#		% make
#		% make install
# 	auth_param digest program /usr/lib/squid/digest_auth_pw /usr/etc/digpass
#	auth_param digest children 5
#	Specifies the realm name which is to be reported to the client for the
#	digest proxy authentication scheme (part of the text the user will see
#	when prompted their username and password).
#	auth_param digest realm Squid proxy-caching web server
#	"nonce_garbage_interval" timeinterval
#	Specifies the interval that nonces that have been issued to clients are
#	checked for validity.
#	auth_param digest nonce_garbage_interval 5 minutes
#	"nonce_max_duration" timeinterval
#	Specifies the maximum length of time a given nonce will be valid for.
#	auth_param digest nonce_max_duration 30 minutes
#	"nonce_max_count" number
#	Specifies the maximum number of times a given nonce can be used.
#	auth_param digest nonce_max_count 50
#	"nonce_strictness" on|off
#	Determines if squid requires strict increment-by-1 behavior for nonce
#	counts, or just incrementing (off - for use when useragents generate
#	nonce counts that occasionally miss 1 (ie, 1,2,4,6)).
#	auth_param digest nonce_strictness off
#	"check_nonce_count" on|off
#	This directive if set to off can disable the nonce count check
#	completely to work around buggy digest qop implementations in certain
#	mainstream browser versions. Default on to check the nonce count to
#	protect from authentication replay attacks.
#	auth_param digest check_nonce_count on
#	"post_workaround" on|off
#	This is a workaround to certain buggy browsers who sends an incorrect
#	request digest in POST requests when reusing the same nonce as acquired
#	earlier in response to a GET request.
#	auth_param digest post_workaround off
#	=== NTLM scheme options follow ===
#	"program" cmdline
#	Specify the command for the external NTLM authenticator. Such a
#	program participates in the NTLMSSP exchanges between Squid and the
#	client and reads commands according to the Squid NTLMSSP helper
#	protocol. See helpers/ntlm_auth/ for details. Recommended ntlm
#	authenticator is ntlm_auth from Samba-3.X, but a number of other
#	ntlm authenticators is available.
#	By default, the ntlm authentication scheme is not used unless a
#	Note: If you're using Samba >= 3.0.2, please install the winbind
#	package and use the ntlm_auth helper from that package.
#	auth_param ntlm program /usr/bin/ntlm_auth --helper-protocol=squid-2.5-ntlmssp
#	auth_param ntlm children 5
#	"keep_alive" on|off
#	This option enables the use of keep-alive on the initial
#	authentication request. It has been reported some versions of MSIE
#	have problems if this is enabled, but performance will be increased
#	if enabled.
#	auth_param ntlm keep_alive on
#	=== Negotiate scheme options follow ===
#	"program" cmdline
#	Specify the command for the external Negotiate authenticator. Such a
#	program participates in the SPNEGO exchanges between Squid and the
#	client and reads commands according to the Squid ntlmssp helper
#	protocol. See helpers/ntlm_auth/ for details. Recommended SPNEGO
#	authenticator is ntlm_auth from Samba-4.X.
#	By default, the Negotiate authentication scheme is not used unless a
#	auth_param negotiate program /path/to/samba/bin/ntlm_auth --helper-protocol=gss-spnego
#	auth_param negotiate children 5
#	If you experience problems with PUT/POST requests when using the
#	Negotiate authentication scheme then you can try setting this to
#	off. This will cause Squid to forcibly close the connection on
#	the initial requests where the browser asks which schemes are
#	supported by the proxy.
#	auth_param negotiate keep_alive on
#Recommended minimum configuration per scheme:
#auth_param negotiate program <uncomment and complete this line to activate>
#auth_param negotiate children 5
#auth_param negotiate keep_alive on
#auth_param ntlm program <uncomment and complete this line to activate>
#auth_param ntlm children 5
#auth_param ntlm keep_alive on
#auth_param digest program <uncomment and complete this line>
#auth_param digest children 5
#auth_param digest realm Squid proxy-caching web server
#auth_param digest nonce_garbage_interval 5 minutes
#auth_param digest nonce_max_duration 30 minutes
#auth_param digest nonce_max_count 50
#auth_param basic program <uncomment and complete this line>
#auth_param basic children 5
#auth_param basic realm Squid proxy-caching web server
#auth_param basic credentialsttl 2 hours
#auth_param basic casesensitive off
#  TAG: authenticate_cache_garbage_interval
#	The time period between garbage collection across the username cache.
#	This is a tradeoff between memory utilization (long intervals - say
#	2 days) and CPU (short intervals - say 1 minute). Only change if you
#	have good reason to.
#Default:
# authenticate_cache_garbage_interval 1 hour
#  TAG: authenticate_ttl
#	The time a user & their credentials stay in the logged in user cache
#	since their last request. When the garbage interval passes, all user
#	credentials that have passed their TTL are removed from memory.
#Default:
# authenticate_ttl 1 hour
#  TAG: authenticate_ip_ttl
#	If you use proxy authentication and the 'max_user_ip' ACL, this
#	directive controls how long Squid remembers the IP addresses
#	associated with each user.  Use a small value (e.g., 60 seconds) if
#	your users might change addresses quickly, as is the case with
#	dialups. You might be safe using a larger value (e.g., 2 hours) in a
#	corporate LAN environment with relatively static address assignments.
#Default:
# authenticate_ip_ttl 0 seconds
#  TAG: external_acl_type
#	This option defines external acl classes using a helper program to
#	look up the status
#	  external_acl_type name [options] FORMAT.. /path/to/helper [helper arguments..]
#	Options:
#	  ttl=n		TTL in seconds for cached results (defaults to 3600
#			for 1 hour)
#	  negative_ttl=n
#			TTL for cached negative lookups (default same
#			as ttl)
#	  children=n	number of processes spawn to service external acl
#			lookups of this type.
#	  concurrency=n	concurrency level per process. Use 0 for simple helpers
#			who can only process a single request at a time.
#			Note: see compatibility note below
#	  cache=n	result cache size, 0 is unbounded (default)
#	  grace=	Percentage remaining of TTL where a refresh of a
#			cached entry should be initiated without needing to
#			wait for a new reply. (default 0 for no grace period)
#	  protocol=2.5  Compatibility mode for Squid-2.5 external acl helpers
#	FORMAT specifications
#	  %LOGIN	Authenticated user login name
#	  %IDENT	Ident user name
#	  %SRC		Client IP
#	  %SRCPORT	Client source port
#	  %DST		Requested host
#	  %PROTO	Requested protocol
#	  %PORT		Requested port
#	  %METHOD	Request method
#	  %MYADDR	Squid interface address
#	  %MYPORT	Squid http_port number
#	  %PATH		Requested URL-path (including query-string if any)
#	  %USER_CERT	SSL User certificate in PEM format
#	  %USER_CERTCHAIN SSL User certificate chain in PEM format
#	  %USER_CERT_xx	SSL User certificate subject attribute xx
#	  %USER_CA_xx	SSL User certificate issuer attribute xx
#	  %{Header}	HTTP request header
#	  %{Hdr:member}	HTTP request header list member
#	  %{Hdr:;member}
#			HTTP request header list member using ; as
#			list separator. ; can be any non-alphanumeric
#			character.
#	 %ACL		The ACL name
#	 %DATA		The ACL arguments. If not used then any arguments
#			is automatically added at the end
#	In addition, any string specified in the referencing acl will
#	also be included in the helper request line, after the specified
#	formats (see the "acl external" directive)
#	The helper receives lines per the above format specification,
#	and returns lines starting with OK or ERR indicating the validity
#	of the request and optionally followed by additional keywords with
#	more details.
#	General result syntax:
#	  OK/ERR keyword=value ...
#	Defined keywords:
#	  user=		The users name (login also understood)
#	  password=	The users password (for PROXYPASS login= cache_peer)
#	  message=	Error message or similar used as %o in error messages
#			(error also understood)
#	  log=		String to be logged in access.log. Available as
#			%ea in logformat specifications
#	Keyword values need to be enclosed in quotes if they may contain
#	whitespace, or the whitespace escaped using \. Any quotes or \
#	characters within the keyword value must be \ escaped.
#	If protocol=3.0 then URL escaping of the strings is used instead
#	of the above described quoting format.
#	Compatibility Note: The children= option was named concurrency= in
#	Squid-2.5.STABLE3 and earlier, and was accepted as an alias for the
#	duration of the Squid-2.5 releases to keep compatibility. However,
#	the meaning of concurrency= option has changed in Squid-2.6 to match
#	that of Squid-3 and the old syntax no longer works.
#Default:
# none
# OPTIONS FOR TUNING THE CACHE
#  TAG: wais_relay_host
#  TAG: wais_relay_port
#	Relay WAIS request to host (1st arg) at port (2 arg).
#Default:
# wais_relay_port 0
#  TAG: request_header_max_size	(KB)
#	This specifies the maximum size for HTTP headers in a request.
#	Request headers are usually relatively small (about 512 bytes).
#	Placing a limit on the request header size will catch certain
#	bugs (for example with persistent connections) and possibly
#	buffer-overflow or denial-of-service attacks.
#Default:
# request_header_max_size 20 KB
#  TAG: request_body_max_size	(KB)
#	This specifies the maximum size for an HTTP request body.
#	In other words, the maximum size of a PUT/POST request.
#	A user who attempts to send a request with a body larger
#	than this limit receives an "Invalid Request" error message.
#	If you set this parameter to a zero (the default), there will
#	be no limit imposed.
#Default:
