Was wondering if I could get a possible price for this. I'd personally would rather buy a prebuilt computer instead of buying the parts and trying to assemble myself (even with help). If I do assemble, EVERY part should come from Newegg or Tiger (or you all can suggest other good sites)
Hardware
- USB 2.0 speeds that are minimum of 30 MB a second
- USB 3.0 speeds that are at lest 300+ MB/s
- Windows Experience Index of at lest 5.0 (minimum)* -- Although if 6.0 min could be possible, fine or even 7.
- Firewire (and or eSata port) --- because I have a external hardrive that has both along with USB
- At lest a solid terabyte (1.5 TB)
- Has either a VGA or DVI port (current monitor I have has both)
- Also has support for HDMI (for the future monitor)
- Multicard reader (although I mainly need SD and Memory Pro Stick Duo)
- Able to use a PS3 controller AND A XBOX 360 controller (and it if possible all of Wii's main controllers)
- I would like a quad core, would hex make much difference in real performance?
- Multiple internal DVD drives (mostly to spend less time swapping discs when installing games).
Software
- Windows 7 Ultimate (64 bit) (Main OS)
- Windows 7 Ultimate 32 bit (if needed)
- Windows XP (if 64 bit won't run some of the games I have) (if needed)
- Folding@home (although I use my PS3 for that when I'm not using it)
- Able to run most games from DOS era on, probably high settings
Gaming Software:
- Will use steam:
-- Elder Scrolls
-- Portal 1 & 2
-- Batman Arkham (Asylum/City)
-- Sonic Generations
-- Quake
-- Wolfenstein (3D)
-- Commander keen
-- Bioshock (1/2)
- L.A. Noire
and others
- Will use CD/DVD's of the games I have:
-- Warcraft 2 - Tides of Darkness & Beyond the Dark Portal
-- Warcraft 3 - Reign of Chaos & Frozen Throne
-- Diablo 1 - 3 (when it comes out)
-- The Sims 1 - And all expansions
-- The Sims 2 (probably)
-- Simcity 4000 & Rushhour
- May use emulation (to run up to the PS2/Wii)
What else I would like (MISC)
- Nothing I can think of @ moment
What I don't need:
- Speakers
- A monitor (@ this time)
- Dual GPU's (though folding@home may be useful for this)
- Alienware (or similar)
- Would rather not have to overclock anything. Rather would use good fans to cool.
* - My current (slimline)'s lowest is 2.6 (graphics), than game graphics (3.0), processor/RAM are 4.7 & primary hardisk is 5.6 . . . My current computer can play Warcrafts, SimCity & TS1.
That's all I can think of the moment. Max budget, If possible within $1200 - $1500 range.
Hardware
Software
Gaming Software:
- Will use steam:
-- Elder Scrolls
-- Portal 1 & 2
-- Quake
-- Wolfenstein (3D)
-- Commander keen
-- Bioshock (1/2)
- L.A. Noire
and others
What I don't need:
- Speakers
