- Jan 4, 2001
- fort drum NY
this is how to install a G4ti4200 in mandrake 8.2 and 9.0
ok this was,as all linux undertakings, a big run around so ill give a step by step the best i remember
1. install mandrake 8.2 with the defualt vidio configuration. make sure to pick to install chromiun the game
2. once you make it all the way to the desktop you can exhale. go to nvidia and get
nvidia_glx-1.0-2960.i386.rpm
nvidia_kernal-1.0-2960.mdk82(smp if you need it).i586.rpm
and dl the file "mc-4.5.55-9mdk.i586.rpm" from mandrake cooker
put them in the root directiory or somewhere you can find them from the terminal
3. install mc-4.5.55-9mdk.i586.rpm. its midnight commander text editor and it wil make life tollerable in linux terminal
4.edit the file /ect/i nittab
find the line that reads id:5:initdefaut:
change the 5 to a 3. this makes it stop at the terminal and not auto start the xserver.
5.reboot and log into root(you should be in terminal) remember linux is case sensitive!
cd into the directiory with your rpms
type rpm -ivh NIVIDIA_k.(hit esc twice and it will complete it for you) then press enter
type rpm -ivh NVIDIA_G9hit esc twice) then press enter
6. now type XFdrake or FXdrake? and choose the nvidia generic geforece 3 card. it should give you an option of withch free86 you want. choose 4.2 and follow the install directions(ex:instert cd1 press enter) remember to say no to any testing or starting x after reboot. Say yes to keep configuration making sure that xfree86 4.2 is shown
7. reboot and log back into root. do the whole xfdrake thing again making all the same selections.
8. now we edit the xfree86config-4
change directory to find the file at /ect/X11
type mcedit XF86Config-4 (big blue screen comes up)
now look for the line that says Load "dbe"
and add underneith Load "glx"
9.now find the graphics device section in the config
change the lines to look like this
section "device"
identifier "NV AGP"
blah blah blah
driver "nvidia"
10.now find the screen sections
change it to look like this
section "screen"
identifier "screen1"
device "NV AGP"
11. now press f2 to save and then f10 to quite
12. now type startx and you should boot into kde. try any game that is opengl (like chromium) if it works your all set. i dont know why there is no nvidia spash screen.
section "device"
identifier "NV AGP"
blah blah blah
driver "nvidia"
section "screen"
device "NV AGP"
