http://www.thermalright.com/new_a_page/product_page/vga/hr-03_gtx/product_vga_cooler_hr03gtx.html
Good news for [FONT=Arial, Helvetica, sans-serif]GTX280 & GTX260 Owners
[/FONT]
[/FONT]
They did a good job on cooling the board loving this cooler from looking at the pics[FONT=Arial, Helvetica, sans-serif]Graphics cards Compatibility
For nVidia GTX280 & GTX260
Note: When installing on a GTX280 or GTX260, a fan must be used.[/FONT]
- [FONT=Arial, Helvetica, sans-serif]6 quality heatpipes for maximum amount of heat transfer to work with any of 92mm or smaller fans for best configuration to suit your needs [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Proprietary two-heatsinks-soldered-to-form-as-one design to maximize cooling capacity[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Heatpipes soldered every heatsink fin to increase heat transfer efficiency [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Nickel-plated heatsink to reduce oxidation effect, maintaining top performance for long term usage[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Two ways of mounting the cooler on video card for best space and configuration management in ATX and BTX form factor cases [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Includes the PWN-IC heatsink with proprietary thru holes adapted from the High Riser Series for best heat dissipation[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Sleek and stylish appearance [/FONT]
