So i got an 8800gtx of ebay, and it had artifacts all over the screen, like a chessboard
Tried reflasing the bios --- still nothing
then rememberd some cases of heat fixing xbox 360's and thourght of using the oven trick on the card.
I put it in the oven for around 5 mins AND NOW IT WORKS
I seriously thourght he was joking, but i got so angry because i couldnt fix the card, i just bunged it in the oven and it worked!
Thanks for all the help!
( by the way if anyone is going to try it make sure u take all the heatsinks off first and make sure you use a PREHEATED oven set to 385F ( gass mark 6) (solder melts around 364F) )
different people left it in there for different times, most people said 6-8 mins 14 is too much
****EDIT1****
GUIDE
1: remove heatsink and thermal paste
2: preheat oven to 385F to 400F( NO HIGHER!) ( gas mark 6)
3: lay foil over the oven rack
4: make 4 balls of foil, about 4cm high,
5L when the oven is heated to its corrent temperature, put the graphics card on the 4 balls, one on each corner )
6: leave for around 6-10 mins, NO MORE THAN 12 OR IT WILL MELT
7: ENOJOY!!!
****EDIT 2****
THIS FIX MOSTLY DOES NOT NOT LAST FOREVER, SO DO NOT SELL THEM ON
Testimonials:
RAVANELI: but desperate to get it back I tossed it in the oven too. MIRACLE!
haste 226: i was finally able to attempt this today and im amazed! it worked. wow...if i had only known when it died...
POLARYS425: Add one more 8800GTX to the success list. I just baked it for 12-15 minutes at 385F.
ME: Stuck it in the oven for 8 mins (exactly) AND NOW IT WORKS!!!!! aaaaaa im soo hapy
DANBROKE: Sweet lord! I just did it too my cellphone that wasnt working and Walla!! It work again!!!!!!!!!!!!!!!!!!!!!! OMG! Great trick!!
might as well give it a shot. To my amazement it totally worked, card is now (apparently) all good with no video corruption or anything
zOZ: I threw it in the oven and it came out and also... now works
BADBONJI: he didn't believe me (I gave him some links of how people have done it) and now it works again, saves him from buying another gpu for a while!
WIKING: Thank you so much, this resurected my x800xl that didnt even POST
ANOTHERSMOKE: let cool new paste and wallah! been folding when not at computer for 3 weeks
PINKGOLD This is madness!! Yesturday I had an 8800gtx that wouldn't even let my comp start if it was connected! Today after 5 mins of light baking, I have a fully functioning gpu!!
Gods_oMekone: it works! booted into windows fine. going to install some games and make sure 3d works
remember to keep the card level in the oven
Can we just simple overheat this gpu to melt those solders
Head hurt two days. Maybe fumes? But I baked garlic bread afterwards and tasted delicious! I feel fine!
Card works great!(better actually due to new thermal compound)
