- Aug 23, 2009
It would have to happen eventually, I am surprised it lasted this long but nope sure enough it started arti-facting in battlefield bad company 2 (purple spots) and yet it has been fine for weeks overclocked so I down-clocked to stock then overclocked it again until stable and all is fine but. I think it only has another year or two left in the old thing.
I am currently looking at an GT-240X-ZHFC
XFX GeForce GT 240 550M 1GB DDR5 HDMI DVI VGA PCI-E.
http://www.videocardshop.co.uk/view...dshop.co.uk/search.aspx?sub=GeForce200+Series
And I used an online psu calculator with all my current specs plus the new card, I might be getting and my cpu overclocked stable to 3.60Ghz and I got maximum needed watts was 340 but after some research the card needs at least a 400 watt psu for a bit of leg room.
Will this bigger psu suffice for my system.
OCZ Stealth Xstream II 500W PSU - 3x SATA 1x PCI-E.
http://www.ebuyer.com/204355-ocz-stealth-xstream-ii-500w-psu-3x-sata-1x-pci-e-ocz500sxs2-uk
Ideally I wanted another graphics card with at least 320bits like my current one and this one only has 128bits.
But all in all this little upgrade would only cost me a maximum of 102 pounds and, I already know about the pcie 2.0 vs 1.0/x16 issue for my current board but after some more research at my current resolution of one monitor at 1280x1024, 75 herts refresh rate it shouldn't be that bad and, I should see a significant increase in performance.
PC Spec's:
PSU-Antec 380 watt,
Motherboard-MSI P35 NEO2,
2x1GBDDR2 PC2-6400(400Mhz),
2X2GB DDR2 Ballistixs(With status leds)
Freezer 7 pro rev 2,
[Overclocked 3.60Ghz Stable]Intel(R) Core(TM)2DUO E6850,
[Overclocked-Custom-Bios-Flashed]Nvidia 8800 GTS 320bit G80(A2,96sp)with 640MB DDR3, Core Clock:649, Shader Clock:1488 and Memory Clock:902,
Hardrive(sata)-Samsung HD501LH 500GB,
Hardrive(ide)-Maxtor 4R120L0 120GB.
OS'S-XP-32bit/Windows 7-64 bit/Kubuntu 11.10-64 bit.
PC Case-Antec
Resolution-1280X1026.
Refresh Rate-75 Hertz.
CPU Clocking's:
CPU FSB:400
CPU Ratio:9
CPU Frequency:3600
VCore:1.4
Memory Volts:2.00
FSB:Auto(800)Mhz
NB:1.3
SB:1.05(Default)
PC Spec's:
PSU-Antec 380 watt,
PC Case-Antec
CPU Clocking's:
CPU FSB:400
CPU Ratio:9
CPU Frequency:3600
VCore:1.4
Memory Volts:2.00
FSB:Auto(800)Mhz
NB:1.3
SB:1.05(Default)
