Its been awhile since I built my PC, now its time to add that second video card. I see from the sticky that the newer drivers allow you to mix and match cards.
Question: Which 2nd card should I get, equal or better than the BFG 7800 GTX thats currently onboard? Thanks
DFI LP NF4 SLI-DR (BIOS 623-3)
AMD Athlon 64 3700+ 939 90nm 1mb L2 cache
2GB (2x1GB) Crucial Ballistix Tracer PC4000
1-BFG GeForce 7800 GTX OC 256mb
WD 74 Gb SATA 10,000 rpm Raptor
NEC 3540A DVD RW
Mitsumi Floppy 7 in 1 USB Card Reader/Smart Media
Creative X-FI Fatality
PC Power & Cooling Turbo-Cool 510 SLI
Lian Li PC-60B Plus case
XP x64 Pro
NEC 3540A DVD RW
XP x64 Pro
