- Aug 20, 2003
Why in all that is holy would you buy a 6000 series CPU mobo for a fresh build? You can get a Z270 for the same cost and get a 7700k which will cost about $175 less than the 6850k and perform about 5% faster, not to mention support for newer tech that the 6000 series dont support. You can also overclock the 7700k to 4.6 - 4.7 Ghz with minimal effort and 4.8 - 4.9 with a bit of effort and some good cooling. CPUs are one of those things that dont usually make sense to buy older models because the newest models are always faster and almost always cheaper.
Why would you comment that he should buy a 4c processor when he specifically states he needs more cores for work processing? If you think that a 7700k is going to be faster in multi-threaded apps then you're dead wrong. Last time I checked, my old xeon in my server does much better at multi-threaded things than my 7700k @5ghz (also debunking your cheaper to buy the newest processor and they are faster argument, I only paid $250 for my 14c processor...).
OP - I say if you don't need the extra pci lanes get the 6800k as it will save you some money.
