Hello, I currently have the following:
mobo: Asus P5KC
cpu: Q6600 Kentsfield (6-F-B) @ 2.4 GHz (1.25V)
ram: 4xCM2X6400 (8GB) 800MHz 5-5-5-18 (1.8V)
gpu: nVIDIA GTX280
psu: Arctic 700
case: Thermaltake Armor+ VH6000BWS
I can still run SWTOR on basically full settings and do all the stuff I need to do, but I've saved up some cash and wanna upgrade the 4 and half year old setup.
Also, I think my (non 80+) psu may be dying (had to disconnect one of the DVD Drives to boot the system otherwise the main HDD wouldn't start up properly).
After some research here's what I'm thinking:
I would appreciate any suggestions
I use the following shop (the pages are in slovak, but should be easy to navigate anyways)
p.s. as a thermal compound I have a brand new Arctic MX-4 bought about a year ago, should I invest into something newer/better?
p.s.2 for some reason i7 2600k 3.4 GHz in my store is €290, i.e. €30 more than the 2700k.
Based on the product description other than the well known 100MHz clock diff, they are identical.
Thank you
mobo: Asus P5KC
gpu: nVIDIA GTX280
psu: Arctic 700
- keep the gpu until the end of the year (or so) I'm quite happy with it
- urgently get a new psu - I'm thinking around 750W, here are some options
- ENERMAX NAXN 80+ ENM750AWT 750W (€100)
- CORSAIR 750W TXV2EU (€100)
- OCZ Fatal1ty Series 750W (€90)
- OCZ ZT Series 750W (€90)
- OCZ ZS Series 750W (€75)
- then, get the following:
cpu: i7 2700k 3.5Ghz (€260) or i7 3770k 3.5 Ghz (€300)
mobo: ASUS MAXIMUS V GENE (€163)
cooler: Arctic Freezer i30 (€30)
ram: DDR3 2x8192MB CMZ16GX3M2A1600C9 Vengeance (9-9-9-24 1.5V) (€75)
+ an SSD drive for the system and the most used games (2 or 3) (~€150)
I've read the discussion about 2700k vs 3770k.
In price the difference is 40 euros, the general consensus seems to be that while 3770k is newer, has more features (supports officially 1600 MHz RAM) and the Z77 chipset is specifically created for it, I would like to give overclocking with 2700k a go (to somewhere around 4.6-4.7).
Unless you guys think I should really spend €40 more for the 3770k.
While most mobos will handle overclocking fine I'd prefer to spend around 150 euros for a solid mobo (€200 for P8Z77-V Pro is a little too much but if you guys think it is worth it I'd consider the top stuff for €200)
Other mobo options I looked at where:
- ASROCK Z77 Extreme4 (€130)
- GIGABYTE Z77X-UD3H (€155)
- ASUS P8Z77-V LX (€105)
but I'm liking the Maximus V Gene the most (so far).
I've read that although 2700k officially supports only 1033/1333 MHz RAM everyone (I saw) days is runs happily with 1600MHz.
The one I listed was one of the few 16GB 2 piece sets with 1.5V so I picked it up. It there some advantage of using 2 DIMMs over 4 esp. for overclocking?!
Thank you
