on another note. This case and the swiftech cooler support PWM settings. I read about it but i am not sure i can do it on this mobo? (asus sabretooth 990fx). I am not sure how to set the fans to work in tandem together. i have
i have two fans that cool the radiator.
One exhaust 140mm at the back
One intake 200+ in the front
One 140mm a the bottom of the case blowing UP..im not sure if thats intake or exhuast but its sucking in cold air from the outside.
sorry if am being confusing new to all this. Thanks again
Have you read the Enthoo Luxe PWM setup in case manual?
The PWM hub functions optimally when modulated by a PWM
signal from the motherboard, which will allow the greatest control
range. However, not all 4-pin motherboard connectors implement
the PWM signal modulation.
Connecting the 4-pin to CPU_FAN
For full PWM functionality, Phanteks’ PWM hub requires users to con-
nect the 4-pin connector to the “CPU_Fan” connector of the mother-
board, because all motherboard manufacturers implements a PWM
signal modulation on this connector. Connect the SATA 12V power to
power the PWM hub. Not all motherboards have their CPU_Fan con-
nector set on PWM signal modulation by default. Please consult your
motherboard documentation for this matter.
Connecting the 4-pin to other 4-pin header (besides the CPU_Fan)
Other 4-pin connectors can be found on modern motherboards be-
sides the “CPU_Fan” connector (e.g. “CPU_Fan2”, “CHA_Fan”, “OPT_Fan”),
however not all motherboard manufacturers implement a true PWM
signal modulation onto these connectors. These type of 4-pin connec-
tors modulate the RPM by voltage, which has a smaller control range
compared to modulation by true PWM signal.
The 12V SATA power cable can not be used to power the PWM hub if
connecting to these types of 4-pin connectors, due to the interference
with the RPM regulation by voltage (resulting in the fans running on
full RPM). The PWM hub will draw its power from the 4-pin connector,
which is limited to a total device consuming 30W in total.
Important Note:
1 motherboard connector can only read 1 RPM signal. Therefore, the motherboard
will only read the RPM signal from 1 device connected to Fan 1. The RPM form all
other devices will be regulated according to FAN 1. Y-splitter should not be connected
to FAN 1.
You have to set the motherboard Fan Control to PWM not voltage and then you would have to use the 4 pin CPU Fan Header to send signal and power to the Luxe PWM controller on the correct input and use OPT CPU Fan header on mobo to Signal the Water cooler fans.
At least that is how it seems explained since I am likely getting that case and have been following the big arse thread over at OCN in the thread for all the Phanteks cases.
RGone...