# request_body_max_size 0 KB
#  TAG: refresh_pattern
#	usage: refresh_pattern [-i] regex min percent max [options]
#	By default, regular expressions are CASE-SENSITIVE.  To make
#	them case-insensitive, use the -i option.
#	'Min' is the time (in minutes) an object without an explicit
#	expiry time should be considered fresh. The recommended
#	value is 0, any higher values may cause dynamic applications
#	to be erroneously cached unless the application designer
#	has taken the appropriate actions.
#	'Percent' is a percentage of the objects age (time since last
#	modification age) an object without explicit expiry time
#	will be considered fresh.
#	'Max' is an upper limit on how long objects without an explicit
#	expiry time will be considered fresh.
#	options: override-expire
#		 override-lastmod
#		 reload-into-ims
#		 ignore-reload
#		 ignore-no-cache
#		 ignore-private
#		 ignore-auth
#		override-expire enforces min age even if the server
#		sent a Expires: header. Doing this VIOLATES the HTTP
#		standard.  Enabling this feature could make you liable
#		for problems which it causes.
#		override-lastmod enforces min age even on objects
#		that were modified recently.
#		reload-into-ims changes client no-cache or ``reload''
#		to If-Modified-Since requests. Doing this VIOLATES the
#		HTTP standard. Enabling this feature could make you
#		liable for problems which it causes.
#		ignore-reload ignores a client no-cache or ``reload''
#		header. Doing this VIOLATES the HTTP standard. Enabling
#		this feature could make you liable for problems which
#		it causes.
#		ignore-no-cache ignores any ``Pragma: no-cache'' and
#		``Cache-control: no-cache'' headers received from a server.
#		The HTTP RFC never allows the use of this (Pragma) header
#		from a server, only a client, though plenty of servers
#		send it anyway.
#		ignore-private ignores any ``Cache-control: private''
#		headers received from a server. Doing this VIOLATES
#		the HTTP standard. Enabling this feature could make you
#		ignore-auth caches responses to requests with authorization,
#		irrespective of ``Cache-control'' headers received from
#		a server. Doing this VIOLATES the HTTP standard. Enabling
#		it causes.
#	Basically a cached object is:
#		FRESH if expires < now, else STALE
#		STALE if age > max
#		FRESH if lm-factor < percent, else STALE
#		FRESH if age < min
#		else STALE
#	The refresh_pattern lines are checked in the order listed here.
#	The first entry which matches is used.  If none of the entries
#	match the default will be used.
#	Note, you must uncomment all the default lines if you want
#	to change one. The default setting is only active if none is
#	used.
#Suggested default:
refresh_pattern ^ftp:		1440	20%	10080
refresh_pattern ^gopher:	1440	0%	1440
refresh_pattern .		0	20%	4320
#  TAG: quick_abort_min	(KB)
#  TAG: quick_abort_max	(KB)
#  TAG: quick_abort_pct	(percent)
#	The cache by default continues downloading aborted requests
#	which are almost completed (less than 16 KB remaining). This
#	may be undesirable on slow (e.g. SLIP) links and/or very busy
#	caches.  Impatient users may tie up file descriptors and
#	bandwidth by repeatedly requesting and immediately aborting
#	downloads.
#	When the user aborts a request, Squid will check the
#	quick_abort values to the amount of data transfered until
#	then.
#	If the transfer has less than 'quick_abort_min' KB remaining,
#	it will finish the retrieval.
#	If the transfer has more than 'quick_abort_max' KB remaining,
#	it will abort the retrieval.
#	If more than 'quick_abort_pct' of the transfer has completed,
#	If you do not want any retrieval to continue after the client
#	has aborted, set both 'quick_abort_min' and 'quick_abort_max'
#	to '0 KB'.
#	If you want retrievals to always continue if they are being
#	cached set 'quick_abort_min' to '-1 KB'.
#Default:
# quick_abort_min 16 KB
# quick_abort_max 16 KB
# quick_abort_pct 95
#  TAG: read_ahead_gap	buffer-size
#	The amount of data the cache will buffer ahead of what has been
#	sent to the client when retrieving an object from another server.
#Default:
# read_ahead_gap 16 KB
#  TAG: negative_ttl	time-units
#	Time-to-Live (TTL) for failed requests.  Certain types of
#	failures (such as "connection refused" and "404 Not Found") are
#	negatively-cached for a configurable amount of time.  The
#	default is 5 minutes.  Note that this is different from
#	negative caching of DNS lookups.
#Default:
# negative_ttl 5 minutes
#  TAG: positive_dns_ttl	time-units
#	Upper limit on how long Squid will cache positive DNS responses.
#	Default is 6 hours (360 minutes). This directive must be set
#	larger than negative_dns_ttl.
#Default:
# positive_dns_ttl 6 hours
#  TAG: negative_dns_ttl	time-units
#	Time-to-Live (TTL) for negative caching of failed DNS lookups.
#	This also makes sets the lower cache limit on positive lookups.
#	Minimum value is 1 second, and it is not recommendable to go
#	much below 10 seconds.
#Default:
# negative_dns_ttl 1 minute
#  TAG: range_offset_limit	(bytes)
#	Sets a upper limit on how far into the the file a Range request
#	may be to cause Squid to prefetch the whole file. If beyond this
#	limit Squid forwards the Range request as it is and the result
#	is NOT cached.
#	This is to stop a far ahead range request (lets say start at 17MB)
#	from making Squid fetch the whole object up to that point before
#	sending anything to the client.
#	A value of -1 causes Squid to always fetch the object from the
#	beginning so it may cache the result. (2.0 style)
#	A value of 0 causes Squid to never fetch more than the
#	client requested. (default)
#Default:
# range_offset_limit 0 KB
#  TAG: collapsed_forwarding	(on|off)
#	This option enables multiple requests for the same URI to be
#	processed as one request. Normally disabled to avoid increased
#	latency on dynamic content, but there can be benefit from enabling
#	this in accelerator setups where the web servers are the bottleneck
#	and reliable and returns mostly cacheable information.
#Default:
# collapsed_forwarding off
#  TAG: refresh_stale_hit	(time)
#	This option changes the refresh algorithm to allow concurrent
#	requests while an object is being refreshed to be processed as
#	cache hits if the object expired less than X seconds ago. Default
#	is 0 to disable this feature. This option is mostly interesting
#	in accelerator setups where a few objects is accessed very
#	frequently.
#Default:
# refresh_stale_hit 0 seconds
# TIMEOUTS
#  TAG: forward_timeout	time-units
#	This parameter specifies how long Squid should at most attempt in
#	finding a forwarding path for the request before giving up.
#Default:
# forward_timeout 4 minutes
#  TAG: connect_timeout	time-units
#	This parameter specifies how long to wait for the TCP connect to
#	the requested server or peer to complete before Squid should
#	attempt to find another path where to forward the request.
#Default:
# connect_timeout 1 minute
#  TAG: peer_connect_timeout	time-units
#	This parameter specifies how long to wait for a pending TCP
#	connection to a peer cache.  The default is 30 seconds.   You
#	may also set different timeout values for individual neighbors
#	with the 'connect-timeout' option on a 'cache_peer' line.
#Default:
# peer_connect_timeout 30 seconds
#  TAG: read_timeout	time-units
#	The read_timeout is applied on server-side connections.  After
#	each successful read(), the timeout will be extended by this
#	amount.  If no data is read again after this amount of time,
#	the request is aborted and logged with ERR_READ_TIMEOUT.  The
#	default is 15 minutes.
#Default:
# read_timeout 15 minutes
#  TAG: request_timeout
#	How long to wait for an HTTP request after initial
#	connection establishment.
#Default:
# request_timeout 5 minutes
#  TAG: persistent_request_timeout
#	How long to wait for the next HTTP request on a persistent
#	connection after the previous request completes.
#Default:
# persistent_request_timeout 1 minute
#  TAG: client_lifetime	time-units
#	The maximum amount of time a client (browser) is allowed to
#	remain connected to the cache process.  This protects the Cache
#	from having a lot of sockets (and hence file descriptors) tied up
#	in a CLOSE_WAIT state from remote clients that go away without
#	properly shutting down (either because of a network failure or
#	because of a poor client implementation).  The default is one
#	day, 1440 minutes.
#	NOTE:  The default value is intended to be much larger than any
#	client would ever need to be connected to your cache.  You
#	should probably change client_lifetime only as a last resort.
#	If you seem to have many client connections tying up
#	filedescriptors, we recommend first tuning the read_timeout,
#	request_timeout, persistent_request_timeout and quick_abort values.
#Default:
# client_lifetime 1 day
#  TAG: half_closed_clients
#	Some clients may shutdown the sending side of their TCP
#	connections, while leaving their receiving sides open.	Sometimes,
#	Squid can not tell the difference between a half-closed and a
#	fully-closed TCP connection.  By default, half-closed client
#	connections are kept open until a read(2) or write(2) on the
#	socket returns an error.  Change this option to 'off' and Squid
#	will immediately close client connections when read(2) returns
#	"no more data to read."
#Default:
# half_closed_clients on
#  TAG: pconn_timeout
#	Timeout for idle persistent connections to servers and other
#	proxies.
#Default:
# pconn_timeout 120 seconds
#  TAG: ident_timeout
#	Maximum time to wait for IDENT lookups to complete.
#	If this is too high, and you enabled IDENT lookups from untrusted
#	users, you might be susceptible to denial-of-service by having
#	many ident requests going at once.
#Default:
# ident_timeout 10 seconds
#  TAG: shutdown_lifetime	time-units
#	When SIGTERM or SIGHUP is received, the cache is put into
#	"shutdown pending" mode until all active sockets are closed.
#	This value is the lifetime to set for all open descriptors
#	during shutdown mode.  Any active clients after this many
#	seconds will receive a 'timeout' message.
#Default:
