- Oct 22, 2011
Hi Everyone,
I'm considering upgrading my brother's old PC into an HTPC.
I wasn't sure where to place this, but since it pertains more to hardware than an HTPC specifically, I posted here.
The PC is an old Acer Aspire E560.
A short rundown on the specs:
I have a GTS 250 lying around since I recently upgraded to a GTX 570. So, I was thinking I could make use of that to reduce costs.
Aside from the GPU, here are the components I plan to upgrade:
What do you think?
Are there any incompatibilities?
Is it worth it? Any suggestions?
My budget is around $250 as I don't want to invest anymore in an ancient machine. Of course, I prefer going lower.
Feel free to use Newegg as reference, I'll be the one to look for the part
I am still researching/doing due diligence on the feasibility of this, so please bear with my limited knowledge.
Any input would be greatly appreciated!
CPU: Intel(R) Pentium(R) D CPU 2.80GHz
MOBO: Acer E415SM
RAM: Kingston 1 GB DDR2 (2x)
PSU: "Industry Standard 250 Watt"
HDD: 160 GB?
GPU: GeForce 9500 GT
(I won't be ordering from Newegg as I don't live in the US but it'll be a sufficient reference)CASE: COOLER MASTER Elite 430 49.99
* I'm not sure the GPU would fit in the OEM case. Plus it's too crammed.
HDD: WD Caviar Green WD10EARX 1TB 139.99
* Additional storage for movies, etc. Not sure if it's compatible though.
PSU: CORSAIR Builder Series CX430 44.99
* I don't trust the "Industry Standard 250 Watt" PSU
TOTAL: $234.97
What do you think?
