My project for today has been setting up a web server. I was given a old computer with a Pentium 4 processor; 512mb of RAM, and a 42gig hard drive.
I was reading over some guides and I came across this guide. It is very self explanatory; however I am having issues with my configuration files within Apache and my firewall (shorewall).
I am focusing on web security. I don't even want to web edit until I know it is "lock-down" secure. In Apache are some supposed settings called Server Tokens and SeverSignature. I can't locate these files in my apache2.conf unfortunately.
Here is what is posted to me in the config:
I have tried re-installing.
Shorewall
I have uninstalled Shorewall. I can't post my code issues with what I was experiencing. But I can say that I didn't have access to
I couldn't get that line of code to run. I've been all over the Ubuntu forums, google, Apache 2.2...
You guys are my best bet now. I can't find anything to help...
Code:
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "/var/log/apache2/foo.log"
# with ServerRoot set to "" will be interpreted by the
# server as "//var/log/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs-2.1/mod/mpm_common.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
#<IfModule !mpm_winnt.c>
#<IfModule !mpm_netware.c>
LockFile /var/lock/apache2/accept.lock
#</IfModule>
#</IfModule>
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
MaxRequestsPerChild 0
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
</IfModule>
# event MPM
<IfModule mpm_event_module>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog /var/log/apache2/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include /etc/apache2/mods-enabled/*.load
Include /etc/apache2/mods-enabled/*.conf
# Include all the user configurations:
Include /etc/apache2/httpd.conf
# Include ports listing
Include /etc/apache2/ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Define an access log for VirtualHosts that don't define their own logfile
CustomLog /var/log/apache2/other_vhosts_access.log vhost_combined
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include /etc/apache2/conf.d/
# Include the virtual host configurations:
Include /etc/apache2/sites-enabled/
Shorewall
sudo cp /usr/share/doc/shorewall-common/examples/one-interface/* /etc/shorewall/
Now, open the “rules” file:
sudo nano /etc/shorewall/rules
Add these lines above where it says “#LAST LINE”
HTTP/ACCEPT net $FW
SSH/ACCEPT net $FW
Then press Control-O and Control-X. Your firewall is now configured to only accept HTTP and SSH traffic.