# shutdown_lifetime 30 seconds
# ACCESS CONTROLS
#  TAG: acl
#	Defining an Access List
#	acl aclname acltype string1 ...
#	acl aclname acltype "file" ...
#	when using "file", the file should contain one item per line
#	acltype is one of the types described below
#	acl aclname src      ip-address/netmask ... (clients IP address)
#	acl aclname src      addr1-addr2/netmask ... (range of addresses)
#	acl aclname dst      ip-address/netmask ... (URL host's IP address)
#	acl aclname myip     ip-address/netmask ... (local socket IP address)
#	acl aclname arp      mac-address ... (xx:xx:xx:xx:xx:xx notation)
#	  # The arp ACL requires the special configure option --enable-arp-acl.
#	  # Furthermore, the arp ACL code is not portable to all operating systems.
#	  # It works on Linux, Solaris, FreeBSD and some other *BSD variants.
#	  # NOTE: Squid can only determine the MAC address for clients that are on
#	  # the same subnet. If the client is on a different subnet, then Squid cannot
#	  # find out its MAC address.
#	acl aclname srcdomain   .foo.com ...    # reverse lookup, client IP
#	acl aclname dstdomain   .foo.com ...    # Destination server from URL
#	acl aclname srcdom_regex [-i] xxx ...   # regex matching client name
#	acl aclname dstdom_regex [-i] xxx ...   # regex matching server
#	  # For dstdomain and dstdom_regex  a reverse lookup is tried if a IP
#	  # based URL is used and no match is found. The name "none" is used
#	  # if the reverse lookup fails.
#	acl aclname time     [day-abbrevs]  [h1:m1-h2:m2]
#	    day-abbrevs:
#		S - Sunday
#		M - Monday
#		T - Tuesday
#		W - Wednesday
#		H - Thursday
#		F - Friday
#		A - Saturday
#	    h1:m1 must be less than h2:m2
#	acl aclname url_regex [-i] ^http:// ...	# regex matching on whole URL
#	acl aclname urlpath_regex [-i] \.gif$ ...	# regex matching on URL path
#	acl aclname urllogin [-i] [^a-zA-Z0-9] ...	# regex matching on URL login field
#	acl aclname port     80 70 21 ...
#	acl aclname port     0-1024 ...		# ranges allowed
#	acl aclname myport   3128 ...		# (local socket TCP port)
#	acl aclname proto    HTTP FTP ...
#	acl aclname method   GET POST ...
#	acl aclname browser  [-i] regexp ...
#	  # pattern match on User-Agent header (see also req_header below)
#	acl aclname referer_regex  [-i] regexp ...
#	  # pattern match on Referer header
#	  # Referer is highly unreliable, so use with care
#	acl aclname ident    username ...
#	acl aclname ident_regex [-i] pattern ...
#	  # string match on ident output.
#	  # use REQUIRED to accept any non-null ident.
#	acl aclname src_as   number ...
#	acl aclname dst_as   number ...
#	  # Except for access control, AS numbers can be used for
#	  # routing of requests to specific caches. Here's an
#	  # example for routing all requests for AS#1241 and only
#	  # those to mycache.mydomain.net:
#	  # acl asexample dst_as 1241
#	  # cache_peer_access mycache.mydomain.net allow asexample
#	  # cache_peer_access mycache_mydomain.net deny all
#	acl aclname proxy_auth username ...
#	acl aclname proxy_auth_regex [-i] pattern ...
#	  # list of valid usernames
#	  # use REQUIRED to accept any valid username.
#	  # NOTE: when a Proxy-Authentication header is sent but it is not
#	  # needed during ACL checking the username is NOT logged
#	  # in access.log.
#	  # NOTE: proxy_auth requires a EXTERNAL authentication program
#	  # to check username/password combinations (see
#	  # auth_param directive).
#	  # WARNING: proxy_auth can't be used in a transparent proxy. It
#	  # collides with any authentication done by origin servers. It may
#	  # seem like it works at first, but it doesn't.
#	acl aclname snmp_community string ...
#	  # A community string to limit access to your SNMP Agent
#	  # Example:
#	  #	acl snmppublic snmp_community public
#	acl aclname maxconn number
#	  # This will be matched when the client's IP address has
#	  # more than <number> HTTP connections established.
#	acl aclname max_user_ip [-s] number
#	  # This will be matched when the user attempts to log in from more
#	  # than <number> different ip addresses. The authenticate_ip_ttl
#	  # parameter controls the timeout on the ip entries.
#	  # If -s is specified the limit is strict, denying browsing
#	  # from any further IP addresses until the ttl has expired. Without
#	  # -s Squid will just annoy the user by "randomly" denying requests.
#	  # (the counter is reset each time the limit is reached and a
#	  # request is denied)
#	  # NOTE: in acceleration mode or where there is mesh of child proxies,
#	  # clients may appear to come from multiple addresses if they are
#	  # going through proxy farms, so a limit of 1 may cause user problems.
#	acl aclname req_mime_type mime-type1 ...
#	  # regex match against the mime type of the request generated
#	  # by the client. Can be used to detect file upload or some
#	  # types HTTP tunneling requests.
#	  # NOTE: This does NOT match the reply. You cannot use this
#	  # to match the returned file type.
#	acl aclname req_header header-name [-i] any\.regex\.here
#	  # regex match against any of the known request headers.  May be
#	  # thought of as a superset of "browser", "referer" and "mime-type"
#	  # ACLs.
#	acl aclname rep_mime_type mime-type1 ...
#	  # regex match against the mime type of the reply received by
#	  # squid. Can be used to detect file download or some
#	  # NOTE: This has no effect in http_access rules. It only has
#	  # effect in rules that affect the reply data stream such as
#	  # http_reply_access.
#	acl aclname rep_header header-name [-i] any\.regex\.here
#	  # regex match against any of the known response headers.
#	  # Example:
#	  # acl many_spaces rep_header Content-Disposition -i [[:space:]]{3,}
#	acl acl_name external class_name [arguments...]
#	  # external ACL lookup via a helper class defined by the
#	  # external_acl_type directive.
#	acl urlgroup group1 ...
#	  # match against the urlgroup as indicated by redirectors
#	acl aclname user_cert attribute values...
#	  # match against attributes in a user SSL certificate
#	  # attribute is one of DN/C/O/CN/L/ST
#	acl aclname ca_cert attribute values...
#	  # match against attributes a users issuing CA SSL certificate
#	acl aclname ext_user       username ...
#	acl aclname ext_user_regex [-i] pattern ...
#	  # string match on username returned by external acl
#	  # use REQUIRED to accept any user name.
#Examples:
#acl macaddress arp 09:00:2b:23:45:67
#acl myexample dst_as 1241
#acl password proxy_auth REQUIRED
#acl fileupload req_mime_type -i ^multipart/form-data$
#acl javascript rep_mime_type -i ^application/x-javascript$
#Recommended minimum configuration:
acl all src 0.0.0.0/0.0.0.0
acl manager proto cache_object
acl localhost src 127.0.0.1/255.255.255.255
acl to_localhost dst 127.0.0.0/8
acl SSL_ports port 443 # https
acl SSL_ports port 563 # snews
acl SSL_ports port 873 # rsync
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl Safe_ports port 901 # SWAT
acl purge method PURGE
acl CONNECT method CONNECT
acl Lancaster src 10.135.225.4-10.135.225.254/255.255.255.255
#  TAG: follow_x_forwarded_for
# Note: This option is only available if Squid is rebuilt with the
#       -DFOLLOW_X_FORWARDED_FOR option
#	Allowing or Denying the X-Forwarded-For header to be followed to
#	find the original source of a request.
#	Requests may pass through a chain of several other proxies
#	before reaching us.  The X-Forwarded-For header will contain a
#	comma-separated list of the IP addresses in the chain, with the
#	rightmost address being the most recent.
#	If a request reaches us from a source that is allowed by this
#	configuration item, then we consult the X-Forwarded-For header
#	to see where that host received the request from.  If the
#	X-Forwarded-For header contains multiple addresses, and if
#	acl_uses_indirect_client is on, then we continue backtracking
#	until we reach an address for which we are not allowed to
#	follow the X-Forwarded-For header, or until we reach the first
#	address in the list.  (If acl_uses_indirect_client is off, then
#	it's impossible to backtrack through more than one level of
#	X-Forwarded-For addresses.)
#	The end result of this process is an IP address that we will
#	refer to as the indirect client address.  This address may
#	be treated as the client address for access control, delay
#	pools and logging, depending on the acl_uses_indirect_client,
#	delay_pool_uses_indirect_client and log_uses_indirect_client
#	options.
#	SECURITY CONSIDERATIONS:
#		Any host for which we follow the X-Forwarded-For header
#		can place incorrect information in the header, and Squid
#		will use the incorrect information as if it were the
#		source address of the request.  This may enable remote
#		hosts to bypass any access control restrictions that are
#		based on the client's source addresses.
#	For example:
#		acl localhost src 127.0.0.1
#		acl my_other_proxy srcdomain .proxy.example.com
#		follow_x_forwarded_for allow localhost
#		follow_x_forwarded_for allow my_other_proxy
#Default:
# follow_x_forwarded_for deny all
#  TAG: acl_uses_indirect_client	on|off
#	Controls whether the indirect client address
#	(see follow_x_forwarded_for) is used instead of the
#	direct client address in acl matching.
#Default:
# acl_uses_indirect_client on
#  TAG: delay_pool_uses_indirect_client	on|off
#	direct client address in delay pools.
#Default:
# delay_pool_uses_indirect_client on
#  TAG: log_uses_indirect_client	on|off
#	direct client address in the access log.
#Default:
# log_uses_indirect_client on
#  TAG: http_access
#	Allowing or Denying access based on defined access lists
#	Access to the HTTP port:
#	http_access allow|deny [!]aclname ...
#	NOTE on default values:
#	If there are no "access" lines present, the default is to deny
#	the request.
#	If none of the "access" lines cause a match, the default is the
#	opposite of the last line in the list.  If the last line was
#	deny, the default is allow.  Conversely, if the last line
#	is allow, the default will be deny.  For these reasons, it is a
#	good idea to have an "deny all" or "allow all" entry at the end
#	of your access lists to avoid potential confusion.
#Default:
# http_access deny all
# Only allow cachemgr access from localhost
http_access allow manager localhost
http_access deny manager
# Only allow purge requests from localhost
http_access allow purge localhost
http_access deny purge
# Deny requests to unknown ports
http_access deny !Safe_ports
# Deny CONNECT to other than SSL ports
http_access deny CONNECT !SSL_ports
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on "localhost" is a local user
#http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Example rule allowing access from your local networks. Adapt
# to list your (internal) IP networks from where browsing should
# be allowed
#acl our_networks src 192.168.1.0/24 192.168.2.0/24
#http_access allow our_networks
http_access allow localhost
# And finally deny all other access to this proxy
http_access allow Lancaster
#  TAG: http_access2
#	Identical to http_access, but runs after redirectors. If not set
#	then only http_access is used.
#Default:
# none
#  TAG: http_reply_access
#	Allow replies to client requests. This is complementary to http_access.
#	http_reply_access allow|deny [!] aclname ...
#	NOTE: if there are no access lines present, the default is to allow
#	all replies
#	If none of the access lines cause a match the opposite of the
#	last line will apply. Thus it is good practice to end the rules
#	with an "allow all" or "deny all" entry.
#Default:
# http_reply_access allow all
# Insert your own rules here.
# and finally allow by default
#  TAG: icp_access
#	Allowing or Denying access to the ICP port based on defined
#	access lists
#	icp_access  allow|deny [!]aclname ...
#	See http_access for details
#Default:
