- Thread Starter
- #21
Thanks for all or the comments. I'll try to address most of them if I can remember. As far as hose clamps, I will be using them but I need to be right on before I finalize everything. That's why I've turned to the best H2O resource I could find, and I thank you. Adding another 8" to the T is not a problem, I bought 10' of clearflex60 it was only $12, so I have extra to try out other configs.
There is a shroud on the core but it's the one from Danger Den. It's acrylic and a ***** to drill. Mine cracked but still useable. I'm thinking of picking up another shroud.
The heater core up top. I tried to put it down below but there is a nother hard drive rack that is not in the pics that goes down there. It also makes things tight with the tubing to the pump. If the core was downstairs I could probably lose a few inches in tubing but with the hd rack back in place I have to mount it sideways and things run tight.
Right now nothing is in stone.
