Hey everyone, coming back here because you are always so helpful. I've been here a few times in the past on the creation and success of my computer. But now I need to do some upgrades, and I'm going to be much less picky this time around.
When I built my PC, it was a powerhouse, dominating all games and programs it came across. These days, I have to overclock just to keep on par.
Basically, I need a new, affordable, trustworthy motherboard. In doing so, I would require a new processor and ddr3 ram sticks for the board. My graphics card is (in my opinion) sufficient for the time being, given my limited budget... I don't want to burn too big a hole in my pocket now.
Below is my current build and opinions with each part.
(Note: This computer is used for much multi-tasking in small-end programs, running Dual-monitor dual-screen setup. This computer gets a lot of use. It is also used for med-high end gaming with games like APB, Rift, SC2, All Call of Duty games, and diablo3 when it's released.)
CURRENT BUILD:
Case: Not Interested In Upgrading.
Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower Computer Case
I love this case, and the size of a full tower is specifically something I did want.
Motherboard: Needs To Be Upgraded!
ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
After a few past posts, other uses came to the conclusion that my current motherboard will stunt the future growth of my PC, as it is now obsolete. What would be a good way to go from here? I'm really a noob at this haha.
Power Supply: Not Interested In Upgrading.
CORSAIR CMPSU-650TX ATX12V / EPS12V 650W Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
So far I have no problems with this. I don't see myself needing any more than this unless someone thinks I really need it based on further upgrades.
Video Card: Not Interested In Upgrading.
BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143119
I know its a good card, especially with G92. I'm on a limited budget, so I think upgrading this is not more important than upgrading the ram/processor/motherboard.
Memory/Ram: Needs to be Upgraded!
Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory
I'm looking to shoot for DDR3 now, which isn't possible on my current MB. So basically, whatever ram I'm recommended NEEDS TO BE COMPATIBLE with the new motherboard I end up getting. xD
Processor: Unsure, possibly needs upgrading?
AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 125W Dual-Core
I know its not the best, but given the current state of my computer, is it recommended? I figured if I should change it, its best to do so with the change of my motherboard. If I do change the processor, it has to be affordable.
PS: I'll say this. The funds I have available for this are in the ten-thousands range. But I didn't save that money by making bad financial decisions. I'm extremely careful with my money. So while my budget is unrestricted, I still would like to be safe with how much I spend on this. Don't go suggesting me Alienware-worthy parts now, I just need to be able to do my upper-end gaming and multitasking. I'm not launching nuclear satellite uplinks or some crap
Thanks again!
CURRENT BUILD:
Thanks again!
