I'm glad i found this forum!! Well this is my first time posting here, i needed some help and i'm not sure if this is the correct way of asking. I'm currently reading thru all thread to find out more about overclocking. Seems interesting.
Can someone kind of guide me what i should do to so called maximise my CPU? Like example from experiences with this setup what can i do with it? Before any further i juz went to BIOS to change from 200 to 210GHZ.. and from 100 to 110 MHZ...hehe
Enlightenment?
System Information
Time of this report: 12/7/2007, 12:54:30
Machine name:
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3200+, MMX, 3DNow, ~2.1GHz
Memory: 2048MB RAM
Page File: 648MB used, 2781MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6600 GT
Chip type: GeForce 6600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0140&SUBSYS_31261458&REV_A2
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6218 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/29/2007 00:43:00, 5690624 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 6/29/2007 00:43:00, 6807328 bytes
Device Identifier: {D7B71E3E-4200-11CF-A26F-2D1103C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0140
SubSys ID: 0x31261458
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10DE&DEV_0059&SUBSYS_AE011458&REV_A2
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5770 (English)
WHQL Logo'd: Yes
Date and Size: 12/22/2004 17:07:12, 2304320 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 26, 23
Static/Strm HW 3D Bufs: 26, 23
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 20:00:00, 57600 bytes
| Driver: usbd.sys, 8/4/2004 20:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 20:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 20:00:00, 24576 bytes
+ HID Keyboard Device
| Vendor/Product ID: 0x1532, 0x0101
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 20:00:00, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Heroes of Might and Magic III (DX7) - Registry: OK, ExeFile: Heroes3.icd (<File Missing>)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 35.1 GB
Total Space: 76.3 GB
File System: NTFS
Model: SAMSUNG SP0822N
Drive: D:
Model: TSSTcorp CD/DVDW SH-S182D
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 49536 bytes
Drive: E:
Model: JM5841J LMZ850Y SCSI CdRom Device
System Devices
Name: NVIDIA GeForce 6600 GT
Device ID: PCI\VEN_10DE&DEV_0140&SUBSYS_31261458&REV_A2\4&243D7BD0&0&0070
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6807328 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 5690624 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 360448 bytes
Driver: C:\WINDOWS\system32\nvucode.bin, 6/29/2007 00:43:00, 1018772 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6729728 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 8466432 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.12002 (English), 6/29/2007 00:43:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6234112 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 5455872 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3321856 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3072000 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 1142784 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3518464 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3600384 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2330624 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2416640 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 6/29/2007 00:43:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 6/29/2007 00:43:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 6/29/2007 00:43:00, 37376 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 6/29/2007 00:43:00, 37376 bytes
Name: nForce4 HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_50001458&REV_A3\3&2411E6FE&0&00
Driver: n/a
Name: nForce4 PCI-Express Root Port
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&68
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&58
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_50041458&REV_A3\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 08:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_50041458&REV_A2\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 17024 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_10DE&DEV_0059&SUBSYS_AE011458&REV_A2\3&2411E6FE&0&20
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5770 (English), 12/22/2004 17:07:12, 2304320 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0034 (English), 12/22/2004 17:09:44, 77824 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0038 (English), 12/22/2004 17:06:56, 17584128 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 13:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0040 (English), 12/22/2004 17:13:36, 9524224 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0004 (English), 9/7/2004 14:23:16, 156672 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_E0001458&REV_A3\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0468 (English), 1/13/2005 16:45:46, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0468 (English), 1/13/2005 16:45:28, 261120 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0468 (English), 1/13/2005 16:45:18, 208256 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 1/13/2005 16:42:42, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 1/13/2005 16:42:42, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0016 (English), 12/16/2004 16:32:36, 32256 bytes
Name: NVIDIA nForce4 ADMA Controller
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_B0031458&REV_A3\3&2411E6FE&0&40
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0507 (English), 1/20/2005 08:45:30, 88960 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 1/20/2005 08:45:32, 295424 bytes
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_B0031458&REV_A3\3&2411E6FE&0&38
Name: NVIDIA nForce4 Parallel ATA Controller
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_50021458&REV_A2\3&2411E6FE&0&30
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_0C111458&REV_A2\3&2411E6FE&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_A3\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 20:00:00, 35840 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8025&SUBSYS_10001458&REV_01\4&13699180&0&5048
