- Jun 6, 2005
- Oregon, US
How flexible would you say that Tygon braided tubing is? The bend radius on their spec sheet looks good, but is it much stiffer than the regular Tygon stuff?
xcuriousgeorge said:How flexible would you say that Tygon braided tubing is? The bend radius on their spec sheet looks good, but is it much stiffer than the regular Tygon stuff?
Jas said:A better choice would be the Tygon R-3603, it has a bend radius of 1.5" (1/2" ID 3/4" OD) R-3603 is the type of Tygon most commonly used in water cooling setups.
capneedle said:According to www.mcmaster.com on page 85 Tygon R-3603 at 1/2" ID 3/4" OD has a bend radius of 1.5" but why not use the Masterkleer on page 82, apparently you don't get the possibility of staining and it has a bend radius just 0.25" greater than tygon but much cheaper.
Cap
bigben2k said:I've used a u-tube from usplastics.com for another application; it's a vinyl tube that's pre-bent into a U shape.