# icp_access deny all
#Allow ICP queries from everyone
icp_access allow all
#  TAG: htcp_access
#	Allowing or Denying access to the HTCP port based on defined
#	access lists
#	htcp_access  allow|deny [!]aclname ...
##Allow HTCP queries from everyone
#htcp_access allow all
#Default:
# htcp_access deny all
#  TAG: htcp_clr_access
#	Allowing or Denying access to purge content using HTCP based
#	on defined access lists
#	htcp_clr_access  allow|deny [!]aclname ...
##Allow HTCP CLR requests from trusted peers
#acl htcp_clr_peer src 172.16.1.2
#htcp_clr_access allow htcp_clr_peer
#Default:
# htcp_clr_access deny all
#  TAG: miss_access
#	Use to force your neighbors to use you as a sibling instead of
#	a parent.  For example:
#		acl localclients src 172.16.0.0/16
#		miss_access allow localclients
#		miss_access deny  !localclients
#	This means only your local clients are allowed to fetch
#	MISSES and all other clients can only fetch HITS.
#	By default, allow all clients who passed the http_access rules
#	to fetch MISSES from us.
#Default setting:
# miss_access allow all
#  TAG: cache_peer_access
#	Similar to 'cache_peer_domain' but provides more flexibility by
#	using ACL elements.
#	cache_peer_access cache-host allow|deny [!]aclname ...
#	The syntax is identical to 'http_access' and the other lists of
#	ACL elements.  See the comments for 'http_access' below, or
#	the Squid FAQ (http://www.squid-cache.org/FAQ/FAQ-10.html).
#Default:
# none
#  TAG: ident_lookup_access
#	A list of ACL elements which, if matched, cause an ident
#	(RFC931) lookup to be performed for this request.  For
#	example, you might choose to always perform ident lookups
#	for your main multi-user Unix boxes, but not for your Macs
#	and PCs.  By default, ident lookups are not performed for
#	any requests.
#	To enable ident lookups for specific client addresses, you
#	can follow this example:
#	acl ident_aware_hosts src 198.168.1.0/255.255.255.0
#	ident_lookup_access allow ident_aware_hosts
#	ident_lookup_access deny all
#	Only src type ACL checks are fully supported.  A src_domain
#	ACL might work at times, but it will not always provide
#	the correct result.
#Default:
#  TAG: tcp_outgoing_tos
#	Allows you to select a TOS/Diffserv value to mark outgoing
#	connections with, based on the username or source address
#	making the request.
#	tcp_outgoing_tos ds-field [!]aclname ...
#	Example where normal_service_net uses the TOS value 0x00
#	and normal_service_net uses 0x20
#	acl normal_service_net src 10.0.0.0/255.255.255.0
#	acl good_service_net src 10.0.1.0/255.255.255.0
#	tcp_outgoing_tos 0x00 normal_service_net 0x00
#	tcp_outgoing_tos 0x20 good_service_net
#	TOS/DSCP values really only have local significance - so you should
#	know what you're specifying. For more information, see RFC2474 and
#	RFC3260.
#	The TOS/DSCP byte must be exactly that - a octet value  0 - 255, or
#	"default" to use whatever default your host has. Note that in
#	practice often only values 0 - 63 is usable as the two highest bits
#	have been redefined for use by ECN (RFC3168).
#	Processing proceeds in the order specified, and stops at first fully
#	matching line.
#	Note: The use of this directive using client dependent ACLs is
#	incompatible with the use of server side persistent connections. To
#	ensure correct results it is best to set server_persisten_connections
#	to off when using this directive in such configurations.
#Default:
# none
#  TAG: tcp_outgoing_address
#	Allows you to map requests to different outgoing IP addresses
#	based on the username or source address of the user making
#	the request.
#	tcp_outgoing_address ipaddr [[!]aclname] ...
#	Example where requests from 10.0.0.0/24 will be forwarded
#	with source address 10.1.0.1, 10.0.2.0/24 forwarded with
#	source address 10.1.0.2 and the rest will be forwarded with
#	source address 10.1.0.3.
#	tcp_outgoing_address 10.0.0.1 normal_service_net
#	tcp_outgoing_address 10.0.0.2 good_service_net
#	tcp_outgoing_address 10.0.0.3
#	matching line.
#	ensure correct results it is best to set server_persistent_connections
#Default:
# none
#  TAG: reply_header_max_size	(KB)
#	This specifies the maximum size for HTTP headers in a reply.
#	Reply headers are usually relatively small (about 512 bytes).
#	Placing a limit on the reply header size will catch certain
#Default:
# reply_header_max_size 20 KB
#  TAG: reply_body_max_size	bytes allow|deny acl acl...
#	This option specifies the maximum size of a reply body in bytes.
#	It can be used to prevent users from downloading very large files,
#	such as MP3's and movies. When the reply headers are received,
#	the reply_body_max_size lines are processed, and the first line with
#	a result of "allow" is used as the maximum body size for this reply.
#	This size is checked twice. First when we get the reply headers,
#	we check the content-length value.  If the content length value exists
#	and is larger than the allowed size, the request is denied and the
#	user receives an error message that says "the request or reply
#	is too large." If there is no content-length, and the reply
#	size exceeds this limit, the client's connection is just closed
#	and they will receive a partial reply.
#	WARNING: downstream caches probably can not detect a partial reply
#	if there is no content-length header, so they will cache
#	partial responses and give them out as hits.  You should NOT
#	use this option if you have downstream caches.
#	If you set this parameter to zero (the default), there will be
#	no limit imposed.
#Default:
# reply_body_max_size 0 allow all
#  TAG: log_access	allow|deny acl acl...
#	This options allows you to control which requests gets logged
#	to access.log (see access_log directive). Requests denied for
#	logging will also not be accounted for in performance counters.
#Default:
# none
# ADMINISTRATIVE PARAMETERS
#  TAG: cache_mgr
#	Email-address of local cache manager who will receive
#	mail if the cache dies. The default is "webmaster".
#Default:
# cache_mgr webmaster
#  TAG: mail_from
#	From: email-address for mail sent when the cache dies.
#	The default is to use 'appname@unique_hostname'.
#	Default appname value is "squid", can be changed into
#	src/globals.h before building squid.
#Default:
# none
#  TAG: mail_program
#	Email program used to send mail if the cache dies.
#	The default is "mail". The specified program must complain
#	with the standard Unix mail syntax:
#	mail_program recipient < mailfile
#	Optional command line options can be specified.
#Default:
# mail_program mail
#  TAG: cache_effective_user
#	If you start Squid as root, it will change its effective/real
#	UID/GID to the user specified below.  The default is to change
#	to UID to proxy.  If you define cache_effective_user, but not
#	cache_effective_group, Squid sets the GID to the effective
#	user's default group ID (taken from the password file) and
#	supplementary group list from the from groups membership of
#	cache_effective_user.
#Default:
# cache_effective_user proxy
cache_effective_user cougarse
#  TAG: cache_effective_group
#	If you want Squid to run with a specific GID regardless of
#	the group memberships of the effective user then set this
#	to the group (or GID) you want Squid to run as. When set
#	all other group privileges of the effective user is ignored
#	and only this GID is effective. If Squid is not started as
#	root the user starting Squid must be member of the specified
#	group.
cache_effective_group cougarse
#  TAG: httpd_suppress_version_string	on|off
#	Suppress Squid version string info in HTTP headers and HTML error pages.
#Default:
# httpd_suppress_version_string off
#  TAG: visible_hostname
#	If you want to present a special hostname in error messages, etc,
#	define this.  Otherwise, the return value of gethostname()
#	will be used. If you have multiple caches in a cluster and
#	get errors about IP-forwarding you must set them to have individual
#	names with this setting.
#Default:
# none
#  TAG: unique_hostname
#	If you want to have multiple machines with the same
#	'visible_hostname' you must give each machine a different
#	'unique_hostname' so forwarding loops can be detected.
#Default:
# none
#  TAG: hostname_aliases
#	A list of other DNS names your cache has.
#Default:
# none
#  TAG: umask
#	Minimum umask which should be enforced while the proxy
#	is running, in addition to the umask set at startup.
#	Note: Should start with a 0 to indicate the normal octal
#	representation of umasks
#Default:
# umask 027
# OPTIONS FOR THE CACHE REGISTRATION SERVICE
#	This section contains parameters for the (optional) cache
#	announcement service.  This service is provided to help
#	cache administrators locate one another in order to join or
#	create cache hierarchies.
#	An 'announcement' message is sent (via UDP) to the registration
#	service by Squid.  By default, the announcement message is NOT
#	SENT unless you enable it with 'announce_period' below.
#	The announcement message includes your hostname, plus the
#	following information from this configuration file:
#		http_port
#		icp_port
#		cache_mgr
#	All current information is processed regularly and made
#	available on the Web at http://www.ircache.net/Cache/Tracker/.
#  TAG: announce_period
#	This is how frequently to send cache announcements.  The
#	default is `0' which disables sending the announcement
#	messages.
#	To enable announcing your cache, just uncomment the line
#	below.
#Default:
# announce_period 0
#To enable announcing your cache, just uncomment the line below.
