- Dec 28, 2001
- Corner of No and Where
All the theories and standard practices have exceptions
Thats what experimentation is for, after all....
icedog9999-
7 exhaust fans is probaly hurting your temps more than helping: balanced (or close to it) airflow is usually best. With 7 fans on exhaust and no intake, right now you are trying to remove air that can't get into the case, essentially.
What usually works best is intake low in front and exhaust high in back. Try it and I bet your case temps go down and bring the cpu temp down at the same time....
The exact placement and number of fans doing intake or exhaust is vey subjective: what works for one may not work as well in another case; again, this is why we experiment.
When trying different cooling ideas out I track all temps and try one change at a time: narrows down the possibilities of which change does what to my temps.
Also- cardboard and duct tape are your friends they work wonders for making test case pieces while you experiment and the cardboard can be used as a template if and when you need to mod case panels.
icedog9999-