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 20:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 21:46:40, 6400 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 20:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 20:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 20:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 20:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 7/11/2007 23:15:00 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/22/2007 12:12:53 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 8/22/2007 12:12:47 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 8/22/2007 12:12:48 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 8/22/2007 12:12:49 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 8/22/2007 12:12:49 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 8/22/2007 12:12:49 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 8/22/2007 12:12:50 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 8/22/2007 12:12:50 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 8/22/2007 12:12:51 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 8/22/2007 12:12:51 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 8/22/2007 12:12:53 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:53 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:53 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:54 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:54 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:52 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:52 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/22/2007 12:12:51 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 20:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 20:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 20:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 11:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 20:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 20:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 20:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 20:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 20:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 20:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 20:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 20:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 20:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 20:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.02.0012.0009
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.02.0012.0009
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.02.0012.0009
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.02.0012.0009
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.02.0012.0009
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero3D Video Filter,0x00200000,1,1,NSG_dxFilter.dll,1.00.0000.0007
Nero Digital Audio Decoder,0x00400000,1,1,NeAudio.ax,4.02.0012.0009
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0003.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00400000,1,1,NeResize.ax,4.02.0012.0009
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.02.0012.0009
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0009
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.02.0012.0009
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.02.0012.0009
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.02.0012.0009
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.02.0012.0009
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0012.0009
Nero3D Transition,0x00200000,1,1,NSG_dxFilter.dll,1.00.0000.0007
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.02.0012.0009
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.02.0012.0009
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.02.0012.0009
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,3,1,NeVideoHD.ax,4.02.0012.0009
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.02.0012.0009
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.02.0012.0009
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.02.0012.0009
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.02.0012.0009
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0003.0000
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.02.0012.0009
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
Nero3D Text Effect,0x00200000,1,1,NSG_dxFilter.dll,1.00.0000.0007
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.02.0012.0009
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.02.0012.0009
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,11,NeDVD.ax,4.02.0012.0009
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.02.0012.0009
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Elecard MPEG2 Demultiplexer,0x00800100,1,2,mpeg2dmx.ax,2.00.0084.30429
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.02.0012.0009
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0009
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.02.0012.0009
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.01.0001.0002
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.02.0012.0009
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.02.0012.0009
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.02.0012.0009
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0009
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.02.0012.0009
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.02.0012.0009
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,DVobSub.ax,1.00.0000.0009
RealAudio Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
DirectVobSub (auto-loading version),0x00800002,2,1,DVobSub.ax,1.00.0000.0009
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.02.0012.0009
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.02.0012.0009
AC3Filter,0x40000000,1,1,ac3filter.ax,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.02.0012.0009
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.02.0012.0009
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.02.0012.0009
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.02.0012.0009
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.02.0012.0009
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.02.0012.0009
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.0000.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
Morgan Stream Switcher,0x00800001,1,1,MMSwitch.ax,0.09.0009.0000
TS Strider,0x00200000,1,1,TSStrider.prm,1.01.0004.0021
Dump,0x00200000,1,0,DvFileWriter.prm,3.00.0000.0000
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.02.0012.0009
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0012.0009
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.02.0012.0009
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.02.0012.0009
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.02.0012.0009
TSSourcePush,0x00200000,0,1,TSSourcePush.prm,
EssienR&D MPEG Writer Filter,0x00200000,2,0,mpgfiltr.ax,
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.02.0012.0009
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.02.0012.0009
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0009
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Elecard MPEG2 Video Decoder,0x00700000,1,1,mpgdec.ax,2.00.0000.2525
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.02.0012.0009
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.02.0012.0009
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2749
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2749
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2749
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
WDM Streaming Rendering Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,17,2,,5.03.2600.2180
Enlightenment?
System Information
Machine name:
Memory: 2048MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0140
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 35.1 GB
File System: NTFS
Drive: D:
Drive: E:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
BDA CP/CA Filters:
