- Apr 19, 2012
Will some one just pm this guy and send him a quad heat pipe phenom stock heat sink and fan already. At least hell get a good load temp might even get some oc from it too...
Why would I want a piece of s**t cooler? You forget, I had one with the CPU and whops, straight in the garbage it went!
Because I know for a fact they can cool over 140w just as you see it depicted. It did in fact come with 140w boxed processors such as 965BE and 9950BE, AND WILL cool better than a 3 pipe cooler because it has FOUR heat pipes....
THEN you put a decent high cfm fan on it and overclock.
Thats why.......
Been running an A8_3850 overclocked and using IGP under that sink for years now. Max oc is 3.6ghz and spanked my FX_4100 with both cinebenches and the fx was on ambient liquid cooling.
Years. Go to classicplatforms, ive had the system a long time now. That heat sink is fine, you must live inthe desert somewhere.
Hey if I had a spare, I,d send it. Free is a good deal
Pretty surethe heat sink you have no is no good.
Do you have the original back plate installed?
When I get home tonight, ill dig in my magical box of wonders and see if the little magical mushroom man has one of those heat sinks in his pocket. Be around 7pm central us time. And maybe a shot of diamond paste in the corner of a baggy too.
Other wise like I said before, the cpu is just going to roast to death.
Its the 78c load temp that I worry bout.
now you need to get a little more case airflow going, the line cputin is getting to the temps i start doing something.
the vrm section, on the otherside of the cpu from the ram needs some more airflow, we like to keep that below 70c.