#announce_period 1 day
#  TAG: announce_host
#  TAG: announce_file
#  TAG: announce_port
#	announce_host and announce_port set the hostname and port
#	number where the registration message will be sent.
#	Hostname will default to 'tracker.ircache.net' and port will
#	default default to 3131.  If the 'filename' argument is given,
#	the contents of that file will be included in the announce
#	message.
#Default:
# announce_host tracker.ircache.net
# announce_port 3131
# HTTPD-ACCELERATOR OPTIONS
#  TAG: httpd_accel_no_pmtu_disc	on|off
#	In many setups of transparently intercepting proxies Path-MTU
#	discovery can not work on traffic towards the clients. This is
#	the case when the intercepting device does not fully track
#	connections and fails to forward ICMP must fragment messages
#	to the cache server.
#	If you have such setup and experience that certain clients
#	sporadically hang or never complete requests set this to on.
#Default:
# httpd_accel_no_pmtu_disc off
# MISCELLANEOUS
#  TAG: dns_testnames
#	The DNS tests exit as soon as the first site is successfully looked up
#	This test can be disabled with the -D command line option.
#Default:
# dns_testnames netscape.com internic.net nlanr.net microsoft.com
#  TAG: logfile_rotate
#	Specifies the number of logfile rotations to make when you
#	type 'squid -k rotate'.  The default is 10, which will rotate
#	with extensions 0 through 9.  Setting logfile_rotate to 0 will
#	disable the rotation, but the logfiles are still closed and
#	re-opened.  This will enable you to rename the logfiles
#	yourself just before sending the rotate signal.
#	Note, the 'squid -k rotate' command normally sends a USR1
#	signal to the running squid process.  In certain situations
#	(e.g. on Linux with Async I/O), USR1 is used for other
#	purposes, so -k rotate uses another signal.  It is best to get
#	in the habit of using 'squid -k rotate' instead of 'kill -USR1
#	<pid>'.
#	Note2, for Debian/Linux the default of logfile_rotate is
#	zero, since it includes external logfile-rotation methods.
#Default:
# logfile_rotate 0
#  TAG: append_domain
#	Appends local domain name to hostnames without any dots in
#	them.  append_domain must begin with a period.
#	Be warned there are now Internet names with no dots in
#	them using only top-domain names, so setting this may
#	cause some Internet sites to become unavailable.
#Example:
# append_domain .yourdomain.com
#Default:
# none
#  TAG: tcp_recv_bufsize	(bytes)
#	Size of receive buffer to set for TCP sockets.  Probably just
#	as easy to change your kernel's default.  Set to zero to use
#	the default buffer size.
#Default:
# tcp_recv_bufsize 0 bytes
#  TAG: error_map
#	Map errors to custom messages
#	    error_map message_url http_status ...
#	http_status ... is a list of HTTP status codes or Squid error
#	messages.
#	Use in accelerators to substitute the error messages returned
#	by servers with other custom errors.
#	    error_map http://your.server/error/404.shtml 404
#	Requests for error messages is a GET request for the configured
#	URL with the following special headers
#	    X-Error-Status:	The received HTTP status code (i.e. 404)
#	    X-Request-URI:	The requested URI where the error occurred
#	In Addition the following headers are forwarded from the client
#	request:
#	    User-Agent, Cookie, X-Forwarded-For, Via, Authorization,
#	    Accept, Referer
#	And the following headers from the server reply:
#	    Server, Via, Location, Content-Location
#	The reply returned to the client will carry the original HTTP
#	headers from the real error message, but with the reply body
#	of the configured error message.
#Default:
# none
#  TAG: err_html_text
#	HTML text to include in error messages.  Make this a "mailto"
#	URL to your admin address, or maybe just a link to your
#	organizations Web page.
#	To include this in your error messages, you must rewrite
#	the error template files (found in the "errors" directory).
#	Wherever you want the 'err_html_text' line to appear,
#	insert a %L tag in the error template file.
#Default:
# none
#  TAG: deny_info
#	Usage:   deny_info err_page_name acl
#	or       deny_info http://... acl
#	Example: deny_info ERR_CUSTOM_ACCESS_DENIED bad_guys
#	This can be used to return a ERR_ page for requests which
#	do not pass the 'http_access' rules.  A single ACL will cause
#	the http_access check to fail.  If a 'deny_info' line exists
#	for that ACL Squid returns a corresponding error page.
#	You may use ERR_ pages that come with Squid or create your own pages
#	and put them into the configured errors/ directory.
#	Alternatively you can specify an error URL. The browsers will
#	get redirected (302) to the specified URL. %s in the redirection
#	URL will be replaced by the requested URL.
#	Alternatively you can tell Squid to reset the TCP connection
#	by specifying TCP_RESET.
#Default:
# none
#  TAG: memory_pools	on|off
#	If set, Squid will keep pools of allocated (but unused) memory
#	available for future use.  If memory is a premium on your
#	system and you believe your malloc library outperforms Squid
#	routines, disable this.
#Default:
# memory_pools on
#  TAG: memory_pools_limit	(bytes)
#	Used only with memory_pools on:
#	memory_pools_limit 50 MB
#	If set to a non-zero value, Squid will keep at most the specified
#	limit of allocated (but unused) memory in memory pools. All free()
#	requests that exceed this limit will be handled by your malloc
#	library. Squid does not pre-allocate any memory, just safe-keeps
#	objects that otherwise would be free()d. Thus, it is safe to set
#	memory_pools_limit to a reasonably high value even if your
#	configuration will use less memory.
#	If set to zero, Squid will keep all memory it can. That is, there
#	will be no limit on the total amount of memory used for safe-keeping.
#	To disable memory allocation optimization, do not set
#	memory_pools_limit to 0. Set memory_pools to "off" instead.
#	An overhead for maintaining memory pools is not taken into account
#	when the limit is checked. This overhead is close to four bytes per
#	object kept. However, pools may actually _save_ memory because of
#	reduced memory thrashing in your malloc library.
#Default:
# memory_pools_limit 5 MB
#  TAG: via	on|off
#	If set (default), Squid will include a Via header in requests and
#	replies.
#Default:
# via on
#  TAG: forwarded_for	on|off
#	If set, Squid will include your system's IP address or name
#	in the HTTP requests it forwards.  By default it looks like
#	this:
#		X-Forwarded-For: 192.1.2.3
#	If you disable this, it will appear as
#		X-Forwarded-For: unknown
#Default:
# forwarded_for on
#  TAG: log_icp_queries	on|off
#	If set, ICP queries are logged to access.log. You may wish
#	do disable this if your ICP load is VERY high to speed things
#	up or to simplify log analysis.
#Default:
# log_icp_queries on
#  TAG: icp_hit_stale	on|off
#	If you want to return ICP_HIT for stale cache objects, set this
#	option to 'on'.  If you have sibling relationships with caches
#	in other administrative domains, this should be 'off'.  If you only
#	have sibling relationships with caches under your control,
#	it is probably okay to set this to 'on'.
#	If set to 'on', your siblings should use the option "allow-miss"
#	on their cache_peer lines for connecting to you.
#Default:
# icp_hit_stale off
#  TAG: minimum_direct_hops
#	If using the ICMP pinging stuff, do direct fetches for sites
#	which are no more than this many hops away.
#Default:
# minimum_direct_hops 4
#  TAG: minimum_direct_rtt
#	which are no more than this many rtt milliseconds away.
#Default:
# minimum_direct_rtt 400
#  TAG: cachemgr_passwd
#	Specify passwords for cachemgr operations.
#	Usage: cachemgr_passwd password action action ...
#	Some valid actions are (see cache manager menu for a full list):
#		5min
#		60min
#		asndb
#		authenticator
#		cbdata
#		client_list
#		comm_incoming
#		config *
#		counters
#		delay
#		digest_stats
#		dns
#		events
#		filedescriptors
#		fqdncache
#		histograms
#		http_headers
#		info
#		io
#		ipcache
#		mem
#		menu
#		netdb
#		non_peers
#		objects
#		offline_toggle *
#		pconn
#		peer_select
#		redirector
#		refresh
#		server_list
#		shutdown *
#		store_digest
#		storedir
#		utilization
#		via_headers
#		vm_objects
#	* Indicates actions which will not be performed without a
#	  valid password, others can be performed if not listed here.
#	To disable an action, set the password to "disable".
#	To allow performing an action without a password, set the
#	password to "none".
#	Use the keyword "all" to set the same password for all actions.
#Example:
# cachemgr_passwd secret shutdown
# cachemgr_passwd lesssssssecret info stats/objects
# cachemgr_passwd disable all
#Default:
# none
#  TAG: store_avg_object_size	(kbytes)
#	Average object size, used to estimate number of objects your
#	cache can hold.  The default is 13 KB.
#Default:
# store_avg_object_size 13 KB
#  TAG: store_objects_per_bucket
#	Target number of objects per bucket in the store hash table.
#	Lowering this value increases the total number of buckets and
#	also the storage maintenance rate.  The default is 50.
#Default:
# store_objects_per_bucket 20
#  TAG: client_db	on|off
#	If you want to disable collecting per-client statistics,
#	turn off client_db here.
#Default:
# client_db on
#  TAG: netdb_low
#  TAG: netdb_high
#	The low and high water marks for the ICMP measurement
#	database.  These are counts, not percents.  The defaults are
#	900 and 1000.  When the high water mark is reached, database
#	entries will be deleted until the low mark is reached.
#Default:
# netdb_low 900
# netdb_high 1000
#  TAG: netdb_ping_period
#	The minimum period for measuring a site.  There will be at
#	least this much delay between successive pings to the same
#	network.  The default is five minutes.
#Default:
# netdb_ping_period 5 minutes
#  TAG: query_icmp	on|off
#	If you want to ask your peers to include ICMP data in their ICP
#	replies, enable this option.
#	If your peer has configured Squid (during compilation) with
#	'--enable-icmp' that peer will send ICMP pings to origin server
#	sites of the URLs it receives.  If you enable this option the
#	ICP replies from that peer will include the ICMP data (if available).
#	Then, when choosing a parent cache, Squid will choose the parent with
#	the minimal RTT to the origin server.  When this happens, the
#	hierarchy field of the access.log will be
#	"CLOSEST_PARENT_MISS".  This option is off by default.
#Default:
# query_icmp off
#  TAG: test_reachability	on|off
#	When this is 'on', ICP MISS replies will be ICP_MISS_NOFETCH
#	instead of ICP_MISS if the target host is NOT in the ICMP
#	database, or has a zero RTT.
#Default:
# test_reachability off
#  TAG: buffered_logs	on|off
#	cache.log log file is written with stdio functions, and as such
#	it can be buffered or unbuffered. By default it will be unbuffered.
#	Buffering it can speed up the writing slightly (though you are
#	unlikely to need to worry unless you run with tons of debugging
#	enabled in which case performance will suffer badly anyway..).
#Default:
# buffered_logs off
#  TAG: reload_into_ims	on|off
#	When you enable this option, client no-cache or ``reload''
#	requests will be changed to If-Modified-Since requests.
#	Doing this VIOLATES the HTTP standard.  Enabling this
#	feature could make you liable for problems which it
#	causes.
#	see also refresh_pattern for a more selective approach.
#Default:
