Underclocking MobileBarton with higher voltage dangerous?? software multiplier chang
i have a mobile barton at 2.2ghz 1.85v. most of the time it doesn't need this power, esp when its just sitting around or downloading or whatever. if i lower the multiplier using crystalcpuid to 668mhz or whatever, it still works fine. the temperature drops 8c or so. so it seems to be using less power, but will the high voltage damage it somehow? i cannot change it because the k7s5a pro doesn't support changing voltage any easy way, let alone in o/s.
i just want less heat in my room, to use less power, and well, a cooler cpu when its not gaming is nice
