- Jan 6, 2016
In the slow process of upgrading my gaming computer while on a budget, so been saving money where I can. I just finished buying and installing a liquid cooling system on my processor and tweeking it to get some improved performance out of it. Now I'm looking at moving on to video card and RAM, and interested in what people recommend I use with my current board and CPU. Now you can see my current specs below including the Board and CPU I'm using and will be sticking with. So what I'm interested in is what RAM and video cards people recommend for top gaming performance. Keep in mind I am on a budget so can't afford the really expensive stuff. Though I want to try build a machine that will run top of the line games at best possible graphics settings I do, even if it means overclocking a few things to do it.
Now what I'm currently looking at in terms of video has been between the Geforce 960 and the Geforce 980Ti. Though the later will require me to do a bit more saving in terms of money. However, I'm wondering what the comparison is between them and their AMD counterparts, considering I'm using a board that could do the AMD Mantle if I had a AMD GPU?
In terms of the RAM I typically buy Corsair and would be going from a 8gig (2x4gig) set up to 16gigs, most likely 1600mhz and definitely DDR3 since my board only supports that. However, my board has been a bit finiky with Corsair ram (I've had to manually adjust some settings in bios to get them to work right) even ones that are on it's compatibility list after fully updated bios. So I'm willing to try other brands if anyone thinks there is a better option out there for me?