# reload_into_ims off
#  TAG: always_direct
#	Usage: always_direct allow|deny [!]aclname ...
#	Here you can use ACL elements to specify requests which should
#	ALWAYS be forwarded by Squid to the origin servers without using
#	any peers.  For example, to always directly forward requests for
#	local servers ignoring any parents or siblings you may have use
#	something like:
#		acl local-servers dstdomain my.domain.net
#		always_direct allow local-servers
#	To always forward FTP requests directly, use
#		acl FTP proto FTP
#		always_direct allow FTP
#	NOTE: There is a similar, but opposite option named
#	'never_direct'.  You need to be aware that "always_direct deny
#	foo" is NOT the same thing as "never_direct allow foo".  You
#	may need to use a deny rule to exclude a more-specific case of
#	some other rule.  Example:
#		acl local-external dstdomain external.foo.net
#		acl local-servers dstdomain  .foo.net
#		always_direct deny local-external
#	NOTE: If your goal is to make the client forward the request
#	directly to the origin server bypassing Squid then this needs
#	to be done in the client configuration. Squid configuration
#	can only tell Squid how Squid should fetch the object.
#	NOTE: This directive is not related to caching. The replies
#	is cached as usual even if you use always_direct. To not cache
#	the replies see no_cache.
#	This option replaces some v1.1 options such as local_domain
#	and local_ip.
#Default:
# none
#  TAG: never_direct
#	Usage: never_direct allow|deny [!]aclname ...
#	never_direct is the opposite of always_direct.  Please read
#	the description for always_direct if you have not already.
#	With 'never_direct' you can use ACL elements to specify
#	requests which should NEVER be forwarded directly to origin
#	servers.  For example, to force the use of a proxy for all
#	requests, except those in your local domain use something like:
#		acl all src 0.0.0.0/0.0.0.0
#		never_direct deny local-servers
#		never_direct allow all
#	or if Squid is inside a firewall and there are local intranet
#	servers inside the firewall use something like:
#		acl local-intranet dstdomain .foo.net
#		always_direct allow local-intranet
#	This option replaces some v1.1 options such as inside_firewall
#	and firewall_ip.
#Default:
# none
#  TAG: header_access
#	Usage: header_access header_name allow|deny [!]aclname ...
#	WARNING: Doing this VIOLATES the HTTP standard.  Enabling
#	this feature could make you liable for problems which it
#	causes.
#	This option replaces the old 'anonymize_headers' and the
#	older 'http_anonymizer' option with something that is much
#	more configurable. This new method creates a list of ACLs
#	for each header, allowing you very fine-tuned header
#	mangling.
#	You can only specify known headers for the header name.
#	Other headers are reclassified as 'Other'. You can also
#	refer to all the headers with 'All'.
#	For example, to achieve the same behavior as the old
#	'http_anonymizer standard' option, you should use:
#		header_access From deny all
#		header_access Referer deny all
#		header_access Server deny all
#		header_access User-Agent deny all
#		header_access WWW-Authenticate deny all
#		header_access Link deny all
#	Or, to reproduce the old 'http_anonymizer paranoid' feature
#	you should use:
#		header_access Allow allow all
#		header_access Authorization allow all
#		header_access WWW-Authenticate allow all
#		header_access Proxy-Authorization allow all
#		header_access Proxy-Authenticate allow all
#		header_access Cache-Control allow all
#		header_access Content-Encoding allow all
#		header_access Content-Length allow all
#		header_access Content-Type allow all
#		header_access Date allow all
#		header_access Expires allow all
#		header_access Host allow all
#		header_access If-Modified-Since allow all
#		header_access Last-Modified allow all
#		header_access Location allow all
#		header_access Pragma allow all
#		header_access Accept allow all
#		header_access Accept-Charset allow all
#		header_access Accept-Encoding allow all
#		header_access Accept-Language allow all
#		header_access Content-Language allow all
#		header_access Mime-Version allow all
#		header_access Retry-After allow all
#		header_access Title allow all
#		header_access Connection allow all
#		header_access Proxy-Connection allow all
#		header_access All deny all
#	By default, all headers are allowed (no anonymizing is
#	performed).
#Default:
# none
#  TAG: header_replace
#	Usage:   header_replace header_name message
#	Example: header_replace User-Agent Nutscrape/1.0 (CP/M; 8-bit)
#	This option allows you to change the contents of headers
#	denied with header_access above, by replacing them with
#	some fixed string. This replaces the old fake_user_agent
#	option.
#	By default, headers are removed if denied.
#Default:
# none
#  TAG: icon_directory
#	Where the icons are stored. These are normally kept in
#	/usr/share/squid/icons
#Default:
# icon_directory /usr/share/squid/icons
#  TAG: global_internal_static
#	This directive controls is Squid should intercept all requests for
#	/squid-internal-static/ no matter which host the URL is requesting
#	(default on setting), or if nothing special should be done for
#	such URLs (off setting). The purpose of this directive is to make
#	icons etc work better in complex cache hierarchies where it may
#	not always be possible for all corners in the cache mesh to reach
#	the server generating a directory listing.
#Default:
# global_internal_static on
#  TAG: short_icon_urls
#	If this is enabled Squid will use short URLs for icons.
#	If off the URLs for icons will always be absolute URLs
#	including the proxy name and port.
#Default:
# short_icon_urls off
#  TAG: error_directory
#	If you wish to create your own versions of the default
#	(English) error files, either to customize them to suit your
#	language or company copy the template English files to another
#	directory and point this tag at them.
#Default:
# error_directory /usr/share/squid/errors/English
#  TAG: maximum_single_addr_tries
#	This sets the maximum number of connection attempts for a
#	host that only has one address (for multiple-address hosts,
#	each address is tried once).
#	The default value is one attempt, the (not recommended)
#	maximum is 255 tries.  A warning message will be generated
#	if it is set to a value greater than ten.
#	Note: This is in addition to the request re-forwarding which
#	takes place if Squid fails to get a satisfying response.
#Default:
# maximum_single_addr_tries 1
#  TAG: retry_on_error
#	If set to on Squid will automatically retry requests when
#	receiving an error response. This is mainly useful if you
#	are in a complex cache hierarchy to work around access
#	control errors.
#Default:
# retry_on_error off
#  TAG: snmp_port
#	Squid can now serve statistics and status information via SNMP.
#	By default it listens to port 3401 on the machine. If you don't
#	wish to use SNMP, set this to "0".
#	Note: on Debian/Linux, the default is zero - you need to
#	set it to 3401 to enable it.
#Default:
# snmp_port 0
#  TAG: snmp_access
#	Allowing or denying access to the SNMP port.
#	All access to the agent is denied by default.
#	usage:
#	snmp_access allow|deny [!]aclname ...
#Example:
# snmp_access allow snmppublic localhost
# snmp_access deny all
#Default:
#  TAG: snmp_incoming_address
#  TAG: snmp_outgoing_address
#	Just like 'udp_incoming_address' above, but for the SNMP port.
#	snmp_incoming_address	is used for the SNMP socket receiving
#				messages from SNMP agents.
#	snmp_outgoing_address	is used for SNMP packets returned to SNMP
#				agents.
#	The default snmp_incoming_address (0.0.0.0) is to listen on all
#	available network interfaces.
#	If snmp_outgoing_address is set to 255.255.255.255 (the default)
#	it will use the same socket as snmp_incoming_address. Only
#	change this if you want to have SNMP replies sent using another
#	address than where this Squid listens for SNMP queries.
#	NOTE, snmp_incoming_address and snmp_outgoing_address can not have
#	the same value since they both use port 3401.
#Default:
# snmp_incoming_address 0.0.0.0
# snmp_outgoing_address 255.255.255.255
#  TAG: as_whois_server
#	WHOIS server to query for AS numbers.  NOTE: AS numbers are
#	queried only when Squid starts up, not for every request.
#Default:
# as_whois_server whois.ra.net
#  TAG: wccp_router
#  TAG: wccp2_router
#	Use this option to define your WCCP ``home'' router for
#	Squid.
#	wccp_router supports a single WCCP(v1) router
#	wccp2_router supports multiple WCCPv2 routers
#	only one of the two may be used at the same time and defines
#	which version of WCCP to use.
#Default:
# wccp_router 0.0.0.0
#  TAG: wccp_version
#	This directive is only relevant if you need to set up WCCP(v1)
#	to some very old and end-of-life Cisco routers. In all other
#	setups it must be left unset or at the default setting.
#	It defines an internal version in the WCCP(v1) protocol,
#	with version 4 being the officially documented protocol.
#	According to some users, Cisco IOS 11.2 and earlier only
#	support WCCP version 3.  If you're using that or an earlier
#	version of IOS, you may need to change this value to 3, otherwise
#	do not specify this parameter.
#Default:
# wccp_version 4
#  TAG: wccp2_rebuild_wait
#	If this is enabled Squid will wait for the cache dir rebuild to finish
#	before sending the first wccp2 HereIAm packet
#Default:
# wccp2_rebuild_wait on
#  TAG: wccp2_forwarding_method
#	WCCP2 allows the setting of forwarding methods between the
#	router/switch and the cache.  Valid values are as follows:
#	1 - GRE encapsulation (forward the packet in a GRE/WCCP tunnel)
#	2 - L2 redirect (forward the packet using Layer 2/MAC rewriting)
#	Currently (as of IOS 12.4) cisco routers only support GRE.
#	Cisco switches only support the L2 redirect assignment method.
#Default:
# wccp2_forwarding_method 1
#  TAG: wccp2_return_method
#	WCCP2 allows the setting of return methods between the
#	router/switch and the cache for packets that the cache
#	decides not to handle.  Valid values are as follows:
#	Cisco switches only support the L2 redirect assignment.
#	If the "ip wccp redirect exclude in" command has been
#	enabled on the cache interface, then it is still safe for
#	the proxy server to use a l2 redirect method even if this
#	option is set to GRE.
#Default:
# wccp2_return_method 1
#  TAG: wccp2_assignment_method
#	WCCP2 allows the setting of methods to assign the WCCP hash
#	Valid values are as follows:
#	1 - Hash assignment
#	2 - Mask assignment
#	As a general rule, cisco routers support the hash assignment method
#	and cisco switches support the mask assignment method.
#Default:
