Success OC with 2400+ and 8RDA
EluSiOn
SC, USA
BIOS Setting
Multiplier: 11.5x
FSB: 219mhz SYNC with Memory running DCDDR
Memory Timing: CAS 2.0-5-2-2
CPU Interface: Optimal
Vcore: 1.95v
Vdmm: 2.90v
VDD: 1.80v (VDD modified)
AGP Voltage: 1.60v
Hardware Setup
Mobo: Epox 8RDA
CPU: AMD 2400+ XP 2.0ghz AIUGB 0244
RAM: Corsair XMS PC3500C2 256mb x2
Video Card: Asus GeForce Ti4200 128mb AGP 8X
PSU: Sparkle 400w
Cooling Setup
White Water CPU Water Block
Z-Chip North Bridge Water Block
Eheim 1250 pump
RAMSINK x3 + 40mm FAN on the 6 MOSFET
CPU temp is within 12c of ambient temp when loaded.
¢XC/W Value = 12c / 123.75w = 0.097(unreal because no WB can have lower than 0.20 ¢XC/W Value yet, probably because 8RDA's temp sensor is in socket instead of on diode)
Reference C/W value: http://www.benchtest.com/calc.html
3dmarks score URL: http://service.futuremark.com/compare?2k1=5755141
Before VDD Mod: 205mhz for FSB
After VDD Mod: 210mhz for FSB
After putting RAMSINK & 40 MM Fan on MOSFETS: 219mhz FSB
BIOS version: 8RD12C06.BIN (8RD13117.BIN is unstable for me)
This is the setting I am running 24/7 and not just for one time benchmark setup (for one time benchmark setup I can do 11.5x224mhz @ 2.15vcore but I am nervours about killing my CPU at that high Voltage so I down clock to 219mhz)
I follow the vddmod thread did that vdd mod, but I didn't solder. I use two SMD Grabbers instead. I used SMD Grabber so VDD mod is easy. I mess up my 8RDA+ when I tried to solder the POTS onto the mobo.
The POT
The SMD Grabber
The Pots is 1K ohm from Radio Shack and I set it at 700 ohm which gives me 1.80v for VDD
