Hi guys,
Spec:
M4A88T-M Motherboard
AMD 960T Black Edition
Corsair Hydro series H80
OCZ Stealth Xstream II 600W PSU
HD 6870 GPU
Kingston 8GB (2x4GB) DDR3 1600Mhzs HyperX CL9 1.65
My computer seems to run fine 24x7 until I start to play games. What happens in that after a period of intensive usage is that it eventually restarts with an 0x124 error (hardware fault) after about an hour.
Now the weird thing is that when I swapped RAM slots from blue to black (Asus recommends putting the RAM in the blue slots for overclocking purposes), the system runs with more stability, in that it takes quite a while longer to get to the 0x124 BSOD.
Initially I thought the problem was due to the graphics card since the error occurs whilst playing games, trying all possible driver combinations did not lead to the error though, and the BSOD does not mention any system files relating to the ATI driver. Also, the error occurs whilst doing a context switch of some kind, (like alt-tabbing mid-game or clicking a UI button) which is why I thought it may be a RAM issue.
The RAM is set to 1600 in the BIOS, and the clock timings are those recommended by ASUS, 9-9-9-9-27 with 1.65v voltage (I bumped the voltage from 1.5v, however at 1.5v I was still getting this crash).
So I clocked my RAM down from 1600 to 1333 and set all to auto and still got the error.
Running memtest86 on the RAM overnight revealed no apparent errors.
I also set the NB frequency to 2400mhz (3xDRAM freq) but this didn't stabilise anything.
Now I'm kind of at a loss as to what the error could be, but I suspect that the memory controller in the CPU may be causing the fault (since apparently 980t supports only 1333mhz RAM ??).
Is there some way of verifying / stabilising the CPU memory controller, or does anyone have any better ideas?
Thanks in advance
Spec:
HD 6870 GPU
Thanks in advance