# wccp2_assignment_method 1
#  TAG: wccp2_service
#	WCCP2 allows for multiple traffic services. There are two
#	types: "standard" and "dynamic". The standard type defines
#	one service id - http (id 0). The dynamic service ids can be from
#	51 to 255 inclusive.  In order to use a dynamic service id
#	one must define the type of traffic to be redirected; this is done
#	using the wccp2_service_info option.
#	The "standard" type does not require a wccp2_service_info option,
#	just specifying the service id will suffice.
#	MD5 service authentication can be enabled by adding
#	"password=<password>" to the end of this service declaration.
#	Examples:
#	wccp2_service standard 0	# for the 'web-cache' standard service
#	wccp2_service dynamic 80	# a dynamic service type which will be
#					# fleshed out with subsequent options.
#	wccp2_service standard 0 password=foo
#Default:
#  TAG: wccp2_service_info
#	Dynamic WCCPv2 services require further information to define the
#	traffic you wish to have diverted.
#	The format is:
#	wccp2_service_info <id> protocol=<protocol> flags=<flag>,<flag>..
#	    priority=<priority> ports=<port>,<port>..
#	The relevant WCCPv2 flags:
#	+ src_ip_hash, dst_ip_hash
#	+ source_port_hash, dest_port_hash
#	+ src_ip_alt_hash, dst_ip_alt_hash
#	+ src_port_alt_hash, dst_port_alt_hash
#	+ ports_source
#	The port list can be one to eight entries.
#	Example:
#	wccp2_service_info 80 protocol=tcp flags=src_ip_hash,ports_source
#	    priority=240 ports=80
#	Note: the service id must have been defined by a previous
#	'wccp2_service dynamic <id>' entry.
#Default:
# none
#  TAG: wccp2_weight
#	Each cache server gets assigned a set of the destination
#	hash proportional to their weight.
#Default:
# wccp2_weight 10000
#  TAG: wccp_address
#  TAG: wccp2_address
#	Use this option if you require WCCP to use a specific
#	interface address.
#	The default behavior is to not bind to any specific address.
#Default:
# wccp_address 0.0.0.0
# wccp2_address 0.0.0.0
# DELAY POOL PARAMETERS (all require DELAY_POOLS compilation option)
#  TAG: delay_pools
#	This represents the number of delay pools to be used.  For example,
#	if you have one class 2 delay pool and one class 3 delays pool, you
#	have a total of 2 delay pools.
#Default:
# delay_pools 0
#  TAG: delay_class
#	This defines the class of each delay pool.  There must be exactly one
#	delay_class line for each delay pool.  For example, to define two
#	delay pools, one of class 2 and one of class 3, the settings above
#	and here would be:
#Example:
# delay_pools 2      # 2 delay pools
# delay_class 1 2    # pool 1 is a class 2 pool
# delay_class 2 3    # pool 2 is a class 3 pool
#	The delay pool classes are:
#		class 1		Everything is limited by a single aggregate
#				bucket.
#		class 2 	Everything is limited by a single aggregate
#				bucket as well as an "individual" bucket chosen
#				from bits 25 through 32 of the IP address.
#		class 3		Everything is limited by a single aggregate
#				bucket as well as a "network" bucket chosen
#				from bits 17 through 24 of the IP address and a
#				"individual" bucket chosen from bits 17 through
#				32 of the IP address.
#	NOTE: If an IP address is a.b.c.d
#		-> bits 25 through 32 are "d"
#		-> bits 17 through 24 are "c"
#		-> bits 17 through 32 are "c * 256 + d"
#Default:
# none
#  TAG: delay_access
#	This is used to determine which delay pool a request falls into.
#	delay_access is sorted per pool and the matching starts with pool 1,
#	then pool 2, ..., and finally pool N. The first delay pool where the
#	request is allowed is selected for the request. If it does not allow
#	the request to any pool then the request is not delayed (default).
#	For example, if you want some_big_clients in delay
#	pool 1 and lotsa_little_clients in delay pool 2:
#Example:
# delay_access 1 allow some_big_clients
# delay_access 1 deny all
# delay_access 2 allow lotsa_little_clients
# delay_access 2 deny all
#Default:
# none
#  TAG: delay_parameters
#	This defines the parameters for a delay pool.  Each delay pool has
#	a number of "buckets" associated with it, as explained in the
#	description of delay_class.  For a class 1 delay pool, the syntax is:
#delay_parameters pool aggregate
#	For a class 2 delay pool:
#delay_parameters pool aggregate individual
#	For a class 3 delay pool:
#delay_parameters pool aggregate network individual
#	The variables here are:
#		pool		a pool number - ie, a number between 1 and the
#				number specified in delay_pools as used in
#				delay_class lines.
#		aggregate	the "delay parameters" for the aggregate bucket
#				(class 1, 2, 3).
#		individual	the "delay parameters" for the individual
#				buckets (class 2, 3).
#		network		the "delay parameters" for the network buckets
#				(class 3).
#	A pair of delay parameters is written restore/maximum, where restore is
#	the number of bytes (not bits - modem and network speeds are usually
#	quoted in bits) per second placed into the bucket, and maximum is the
#	maximum number of bytes which can be in the bucket at any time.
#	For example, if delay pool number 1 is a class 2 delay pool as in the
#	above example, and is being used to strictly limit each host to 64kbps
#	(plus overheads), with no overall limit, the line is:
#delay_parameters 1 -1/-1 8000/8000
#	Note that the figure -1 is used to represent "unlimited".
#	And, if delay pool number 2 is a class 3 delay pool as in the above
#	example, and you want to limit it to a total of 256kbps (strict limit)
#	with each 8-bit network permitted 64kbps (strict limit) and each
#	individual host permitted 4800bps with a bucket maximum size of 64kb
#	to permit a decent web page to be downloaded at a decent speed
#	(if the network is not being limited due to overuse) but slow down
#	large downloads more significantly:
#delay_parameters 2 32000/32000 8000/8000 600/8000
#	There must be one delay_parameters line for each delay pool.
#Default:
# none
#  TAG: delay_initial_bucket_level	(percent, 0-100)
#	The initial bucket percentage is used to determine how much is put
#	in each bucket when squid starts, is reconfigured, or first notices
#	a host accessing it (in class 2 and class 3, individual hosts and
#	networks only have buckets associated with them once they have been
#	"seen" by squid).
#Default:
# delay_initial_bucket_level 50
#  TAG: incoming_icp_average
#  TAG: incoming_http_average
#  TAG: incoming_dns_average
#  TAG: min_icp_poll_cnt
#  TAG: min_dns_poll_cnt
#  TAG: min_http_poll_cnt
#	Heavy voodoo here.  I can't even believe you are reading this.
#	Are you crazy?  Don't even think about adjusting these unless
#	you understand the algorithms in comm_select.c first!
#Default:
# incoming_icp_average 6
# incoming_http_average 4
# incoming_dns_average 4
# min_icp_poll_cnt 8
# min_dns_poll_cnt 8
# min_http_poll_cnt 8
#  TAG: max_open_disk_fds
#	To avoid having disk as the I/O bottleneck Squid can optionally
#	bypass the on-disk cache if more than this amount of disk file
#	descriptors are open.
#	A value of 0 indicates no limit.
#Default:
# max_open_disk_fds 0
#  TAG: offline_mode
#	Enable this option and Squid will never try to validate cached
#	objects.
#Default:
# offline_mode off
#  TAG: uri_whitespace
#	What to do with requests that have whitespace characters in the
#	URI.  Options:
#	strip:  The whitespace characters are stripped out of the URL.
#		This is the behavior recommended by RFC2396.
#	deny:   The request is denied.  The user receives an "Invalid
#		Request" message.
#	allow:  The request is allowed and the URI is not changed.  The
#		whitespace characters remain in the URI.  Note the
#		whitespace is passed to redirector processes if they
#		are in use.
#	encode:	The request is allowed and the whitespace characters are
#		encoded according to RFC1738.  This could be considered
#		a violation of the HTTP/1.1
#		RFC because proxies are not allowed to rewrite URI's.
#	chop:	The request is allowed and the URI is chopped at the
#		first whitespace.  This might also be considered a
#		violation.
#Default:
# uri_whitespace strip
#  TAG: broken_posts
#	A list of ACL elements which, if matched, causes Squid to send
#	an extra CRLF pair after the body of a PUT/POST request.
#	Some HTTP servers has broken implementations of PUT/POST,
#	and rely on an extra CRLF pair sent by some WWW clients.
#	Quote from RFC2068 section 4.1 on this matter:
#	  Note: certain buggy HTTP/1.0 client implementations generate an
#	  extra CRLF's after a POST request. To restate what is explicitly
#	  forbidden by the BNF, an HTTP/1.1 client must not preface or follow
#	  a request with an extra CRLF.
#Example:
# acl buggy_server url_regex ^http://....
# broken_posts allow buggy_server
#Default:
# none
#  TAG: mcast_miss_addr
#       --enable-multicast-miss option
#	If you enable this option, every "cache miss" URL will
#	be sent out on the specified multicast address.
#	Do not enable this option unless you are are absolutely
#	certain you understand what you are doing.
#Default:
# mcast_miss_addr 255.255.255.255
#  TAG: mcast_miss_ttl
#	This is the time-to-live value for packets multicasted
#	when multicasting off cache miss URLs is enabled.  By
#	default this is set to 'site scope', i.e. 16.
#Default:
# mcast_miss_ttl 16
#  TAG: mcast_miss_port
#	This is the port number to be used in conjunction with
#	'mcast_miss_addr'.
#Default:
# mcast_miss_port 3135
#  TAG: mcast_miss_encode_key
#	The URLs that are sent in the multicast miss stream are
#	encrypted.  This is the encryption key.
#Default:
# mcast_miss_encode_key XXXXXXXXXXXXXXXX
#  TAG: nonhierarchical_direct
#	By default, Squid will send any non-hierarchical requests
#	(matching hierarchy_stoplist or not cacheable request type) direct
#	to origin servers.
#	If you set this to off, Squid will prefer to send these
#	requests to parents.
#	Note that in most configurations, by turning this off you will only
#	add latency to these request without any improvement in global hit
#	ratio.
#	If you are inside an firewall see never_direct instead of
#	this directive.
#Default:
# nonhierarchical_direct on
#  TAG: prefer_direct
#	Normally Squid tries to use parents for most requests. If you for some
#	reason like it to first try going direct and only use a parent if
#	going direct fails set this to on.
#	By combining nonhierarchical_direct off and prefer_direct on you
#	can set up Squid to use a parent as a backup path if going direct
#	fails.
#	Note: If you want Squid to use parents for all requests see
#	the never_direct directive. prefer_direct only modifies how Squid
#	acts on cacheable requests.
#Default:
