- Jul 17, 2013
I'm a happy water cooler since about 9 months or so, but there is one issue I have since the beginning, which I still can't figure out.
How to decouple my D5 Res-Pump Combo from my case.
When I first planed and installed my loop this was the only way I could think of mounting the pump, and not knowing much about water cooling as a beginner back then, I just did it that way.
The placement is perfectly fine to be honest, but since I disassembled my loop and replaced the tubing a few months back, I can hear my PC. Just a very very slight humming sound.
At first I thought it came from the fans, even though they run at under 400rpm, but after turning them down the noise was still there.
I did some moving around inside the case and came to the conclusion, that it is the pump. Moving and touching the part where it is mounted directly influenced the sound.
Now, the simplest solution I found was to use some sort of "Shoggy sandwich", which is basically a sponge that absorbs vibrations.
The problem is that I can't place my pump on it, like if it was on the bottom of my case, because I have a pump-res-combo (which I like to keep).
So, do you guys have any suggestions on how to accomplish a proper decoupling?
I attached a picture that shows how my pump is mounted.
The silver brace, which holds the pump has a rubber in between, which helps a little, but doesn't reduce the vibrations to zero.
