- Dec 8, 2003
Yeah just downloaded it and tried it out, seems pretty good. Non stop action guns blazing and stuff exploding, heard it has multiplayer too...I wonder if it will have COOP?
RedDragonXXX said:Great, one game I have been looking forward to playing on my 360 and the day demo comes out my console gets the red ring of death
I wonder how thats supposed to work, something to do with it overheating it to the point the heatsink fuses to the GPU somehow improving cooling and making baby 360 all better? Im not denying that it works, just wondering how.rainless said:Wrap it in a towel and turn it on for half an hour or so. I've seen video of that working (and it this point it couldn't hurt now could it?)
freakdiablo said:I wonder how thats supposed to work, something to do with it overheating it to the point the heatsink fuses to the GPU somehow improving cooling and making baby 360 all better? Im not denying that it works, just wondering how.
Links to demo?
12am said:I've done the towel trick and it only worked for a total of 5 mins before my 360 was bricked again, so you can try it but don't hold your breath or be excited when your 360 turns back on after. Apparently what is happening when you do this is heating the board and chipsets up so much that the solder remelts and temporarily fuses the components back together for a short while, some people have had weeks of sucess from this trick while others got nothing, and as I said I got 5 more mins use by this trick.. hardly worth the 30 mins it takes to do this trick from start to finish in my books.
12am said:Be carefull of them replacement plans, I went through best buy on my first 360 and it was carefully written that if they could *not* repair it they would exchange it for me wich of course microsoft will repair every 360 with the red ring error, therefore making best buy's replacement plan garbage and a total money waste seeing as they will just send it away for you... needless to say I just bought another 360 core system and put my old hd in, and told best buy they could stick thier replacement plan where the sun didn't shine lol.
rainless said:That's why banging on the side of the 360 also seems to help. It's just a matter of flattening the motherboard.
FudgeNuggets said:Rainman, the artifacting issue is caused by the GPU getting too hot.
OC Noob said:Yeah, definitely have to get the replacement warrenties were you swap your broken for a new unit like the game stores offer regardless of the issue/repair.
ps people think the problem is the heat cause conections between the mobo and cpu to separate and by overheating with the towel trick it softens the solder enough to reconnect the... connections between mobo and cpu. Some people say the connections go bad due to heat and some say the board warps causing it. All I know is that I don't know why or what happens, but the theories sound good
maxio098ui said:i was always in doubt of strangle hold but it might be cool. i was always scared of it going like that game based in la and after in new york. i just cant get the name atm.
12am said:Due to the high failure rates of the 360 alot of retailers aren't offering direct swap replacement plans for 360's anymore due to the large turnovers and losses they have had to incur. Personally in my area all the EBGames stores will now refuse you replacement plans on 360's, but that's a story for generous other threads lol...
Back to the topic, stranglehold always seemed to have clunky controls from the vids I've seen, very similar as to how dead to rights felt from the XBOX days. Does Stranglehold feel similar or am I crazy?
rainless said:How can you tell what the controls are like by watching a video?
Anyway... "No." The controls aren't clunky at all. I believe they spend 80% of their time working on the controls and it shows. You sort of get a mini-lock on targets you're in the general direction of aiming at (a-la Doom. Why don't more games have this these days?) But you also have a lot of extra control when you need it.
I think the only way to play Stranglehold is either on Hard or Hard-boiled. Otherwise you have no idea what the game is really about. (The importance of using the environment against your enemies. The importance of taking cover and then fleeing that cover. Using the special techniques to your advantage.)
The ambush in the market is a good example of this. On casual and normal you can just walk through it. On Hard and Hard-Boiled it takes an incredible amount of technique just to survive.