# prefer_direct off
#  TAG: strip_query_terms
#	By default, Squid strips query terms from requested URLs before
#	logging.  This protects your user's privacy.
#Default:
# strip_query_terms on
#  TAG: coredump_dir
#	By default Squid leaves core files in the directory from where
#	it was started. If you set 'coredump_dir' to a directory
#	that exists, Squid will chdir() to that directory at startup
#	and coredump files will be left there.
#Default:
# coredump_dir none
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
#  TAG: redirector_bypass
#	When this is 'on', a request will not go through the
#	redirector if all redirectors are busy.  If this is 'off'
#	and the redirector queue grows too large, Squid will exit
#	with a FATAL error and ask you to increase the number of
#	redirectors.  You should only enable this if the redirectors
#	are not critical to your caching system.  If you use
#	redirectors for access control, and you enable this option,
#	users may have access to pages they should not
#	be allowed to request.
#Default:
# redirector_bypass off
#  TAG: ignore_unknown_nameservers
#	By default Squid checks that DNS responses are received
#	from the same IP addresses they are sent to.  If they
#	don't match, Squid ignores the response and writes a warning
#	message to cache.log.  You can allow responses from unknown
#	nameservers by setting this option to 'off'.
#Default:
# ignore_unknown_nameservers on
#  TAG: digest_generation
#	This controls whether the server will generate a Cache Digest
#	of its contents.  By default, Cache Digest generation is
#	enabled if Squid is compiled with USE_CACHE_DIGESTS defined.
#Default:
# digest_generation on
#  TAG: digest_bits_per_entry
#	This is the number of bits of the server's Cache Digest which
#	will be associated with the Digest entry for a given HTTP
#	Method and URL (public key) combination.  The default is 5.
#Default:
# digest_bits_per_entry 5
#  TAG: digest_rebuild_period	(seconds)
#	This is the number of seconds between Cache Digest rebuilds.
#Default:
# digest_rebuild_period 1 hour
#  TAG: digest_rewrite_period	(seconds)
#	This is the number of seconds between Cache Digest writes to
#	disk.
#Default:
# digest_rewrite_period 1 hour
#  TAG: digest_swapout_chunk_size	(bytes)
#	This is the number of bytes of the Cache Digest to write to
#	disk at a time.  It defaults to 4096 bytes (4KB), the Squid
#	default swap page.
#Default:
# digest_swapout_chunk_size 4096 bytes
#  TAG: digest_rebuild_chunk_percentage	(percent, 0-100)
#	This is the percentage of the Cache Digest to be scanned at a
#	time.  By default it is set to 10% of the Cache Digest.
#Default:
# digest_rebuild_chunk_percentage 10
#  TAG: chroot
#	Use this to have Squid do a chroot() while initializing.  This
#	also causes Squid to fully drop root privileges after
#	initializing.  This means, for example, that if you use a HTTP
#	port less than 1024 and try to reconfigure, you will get an
#	error.
#Default:
# none
#  TAG: client_persistent_connections
#  TAG: server_persistent_connections
#	Persistent connection support for clients and servers.  By
#	default, Squid uses persistent connections (when allowed)
#	with its clients and servers.  You can use these options to
#	disable persistent connections with clients and/or servers.
#Default:
# client_persistent_connections on
# server_persistent_connections on
#  TAG: persistent_connection_after_error
#	With this directive the use of persistent connections after
#	HTTP errors can be disabled. Useful if you have clients
#	who fail to handle errors on persistent connections proper.
#Default:
# persistent_connection_after_error off
#  TAG: detect_broken_pconn
#	Some servers have been found to incorrectly signal the use
#	of HTTP/1.0 persistent connections even on replies not
#	compatible, causing significant delays. This server problem
#	has mostly been seen on redirects.
#	By enabling this directive Squid attempts to detect such
#	broken replies and automatically assume the reply is finished
#	after 10 seconds timeout.
#Default:
# detect_broken_pconn off
#  TAG: balance_on_multiple_ip
#	Some load balancing servers based on round robin DNS have been
#	found not to preserve user session state across requests
#	to different IP addresses.
#	By default Squid rotates IP's per request. By disabling
#	this directive only connection failure triggers rotation.
#Default:
# balance_on_multiple_ip on
#  TAG: pipeline_prefetch
#	To boost the performance of pipelined requests to closer
#	match that of a non-proxied environment Squid can try to fetch
#	up to two requests in parallel from a pipeline.
#	Defaults to off for bandwidth management and access logging
#	reasons.
#Default:
# pipeline_prefetch off
#  TAG: extension_methods
#	Squid only knows about standardized HTTP request methods.
#	You can add up to 20 additional "extension" methods here.
#Default:
# none
#  TAG: request_entities
#	Squid defaults to deny GET and HEAD requests with request entities,
#	as the meaning of such requests are undefined in the HTTP standard
#	even if not explicitly forbidden.
#	Set this directive to on if you have clients which insists
#	on sending request entities in GET or HEAD requests. But be warned
#	that there is server software (both proxies and web servers) which
#	can fail to properly process this kind of request which may make you
#	vulnerable to cache pollution attacks if enabled.
#Default:
# request_entities off
#  TAG: high_response_time_warning	(msec)
#	If the one-minute median response time exceeds this value,
#	Squid prints a WARNING with debug level 0 to get the
#	administrators attention.  The value is in milliseconds.
#Default:
# high_response_time_warning 0
#  TAG: high_page_fault_warning
#	If the one-minute average page fault rate exceeds this
#	value, Squid prints a WARNING with debug level 0 to get
#	the administrators attention.  The value is in page faults
#	per second.
#Default:
# high_page_fault_warning 0
#  TAG: high_memory_warning
#	If the memory usage (as determined by mallinfo) exceeds
#Default:
# high_memory_warning 0
#  TAG: store_dir_select_algorithm
#	Set this to 'round-robin' as an alternative.
#Default:
# store_dir_select_algorithm least-load
#  TAG: forward_log
#       --enable-forward-log option
#	Logs the server-side requests.
#	This is currently work in progress.
#Default:
# none
#  TAG: ie_refresh	on|off
#	Microsoft Internet Explorer up until version 5.5 Service
#	Pack 1 has an issue with transparent proxies, wherein it
#	is impossible to force a refresh.  Turning this on provides
#	a partial fix to the problem, by causing all IMS-REFRESH
#	requests from older IE versions to check the origin server
#	for fresh content.  This reduces hit ratio by some amount
#	(~10% in my experience), but allows users to actually get
#	fresh content when they want it.  Note that because Squid
#	cannot tell if the user is using 5.5 or 5.5SP1, the behavior
#	of 5.5 is unchanged from old versions of Squid (i.e. a
#	forced refresh is impossible).  Newer versions of IE will,
#	hopefully, continue to have the new behavior and will be
#	handled based on that assumption.  This option defaults to
#	the old Squid behavior, which is better for hit ratios but
#	worse for clients using IE, if they need to be able to
#	force fresh content.
#Default:
# ie_refresh off
#  TAG: vary_ignore_expire	on|off
#	Many HTTP servers supporting Vary gives such objects
#	immediate expiry time with no cache-control header
#	when requested by a HTTP/1.0 client. This option
#	enables Squid to ignore such expiry times until
#	HTTP/1.1 is fully implemented.
#	WARNING: This may eventually cause some varying
#	objects not intended for caching to get cached.
#Default:
# vary_ignore_expire off
#  TAG: sleep_after_fork	(microseconds)
#	When this is set to a non-zero value, the main Squid process
#	sleeps the specified number of microseconds after a fork()
#	system call. This sleep may help the situation where your
#	system reports fork() failures due to lack of (virtual)
#	memory. Note, however, that if you have a lot of child
#	processes, these sleep delays will add up and your
#	Squid will not service requests for some amount of time
#	until all the child processes have been started.
#	On Windows value less then 1000 (1 milliseconds) are
#	rounded to 1000.
#Default:
# sleep_after_fork 0
#  TAG: minimum_expiry_time	(seconds)
#	The minimum caching time according to (Expires - Date)
#	Headers Squid honors if the object can't be revalidated
#	defaults to 60 seconds. In reverse proxy enorinments it
#	might be desirable to honor shorter object lifetimes. It
#	is most likely better to make your server return a
#	meaningful Last-Modified header however.
#Default:
# minimum_expiry_time 60 seconds
#  TAG: relaxed_header_parser	on|off|warn
#	In the default "on" setting Squid accepts certain forms
#	of non-compliant HTTP messages where it is unambiguous
#	what the sending application intended even if the message
#	is not correctly formatted. The messages is then normalized
#	to the correct form when forwarded by Squid.
#	If set to "warn" then a warning will be emitted in cache.log
#	each time such HTTP error is encountered.
#	If set to "off" then such HTTP errors will cause the request
#	or response to be rejected.
#Default:
# relaxed_header_parser on
visible_hostname 10.135.225.5
unique_hostname 10.135.225.5
my squidgaurd.conf
Code:
# CONFIG FILE FOR SQUIDGUARD
dbhome /var/lib/squidguard/db
logdir /var/log/squid
# TIME RULES:
# abbrev for weekdays:
# s = sun, m = mon, t =tue, w = wed, h = thu, f = fri, a = sat
time workhours {
	weekly mtwhf 08:00 - 16:30
	date *-*-01  08:00 - 16:30
# REWRITE RULES:
#rew dmz {
#	s@://admin/@://admin.foo.bar.no/@i
#	s@://foo.bar.no/@://www.foo.bar.no/@i
# SOURCE ADDRESSES:
#src admin {
#	ip		1.2.3.4 1.2.3.5
#	user		root foo bar
#	within 		workhours
#src foo-clients {
#	ip		172.16.2.32-172.16.2.100 172.16.2.100 172.16.2.200
#src bar-clients {
#	ip		172.16.4.0/26
# DESTINATION CLASSES:
dest good {
dest local {
dest porn {
        domainlist porn/domains
        urllist porn/urls
#dest adult {
#	domainlist	adult/domains
#	urllist		adult/urls
#	expressionlist	adult/expressions
#	redirect 	http://admin.foo.bar.no/cgi-bin/squidGuard.cgi?clientaddr=%a+clientname=%n+clientident=%i+srcclass=%s+targetclass=%t+url=%u
acl {
        default {
                pass !porn all
                redirect http://localhost/block.html
#	admin {
#		pass	 any
#	foo-clients within workhours {
#		pass	 good !in-addr !adult any
#	} else {
#		pass any
#	bar-clients {
#		pass	local none
	default {
		pass	 local none
#		rewrite	 dmz
I'm going to cry ! I need to block porn on the network!!! :bday:
