- Dec 1, 2003
Well, as time comes near for me to finally commit to buying my Wata stuff I'm left with a few nagging questions;
1. 3/8" ID vs. 1/2" ID; I've heard from people that the larger tubing is only a 1*c improvement at best; and thats with a full WC system... I'd like to know I can get away with a 3/8" ID system using an RBX and Maze4 GPU with a HC rad and either a Hydor L30 or a Danner Mag (now that I know DM = pondmaster I have to re-check my local stores, I think they DID stock pondmaster but since I didn't know...)....
2. Will the tubing I find at Home Depot (assuming I got 3/8" ID) fit over the RBX's 1/2" barbs? I cannot find a 3/8" ID RBX at DangerDen, I think FrozenCPU stocks them but I've heard that shoving the tube over a bigger barb has a better fit and if I can leave myself the option of changing to 1/2" ID later, well, thats a good thing...
3. How do zip ties (used in wire management) the things that have that friction clamp (I think I got the name right but...) come in many colors, cheap how are they as clamps? is is risky or ok?
4. Finally, for making a resiviour should I use homemade Acrylic cement (got a great guide on Pimprig.com, the guide aint up now but I know the guy who knows how to make it and can get the recipe, he has great success with it) or will hot-glue work... I think it would be tight enough but its very HOT and might melt the plexi, trial and error might be a good thing to use here but what the hey, might at well ask..
